20 degree BBC w/alcohol - Page 11 - Yellow Bullet Forums
Old 11-22-2019, 03:11 PM   #151
Coloradoracer
Coloradoracer's Avatar
Default Re: 20 degree BBC w/alcohol
Found my issue, flexplate bolts came loose. Converter is ok, crank is ok, but flexplate is done....so new flexplate and bolts and we'll give it another go!
Mark Goulette
Owner and driver, Livin' the Dream Racing Dragster
Speed kills but it's better than going slow!
www.livinthedreamracing.com
Authorized Amsoil Dealer
Coloradoracer is offline   Reply With Quote
Old 11-22-2019, 07:36 PM   #152
Rick!
Rick!'s Avatar
Did you drop the pan and inspect all the mains? Flexplate to crank or flexplate to TC bolts loosened?...
Rick! is online now   Reply With Quote
Old 11-23-2019, 09:30 AM   #153
Coloradoracer
Two piece pan, so dropped it and inspected everything. Crank to flexplate bolts loose, and one converter bolt. I usually loctite them in, but didn't this last time....Won't make the same mistake again...I did overrev it on the launch when the tires broke loose, it hit the limiter, but everything checks out except for that...No metal at all in the oil either, which is way better than I expected. Trans comes out today, new parts will be here Tuesday.....and the loctite....heheheh
Mark Goulette
Old 11-23-2019, 10:16 AM   #154
inferno camaro
inferno camaro's Avatar
Thumbs up Re: 20 degree BBC w/alcohol
Always sucks to have a break down but this is music to your ears when you find something simple.
inferno camaro is offline   Reply With Quote
Old 11-23-2019, 10:38 AM   #155
Coloradoracer
Tell me about it....I had already planned for the worst....this was a VERY pleasant surprise!!!
Mark Goulette
Old 11-24-2019, 12:22 PM   #156
Pascal
Pascal's Avatar
Wow very lucky break! Glad it was something very easily fixable.
Pascal
www.LecompteRacingEngines.com
cell: 248-703-8505
Dealer for:
Callies
Cometic Gaskets
Comp Cams
DART
Diamond Pistons
Morel lifters
Quick Fuel Technology
PAC springs
PSI Springs
RFD Heads
T&D Machines
Trend Pushrods
Pascal is offline   Reply With Quote
Old 11-24-2019, 12:42 PM   #157
Coloradoracer
Me too.......
Mark Goulette
Old 11-27-2019, 05:53 PM   #158
IMSHOT
TEAM CARB
IMSHOT's Avatar
Updates?
Baller on a budget..........
IMSHOT is offline   Reply With Quote
Old 11-27-2019, 09:04 PM   #159
Coloradoracer
Originally Posted by IMSHOT View Post
Updates?
Yes, just been busy with stuff. Car is fixed and running again, but not sure when I can get to the track to test. I didn't see any published test dates between now and Christmas, plus I'm going to be busy with work and some travel until then...hoping to hit the track asap in jan though....sometimes that's just how it works out.
Mark Goulette
