Viking Shocks - Page 42 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 07-26-2019, 05:15 PM   #616
midniteta
midniteta's Avatar
Default Re: Viking Shocks
Originally Posted by fast89stang View Post
I have a buddy with me most of the time watching. We try to watch if it spins at the hit, or right after the hit to see what to do On rear shocks.
THis is spinning every time after the hit. Plants good then like tire bounces back up. Ran out of time the other night. I only have to more clicks tighter on compression on rear shocks to use.
midniteta is offline   Reply With Quote
Old 07-27-2019, 01:45 PM   #617
fast89stang
fast89stang's Avatar
Not sure if that's because your front is stopping so suddenly. But usually on mine I tighten compression if it spins after the hit(I think that's correct)
92 coupe 364, FTI cam, stock heads, stock shortblock. Pro Systems 950hp , Vic jr intake, BTE converter, turbo350 trans, 4.30 gear. [email protected] 1.24 60ft
fast89stang is offline   Reply With Quote
Old 07-29-2019, 08:34 AM   #618
midniteta
midniteta's Avatar
I have 2 more clicks I can go tighter on rear. Going to loosen front a tad and tighten rear next time out and try it again. Then maybe lower 2 step a little see if maybe its not as violent in rear
Old 07-29-2019, 08:51 AM   #619
sscamaro2485
The car looks way too stiff. Loosen the front on extension an tight on compression. rear should be full loose on a slick track. Lower your leave RPM as well. 4300 is pretty high. Your front springs might be shot as well the car is not working at all. How old are the tires?
sscamaro2485 is offline   Reply With Quote
Old 07-29-2019, 11:55 AM   #620
midniteta
midniteta's Avatar
All springs, and tires are new
