Turbo Tuning on Methanol Advice - Page 3 - Yellow Bullet Forums
Old 07-16-2019, 02:02 PM   #31
sleeperstang
sleeperstang's Avatar
Default Re: Turbo Tuning on Methanol Advice
While 220lb injectors seem small, when they are run at 90psi base pressure, they flow closer to 320lb. I personally have gone 7.50 at 180mph at 2700lbs with 220 Siemens deka and 90 psi base. My good friend has a x275 legal car that had a borg s480 cast wheel that went 4.80s at 150mph using a single set of 220lbs on batch fire with a sbf and XFI tuning to the leanest hole (thereby making the other holes a bit richer than they needed to be) .... I will caution this, the brushless fuel pump (or any electric pump for that matter) is not gonna get the job done. It’s belt drive/cable drive/or cam drive mechanical territory ....
Outlaw 10.5
1963 Tommy Mauney Corvette
393ci SBC, 23deg AFR 220cc, 118mm precision turbo, Holley Dominator EFI, on methanol.
Baddest 23 Deg SBC on the planet
1.00 60ft
[email protected] 180.75mph
West Coast Outlaw 10.5 legal trim
sleeperstang is offline   Reply With Quote
Old 07-16-2019, 02:22 PM   #32
Topfun99
Topfun99's Avatar
Location: Temporarily Away, Check Back Later For Updates
Originally Posted by sleeperstang View Post
While 220lb injectors seem small, when they are run at 90psi base pressure, they flow closer to 320lb. I personally have gone 7.50 at 180mph at 2700lbs with 220 Siemens deka and 90 psi base. My good friend has a x275 legal car that had a borg s480 cast wheel that went 4.80s at 150mph using a single set of 220lbs on batch fire with a sbf and XFI tuning to the leanest hole (thereby making the other holes a bit richer than they needed to be) .... I will caution this, the brushless fuel pump (or any electric pump for that matter) is not gonna get the job done. Itís belt drive/cable drive/or cam drive mechanical territory ....
Absolutely correct. Aeromotive's graph showing fuel flow vs. voltage for the Pro Pump STOPS at 80 psi. I'm not sure they could even dead head much past 90 psi.
I was using 2 Aeromotive Pro Pumps when I ran the methanol but only was using 45 psi base pressure. Those 2 pumps combined were probably just enough to keep up.
Try not to take everything so literally. Just because someone suggests it's time to deal with the Elephant in the room doesn't mean you should break out the peanuts.
HALTECH (Elite 2500 plus REM)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - [email protected]
Topfun99 is offline   Reply With Quote
Old 07-17-2019, 11:36 AM   #33
RonSSNova
RonSSNova's Avatar
Originally Posted by michaeld View Post
THIS.. 220 are on the small side for meth with boost
Especially with half the pump dead.
Iíve confirmed this, now need to talk with Holley.
The pump placement was horrible. Nearly above the top of the fuel cell. Iíll be re-engineering that to be correct with the pump at sump level. It will be awhile before I get back to tuning.
69 Nova 5.3 S476 Billet ([email protected])
2000 C5 10.99 @ 124 LS1
RonSSNova is offline   Reply With Quote
Old 07-19-2019, 03:17 PM   #34
RonSSNova
RonSSNova's Avatar
Holley won't repair the pump. I took it apart, corroded inside. Something got in the screw on one side.
So after all the hassles with this car.....blowing trans fluid out, slick going flat during a pull and now the FP dead, time to rethink.
Going to go to E85. Aeromotive brushless pump, re-do the fuel system.
Just a few pulls on the dyno the methanol polluted the oil. And polluted my brain.
I'm thinking methanol isn't for girls.
Where is my dress...…..
Ron
Old 07-19-2019, 04:45 PM   #35
TurboII
TurboII's Avatar
Evidently not, I love it and wouldn't run anything else in an engine I am really going to lean on. I have never had any issues with methanol and been running the same pump, regulator, Deka 220pph injectors for over 8yrs. VP M1 with their lube and I don't drain the system ever. Cap the vent and that's it. Waterman Little Bertha with their cable drive coming off the back of the dry sump pump.
Leader of the Methanol Mulisha
KINETIC RACECRAFT
"Turning your potential into motion"
Dealer for: Haltech EFI, Billet Atomizer Injectors, ProTorque Converters
Coming Soon - 6000HP Mainline Pro Hub Dyno
Manifold EFI conversions, Fuel Hoop installation, Dry Deck Conversions, LS/LSX 1/2" Stud Conversions
Custom crimped AN hoses
"He who is without oil shall throw the first rod."
