dead head regulator for boost? - Yellow Bullet Forums
Old 09-05-2019, 03:22 AM   #1
Jebchevelle
Jebchevelle's Avatar
Default dead head regulator for boost?
I have a non return style fuel system on my car and have no way to install a return line. I was looking but have not found a non bypass regulator with boost reference port, any one know of a company that makes a 3.5-4psi dead head regulator that is boost referenced?
my pump is a internal bypass so does not need nor can it be setup with a return line. the reg might be but had problems running this style pump that way as it needs the pressure to steady flow.
78 malibu 402 eddy heads,174 B&M,th350,9" 3:70, Sniper EFI, 26X8.50-15" slicks.
96 chevy 1500, tow vehicle.
03 yz85 fun pit bike.
69 vw Baja 1679cc.
04 scion XB daily driver.
Jebchevelle is offline   Reply With Quote
Old 11-07-2019, 12:30 PM   #2
BigBlockRanger
BigBlockRanger's Avatar
Default Re: dead head regulator for boost?
RobbMc sells one I believe.
Drag Week 2011 - DD backmarker...
Drag Week 2012 - SR BB N/A runner-up
Drag Week 2014 - *kapooya*
RMRW 2018
BigBlockRanger is offline   Reply With Quote
Old 11-07-2019, 02:48 PM   #3
makinchips
makinchips's Avatar
Carbuerator ?
makinchips is offline   Reply With Quote
Old 11-08-2019, 01:57 PM   #4
julios
What psi does your pump bypass at? How much boost do you intend to run?
julios is offline   Reply With Quote
Old 11-09-2019, 08:23 AM   #5
forcd02
forcd02's Avatar
I ran one with a blowthru carb, been a while, but thought I used an Aeromotive reg. One thing I
noticed at times was I would get a spike when the pump was first turned on, then it went normal.
when your credit cards are max\'ed-call and raise the limits
forcd02 is offline   Reply With Quote
