The Opinionated Angle( My Take on Pinion angle) - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension
Old 09-05-2019, 09:31 AM   #1
DragBoss
DragBoss's Avatar
Default The Opinionated Angle( My Take on Pinion angle)
This is my take on measuring pinion angle.
408 Cleveland, 9.69 at 136mph with a 1.27 60 ft. Just starting to fine tune.
DragBoss is offline   Reply With Quote
Old 09-05-2019, 11:30 PM   #2
440roadrunner
440roadrunner's Avatar
Default Re: The Opinionated Angle( My Take on Pinion angle)
Well you are wrong. Been said here many times. Take the driveshaft out of the car and hide it. The pinion in reference to the crank/ transmission shaft centerline is what you want. They need to be paralllel under power. The end.
Thanks for upping my post count!!
440roadrunner is offline   Reply With Quote
Old 09-06-2019, 08:07 AM   #3
DragBoss
DragBoss's Avatar
That is true, the rear end rises under load, not sure what I said wrong. Either way, that is why i said it is my opinion, and works for me.
Old 09-06-2019, 07:25 PM   #4
Topfun99
Topfun99's Avatar
Location: Temporarily Away, Check Back Later For Updates
X1000
As soon as I see someone measuring the driveshaft angle relative to ANYTHING, I know it's going to be bad advice relative to setting pinion angle.
It's pinion angle VS transmission output shaft angle. Transmission output shaft angle is also the same as the engine crankshaft/front damper angle.
Period, end of story. No way easier to show/understand why then to watch this video.
Try not to take everything so literally. Just because someone suggests it's time to deal with the Elephant in the room doesn't mean you should break out the peanuts.
HALTECH (Elite 2500 plus REM)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - [email protected]
Topfun99 is offline   Reply With Quote
Old 09-09-2019, 05:04 PM   #5
novafornow
novafornow's Avatar
Always give the same answer. Take the shaft and hide it until done. THE BEST ADVISE that I got when building my own tube chassis.
novafornow is offline   Reply With Quote
Old 09-09-2019, 09:11 PM   #6
nostalgiaSS
nostalgiaSS's Avatar
Yep. That video is wrong. All that is being measured is the rear operating angle. The operating angle is not the same as what is commonly called pinion angle. Leave the driveshaft out of it unless you want to make sure you don't have excessive operating angle like one might find in a lifted truck.
nostalgiaSS is online now   Reply With Quote
Old 09-09-2019, 11:15 PM   #7
LLLosingit
Unless you're driving a lifted vehicle driveshaft working angle is doesn't matter.
LLLosingit is offline   Reply With Quote
Old 09-20-2019, 08:34 AM   #8
Third Gen Racer
Third Gen Racer's Avatar
https://youtu.be/Hr62W_BgznM
And NEVER run brake lines in the driveshaft tunnel.
Third Gen Racer is offline   Reply With Quote
Old 09-20-2019, 12:46 PM   #9
Eman85
Another incorrect example of pinion angle. The one thing done right was having the car on boxes. He did get the pinion yoke in the right position also.
I'm just glad I didn't have to watch the previous 30 episodes.
Eman85 is offline   Reply With Quote
Old 09-20-2019, 12:52 PM   #10
Topfun99
Topfun99's Avatar
You can measure/set the pinion angle with just the rear end in the air. As long as the suspension of the car, primarily the rear end, is close to the "normal" loaded position, the pinion angle won't change significantly.
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 09-20-2019, 02:54 PM   #11
Boosted Bullet
Boosted Bullet's Avatar
I'm posting this just to be silly,
Boosted Bullet is offline   Reply With Quote
Old 09-20-2019, 05:17 PM   #12
https://www.youtube.com/watch?v=Yss6Uf3AwNM
The driveshaft on that car is probably at the same angle as the crank shaft .
I got my truck set up like that . My driveshaft and crank shaft are within .5 degree .
Old 09-21-2019, 12:25 AM   #13
Farthole
Boosted to funny. Take the drive staff off and hind it in the corner. I have heard it all now. WOW
Farthole is offline   Reply With Quote
Old 09-21-2019, 06:23 PM   #14
tempname
Indeed that is the correct way to measure pinion angle. McAnnis is measuring operating angle technically.
tempname is online now   Reply With Quote
Old 09-21-2019, 07:00 PM   #15
Farthole
All. I Can say is google it. Race craft, smith race craft Jeffers chassis, Bickel chassis, and the hurndreds of other pro chassis builders are all wrong. And 3 guys on a furom are right. Lol. Never know thuo lmfao. Temp you are right,that's way we set it in the first place.