-Compressions 11.5:1
TurboII is offline   Reply With Quote
Old 07-19-2019, 05:50 PM   #36
Topfun99
Topfun99's Avatar
I agree with everything you wrote.
But....
It's easy for methanol to absorb water especially in humid environments. I had problems with this and yes, some of it was my own fault. I didn't use sealed 5 gallon drums of it and let it get exposed too much to humid air while handling it. When I first tested some batches with a hydrometer I could tell it was already borderline "bad" from water contamination. After using it for approximately a year I stopped and went back to my only other option at the time - race gas. A month later I was doing a fuel pump test and could tell something was wrong. Turns out my pump inlet filters were clogged with chalky residue and the housings terribly corroded.
I never had a problem with contaminating the oil though. The methanol was only used with my secondary injectors while under boost. Otherwise the engine ran on gas which kept it hot eliminated the problems with methanol idling and during light throttle.
If I ever try using it again I will be more careful with the purity of the methanol I use.
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 07-19-2019, 07:43 PM   #37
camarols1
camarols1's Avatar
I agree with Brian.
With what little time I have spent tuning mine, I'm loving it.
Half a dozen back to back 500ft test hits on the street and the coolant temperature moves 3 degrees....lol
The key is keeping it lean and mean out of boost to avoid shitting up the oil.
A dual fuel setup makes this aspect a piece of cake.
Top fun inspired my setup, and while it is not cheap or easy, it works flawlessly.
79 Camaro 6.0 LSA heads, Twin borg s366's
9.125 @ 148.35 - best pass so far - 22lb boost
1.301 best 60FT ...getting there !!!
http://m.youtube.com/user/jimnorman74
camarols1 is offline   Reply With Quote
Old 07-19-2019, 09:18 PM   #38
RonSSNova
RonSSNova's Avatar
My bitch wasn't mainly about the fuel. I'm learning a new FI setup, and vaulted to a fuel I'm unfamiliar with.
On a car far from ready for prime time.
Were it tuned nicely on race fuel or E85, everything working, sure would have been easier.
Pump was DOA. Worked ok until I richened the fuel.
When I took it apart, there were chunks of corrosion throughout it. Thankfully there was a post filter.
I did tune idle and part throttle lean, 6.2 AFR.
As far as temps, well the radiator/fan even with our dyno fan couldn't keep it below 210. Although it took forever to warm up to 170 or so.
Appreciate the sidebars, always ok with me!
Ron
Old 07-19-2019, 09:34 PM   #39
camarols1
camarols1's Avatar
Yeah, you were given the task of making chicken soup out of chicken shit.....
Roughing in the tune on gas or corn is a good idea as a baseline.
Good luck getting it all sorted out.
A belt or cable pump is essential for M1.
Old 07-19-2019, 10:29 PM   #40
DHR Darren
OG Member since 9/7/06
DHR Darren's Avatar
Ron,
That sounds like a complete botched combo that they put together and threw in your lap Ron. When I built Mable the little 63 Chevy to its was very simple once I figured out the EFI system itself.
If you can't find your welfare check, try looking under your work boots.
DHR Darren is offline   Reply With Quote
Old 07-19-2019, 10:38 PM   #41
Wabash Cannonball
The Liquor Makes Me Think
Wabash Cannonball's Avatar
Never had a problem with M1 sitting in the injectors all season?
------Front Sight Squeeze
*All my posts are hypothetical jokes*
Wabash Cannonball is offline   Reply With Quote
Old 07-19-2019, 10:49 PM   #42
DHR Darren
DHR Darren's Avatar
You have to use the VP lube or else you will have corrosion problems for sure.
Old 07-20-2019, 11:29 AM   #43
sleeperstang
I think the most important thing is to drain the lines and spray wd40 in them any time your gonna let things sit while the car can’t run. If it’s capable of running, then it’s nothing more than a simple fire up every couple weeks and your good ... that’s all we do, and 7yrs without issues ...
Outlaw 10.5
1.00 60ft
Old 07-20-2019, 12:31 PM   #44
RonSSNova
RonSSNova's Avatar
Thanks guys. I really want to see this become successful for our customer. Probably should have taken it, made a list of things to fix then brought it back after.
It will all be good in the end.
I have a list BTW......and it's long!
When I was testing the fuel pump, the switch is in the drivers compartment. So I thought, gee I'll just use the master cutoff switch at the back of the car. Well, it doesn't shut off the fuel pump...….
I'm spending time getting to know the customer. I think it's important.
Anyway, Darren, hope we can run into each other in person some time soon.
Ron
Old 07-20-2019, 08:37 PM   #45
DHR Darren
DHR Darren's Avatar
Ron,
We are taking the 55 to the good guys drags next Friday. Are you going to come up for them?
