Vacuum pump ins" VS lbs. - Yellow Bullet Forums
Old 09-20-2019, 12:03 PM   #1
MT BUICKNUT
MT BUICKNUT's Avatar
Default Vacuum pump ins" VS lbs.
On a vacuum pump my gauge reads lbs. then I read about inches of mercury. What's the difference, and what would be a suitable setting in pounds?
Thanks Rick
Rick Starkey
Buick Goin Fast With Class
MT BUICKNUT is offline   Reply With Quote
Old 09-20-2019, 01:03 PM   #2
NHRA686
NHRA686's Avatar
Default Re: Vacuum pump ins" VS lbs.
1" Hg is about -.5 psi. If your gauge is reading -10 psi, you have about 20" Hg
Bill Huntington
www.gzmotorsports.com
NHRA686 is offline   Reply With Quote
Old 09-20-2019, 07:42 PM   #3
wolf Wengler
wolf Wengler's Avatar
Hey Bill!!
Question I've been thinking about:
How does vacuum change as altitude increases? If I run 8 inches at sea level and I take my car to Santa Fe, elevation 7,000 msl, what does my vac gauge read? Is there a formula, does it go down 2%/1000 feet or ???? Lower than 6?
thx!!
509 BBC, solid roller
5-speed, 4-link
wolf Wengler is offline   Reply With Quote
Old 09-21-2019, 03:09 PM   #4
NHRA686
NHRA686's Avatar
I'm not sure. I do know that It's harder to get good vacuum at high altitude
Bill Huntington
Old 09-21-2019, 05:20 PM   #5
juiced coupe 78
juiced coupe 78's Avatar
https://www.engineeringtoolbox.com/a...ure-d_462.html
Look at the PSIA at different elevations. 14.7# PSIA is what would be considered normal for sea level, or 0# PSIG.
juiced coupe 78 is offline   Reply With Quote
Old 09-21-2019, 08:37 PM   #6
440roadrunner
440roadrunner's Avatar
LOL that's because the pressure you are evacuating is less--atmospheric pressure. Previous poster is right. It's about a 50% ratio "roughly" psi to inches Hg. Sea level is just under 15psi in rough figures, and just under 30" Hg. I refuse to think in "bars." And be careful, somethings are inches of WATER. We used to use that all the time in HVAC for gas/ LP pressure, and duct pressure
Thanks for upping my post count!!
440roadrunner is offline   Reply With Quote
