Using grid and rpm window switch - Yellow Bullet Forums
Old 06-29-2019, 03:45 PM   #1
slowstang
slowstang's Avatar
Default Using grid and rpm window switch
I have a 7al2 and a grid controller.leesh progressive controller.the grid brown and white wire is for the rpm window function applying a 2 amp ground.where is it best to hook up the brown and white wire?
slowstang is offline   Reply With Quote
Old 06-29-2019, 03:53 PM   #2
slowstang
slowstang's Avatar
Wanting the rpm switch function to turn off nitrous if rpm suddenly jumps.driveline failure etc.
Old 07-09-2019, 12:59 AM   #3
martincillo65
Did u find out how? Ide like to do thesame thanx
martincillo65 is offline   Reply With Quote
Old 07-09-2019, 09:56 AM   #4
ant447
How is your wot switch wired? With positive or ground? I have wired it to wot switch supping ground to nitrous relay. If you exceed rpm it opens ground circuit. If using positive then you can hook it up to your nitrous relay ground to supply ground at rpm window you want.
ant447 is offline   Reply With Quote
Old 07-09-2019, 04:30 PM   #5
martincillo65
Is it a must have on a n2o car ?
Old 07-10-2019, 11:43 AM   #6
ant447
Nice to have
Old 07-18-2019, 08:26 PM   #7
slowstang
slowstang's Avatar
Haven't had a chance to try and wire anything up yet.
