Wheel alignment - Yellow Bullet Forums
Old 09-20-2019, 08:49 PM   #1
sbfnotch
Default Wheel alignment
Is there any difference in wheel alignment from a street/strip car with skinnies to a normal everyday vehicle?
sbfnotch is offline   Reply With Quote
Old 09-20-2019, 09:34 PM   #2
Lumbergh
Lumbergh's Avatar
Default Re: Wheel alignment
Yep, street strip usually will will usually run around 0 for camber, street cars run negative for handling.
Lumbergh is offline   Reply With Quote
Old 09-20-2019, 09:48 PM   #3
sbfnotch
Thank you
Old 09-21-2019, 01:01 PM   #4
Shawn Finn
Shawn Finn's Avatar
We run more caster as well. For a street deal we will normally run 2-3* of caster, .5-1* on the camber. Race stuff will be 6-8 on the caster, 0 or .1 on the camber depending on what it does throughout the travel.
The Engine Shop
Farks Supercars
718 594 3003
562 DRCE1 Engine for sale
Dealers for: Ferrea, Mark Williams, Aeromotive, Procharger, Fueltech, PST.
Shawn Finn is offline   Reply With Quote
Old 09-23-2019, 12:29 AM   #5
engineguy
For a street/strip vehicle, go with the stock specs. It is always a good idea to place some weights, equal to your body weight in the drivers seat during the alignment procedure.
For a race only vehicle, more caster is recommended as well as checking and correcting any bump-steer. Correcting bump steer can be a major project, however the results are very worth while.
Bill
SAE Member (28+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
Do what you can, with what you have, where you are.
- Theodore Roosevelt
engineguy is offline   Reply With Quote
Old 09-23-2019, 06:48 PM   #6
DracerX
DracerX's Avatar
Some people go the extra mile for a drag only setup and jack up/raise the front end to simulate weight transfer and the car's stance going down track.
DracerX is offline   Reply With Quote
Old 09-23-2019, 07:07 PM   #7
I run as much caster as I can . 1/16" of toe in
The track is where it counts . But handles just fine on the street
Old 09-24-2019, 11:55 AM   #8
bracketchev1221
This is how mine was always done.
http://s30.photobucket.com/albums/c306/bracketchev1221/chevelle%20pics/?action=view&current=DSC01615.jpg
Best ET 8.87 at 151 @ 3200 lbs. Sold 3/18
New project 70 Chevelle SS396 restoration. Completion date????????
bracketchev1221 is offline   Reply With Quote
