Small shot - no timing retard - Yellow Bullet Forums
Old 12-01-2019, 10:30 AM   #1
dart73
Default Small shot - no timing retard
Hello folks,
I'm going to try a small shot with a friend on a Dodge Dakota 2009 where we don't have option for a time retard.
A coleague said we could compensate this lack of timing retard with a coulder spark plug but I don't see a correlation between them.
We do timing retardingbecause nitrous increase burn speed avoiding the peak cilynder pressure right? How a colder spark can compensate that?!
Thanks and Br,
dart73 is offline   Reply With Quote
Old 12-01-2019, 11:26 AM   #2
Briansshop
Briansshop's Avatar
Default Re: Small shot - no timing retard
Thanks and Br,
Cold plug won't help. It's not a colder spark, but a cooler plug operating temp.
How small of a shot?
SBE 351W 10.26/134, 4280lbs
Briansshop is offline   Reply With Quote
Old 12-01-2019, 11:36 AM   #3
Wabash Cannonball
The Liquor Makes Me Think
Wabash Cannonball's Avatar
Is it on a stock tune?
------Front Sight Squeeze
*All my posts are hypothetical jokes*
Wabash Cannonball is online now   Reply With Quote
Old 12-01-2019, 08:41 PM   #4
dart73
Yes, stock tune. Max would be 125hp shot. No more than that. Br
Old 12-02-2019, 10:27 AM   #5
Induction-Solutions
Induction-Solutions's Avatar
I would get the option to manage timing..
Steve Johnson
www.InductionSolutions.com
http://www.facebook.com/#!/pages/Ind...06171102739096
815-341-8853 Cell
352-593-5900 Parts/Shop
Induction-Solutions is offline   Reply With Quote
Old 12-02-2019, 10:53 AM   #6
CorkyE
CorkyE's Avatar
You might get away with a 50hp shot, I certainly would not try 125 w/o retard.
79 Z-28 Bought new, honeymoon ride, still have same wife, same car.
CorkyE is online now   Reply With Quote
Old 12-02-2019, 03:06 PM   #7
Horndog
If you can't retard the timing, are you able to enrich the fuel?
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
“And if all others accepted the lie which the Party imposed—if all records told the same tale—then the lie passed into history and became truth." -George Orwell
I really don't know which is worse ..... all of DOTARD's lies all the time, or all the trumphumpers lapping them up with not even giving them a critical thought
Horndog is offline   Reply With Quote
Old 12-03-2019, 05:03 AM   #8
John Anthony
This is coil on plug with coils that have a two pin connector? If so, you can use the J&S Vampire unit.
In addition to nitrous retard, it also features individual cylinder knock retard. I just upgraded the design and incorporated an adjustable rev limiter. You can set the rev limiter to arm with either 12v or ground, so you use it as a staging limit.
John Anthony is offline   Reply With Quote
Old 12-03-2019, 05:59 AM   #9
John Anthony
Looking at the coils on rockauto dotcom, it looks like this is waste spark. Four coils, two plug wires per coil? The Vampire controls one coil per channel, so the four channel version is all you need.
To install, no wires are cut or intercepted. The Vampire has a "control wire" for each coil, that connects to the coil negative wire. It retards by extending the dwell pulse. The unit senses when the stock ignition is firing the coil. If it wants to retard, it instantly grounds THAT coil, preventing the spark. The coil is released to fire at the end of the retard angle.
The stock ignition does most of the work. The Vampire goes active only when retarding or rev limiting. You can disconnect the unit while the engine is running, and it continues running on the stock ignition. No bypass plugs or tach adapters are required.
The rev limiter is set by a knob on the front panel. The associated test point is calibrated in volts/thousand RPM. Resolution is 50 RPM. For example, if you want to stage at 3250 RPM, set the knob so the test point reads 3.25v.
Old 12-03-2019, 06:09 AM   #10
John Anthony
The retard is proportional to the amount set by the knob on the front panel and a 0-5v signal. The range is 0-16° retard.
For example, with the knob at midrange, you would get 8° retard when anything over 5v is applied to the input pin. Apply 2.5v and you would get 4° retard.
Old 12-03-2019, 06:39 AM   #11
John Anthony
The rev limiter has a soft touch, skipping every third cylinder at the selected limit, resulting in a 33% drop in power. If the engine goes 100 RPM above the limit, it skips as many cylinders as necessary.
For six cylinder, this strategy would result in misfiring the same two plugs, so the program fires three, skips two, etc, resulting in a 40% drop in power.
The number of cylinders is set by two mode switches on the front panel.
Old 12-03-2019, 06:52 AM   #12
John Anthony
The unit includes an onboard 2.5 bar MAP sensor for boost retard or vacuum advance. The Boost Retard "Start" knob sets at what psi boost retard starts (adjustable from 0-10 psi), while the "Rate" knobs sets the amount of retard per psi above the start point (adjustable from 0-2° retard per psi).
Old 12-03-2019, 07:18 AM   #13
dart73
Yes, it´s a wet kit. Single Nozzle.
Old 12-03-2019, 07:52 AM   #14
TS1955
TS1955's Avatar
What is the actual total timing of the motor now? And how efficient is the chamber?
TS1955
TS1955 is offline   Reply With Quote
Old Today, 06:49 PM   #15
bottlefed1
bottlefed1's Avatar
Most any modern engine will have the timing set close to optimal from the factory....This means that it will hurt itself quickly if you add nitrous.
Other methods of trying to slow combustion (cooler/fatter) are a patch, retard the timing to the proper level for the amount of nitrous used and your bank account (and ET) will thank you.
bottlefed1 is offline   Reply With Quote
