26" or 28" front runners - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 11-08-2019, 10:37 PM   #16
crazees#2
crazees#2's Avatar
Default Re: 26" or 28" front runners
26 is what's on my car in my avatar but you can't see them. Any smaller looks bad in my eyes, I do have a set of wheels with 5.50 Morosos but haven't ran them for several years.
crazees#2 is offline   Reply With Quote
Old 11-09-2019, 04:17 PM   #17
nuclearcobra
nuclearcobra's Avatar
Well this thread got me off my azz and i went out in the shop and took the 25'' hoosier's off the rims and put my 26'' MT sportsman's back on and i like it much better even tho i just added 10 lbs to the front , But then again i never noticed an ET change with the lighter tires.
nuclearcobra is offline   Reply With Quote
Old 11-09-2019, 04:44 PM   #18
engineguy
Quote:
Lighter front tires won't change ET by a measurable amount, however the taller front tire will result in additional roll-out which "should" result in lower ET.
Bill
SAE Member (29+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
Do what you can, with what you have, where you are.
- Theodore Roosevelt
engineguy is offline   Reply With Quote
Old 11-13-2019, 03:45 AM   #19
Smokin408
Launchin
I put the 26's on my car to change the instant center and help it keep the wheels on the ground.
Smokin408 is offline   Reply With Quote
Old 11-13-2019, 06:18 AM   #20
Bigtruckdrivah
FHRITP
26” on a 17” rim looks nice
Bigtruckdrivah is offline   Reply With Quote
Old 11-13-2019, 01:28 PM   #21
GTAShief
GTAShief's Avatar
Quote:
This is what I have. Was thinking 25, glad I didn't.
GTAShief is online now   Reply With Quote
Old 11-13-2019, 05:34 PM   #22
62 turbo conv
Launchin
62 turbo conv's Avatar
I have run 24,26,28 tires on the front of my nova. The problem I found if you go to different tracks the roll out could be different. Making harder to stage the car the same every time. With the 24 I feel you swim between the lights. I run 26 and have a much better consistent light. 3100 lbs cutting 00 lights. Have fun and be safe.
62 turbo conv is offline   Reply With Quote
Old 11-13-2019, 06:33 PM   #23
Rich_1028
Rich_1028's Avatar
Garage
26" front runners on mine
\/ \/ \/ Below in sig.
Rich Schneer
Dear lefties:
Make all the gun laws you want, I will chose which ones violate my oath to the US constitution.
My '80 Camaro
Rich_1028 is offline   Reply With Quote
Old 11-14-2019, 08:20 AM   #24
Bigtruckdrivah
FHRITP
Quote:
25” wouldn’t have been enough sidewall for me. Truck is kinda heavy and street drives a lot :/
Old 11-14-2019, 10:09 AM   #25
n2omike
n2omike's Avatar
Those of you thinking a taller tire makes you faster, are a bit off the mark. They are only fooling the clocks into starting later. If you were in a street race, it would make zero difference. In all reality, the taller tire would make you slower, as it is probably heavier, and that extra mass is further from the axis of rotation... adding rotational inertia.
If you need better reaction times, get the shorter tire. If you want your car to appear faster than it actually is... put a set of 30's on the front.
1966 Mustang
3300lbs w/driver pump gas street car
306 w/200hp plate 4-speed toploader
9.88 @ 135.67
n2omike is offline   Reply With Quote
Old 11-14-2019, 10:31 AM   #26
SST469C
Spooled up
SST469C's Avatar
I've always ran 28" front runners on my old truck. Anything else would look too small to me. As long as I can cut a light I'm good.
SST469C is offline   Reply With Quote
