Wastegate with S trim - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged
Old 11-07-2019, 03:55 PM   #1
140HORSE
140HORSE's Avatar
Default Wastegate with S trim
So this may be a dumb question, but has anyone ever put a wastegate on the charge pipe? My thoughts were to pulley the blower to max speed with a 2.95 upper with my 6.87 lower and then just set the wastegate to 11psi... From swapping pulleys previously I know that the 3.33 makes 11psi @6000, 3.12 14psi @6000, so a 2.95 should make 16+ and 11psi at about 4200. I could theoretically make more boost lower in the RPM range without the worry of turning my stock block into scrap metal...
"From as early as I can remember, I never did anything that I didn't want to do... because what was expected and what was normal just seemed fucking boring" Jason Huh
140HORSE is offline   Reply With Quote
Old 11-07-2019, 03:59 PM   #2
naynay
naynay's Avatar
Default Re: Wastegate with S trim
pic of the charge pipe? placement is crucial.
63 c10 - bagged - slow
wtb gbody roller
naynay is offline   Reply With Quote
Old 11-07-2019, 04:09 PM   #3
140HORSE
140HORSE's Avatar
Typical Foxbody kit with an intercooler
Old 11-07-2019, 04:10 PM   #4
140HORSE
140HORSE's Avatar
[IMG][/IMG]
Old 11-07-2019, 05:51 PM   #5
Chuck u Farley M.D.
Medium Pimpin!
Chuck u Farley M.D.'s Avatar
Location: Hangin @ Sea shanties & wet panties. Baltimore
Job Spetter was doing this years ago and had great success, on a intercooled centrifugal setup he put the wastegate right at the discharge side of the intercooler.
Posted Via Dialup
Chuck u Farley M.D. is offline   Reply With Quote
Old 11-07-2019, 06:33 PM   #6
naynay
naynay's Avatar
thats what i was thinking, you would need to refabricate the peice with vbands and hard bends, and put it at the first bend.
wtb gbody roller
Old 11-08-2019, 09:17 PM   #7
joemondo
Just find a block.
joemondo is offline   Reply With Quote
Old 11-09-2019, 02:12 PM   #8
TurboII
TurboII's Avatar
It can be very hard on the compressor wheel depending on how much pressure it dumps at what rpm.
Leader of the Methanol Mulisha
KINETIC RACECRAFT
"Turning your potential into motion"
Dealer for: Haltech EFI, Billet Atomizer Injectors, ProTorque Converters
Coming Soon - 6000HP Mainline Pro Hub Dyno
Manifold EFI conversions, Fuel Hoop installation, Dry Deck Conversions, LS/LSX 1/2" Stud Conversions
Custom crimped AN hoses
"He who is without oil shall throw the first rod."
-Compressions 11.5:1
TurboII is offline   Reply With Quote
Old 11-09-2019, 05:53 PM   #9
stevieturbo
Waste of time, just spin it hard and send it.
blow me
https://www.youtube.com/watch?v=Ss_c7fML3rw
What the f****
stevieturbo is offline   Reply With Quote
Old 11-09-2019, 07:30 PM   #10
Wabash Cannonball
The Liquor Makes Me Think
Wabash Cannonball's Avatar
Wouldnt an inlet restrictor be safer?
------Front Sight Squeeze
*All my posts are hypothetical jokes*
Wabash Cannonball is offline   Reply With Quote
Old 11-09-2019, 09:57 PM   #11
Screwblower
Rpm kills stock blocks , boost kills rotators and head gaskets.
Put the 3.12 on , step up a ratio in the 8.8 and enjoy the car.
Screwblower is offline   Reply With Quote
Old 11-10-2019, 09:12 AM   #12
joemondo
I ran a T-Trim with cogs 73 bottom 32 top on my 92 lx when the car was new. Made 20psi with performer heads, I controlled the power level with low timing and good fuel for the track. Just drove the car easy on the street. Car ran 10.00 at 132 with a c-4 back in 96. Stock original block I sold later running.
Old 11-10-2019, 09:21 AM   #13
Screwblower
Cool sounding car.
Did you consider Vic Jr. heads?
Old 11-10-2019, 06:41 PM   #14
joemondo
Yes when I upgraded the block we replaced the heads with jr's and added the XX Trim with a glide. Still have the car now but has an 88mm Garret with 20,000 original miles.
Old 11-10-2019, 07:00 PM   #15
Screwblower
Sweeeeeettttt!
