4.6 Mod to TH400 swap. Block plate? - Yellow Bullet Forums
Old 11-08-2019, 01:38 PM   #1
cp463
cp463's Avatar
Default 4.6 Mod to TH400 swap. Block plate?
Do I need to run the stock 4.6 automatic block/spacer plate between the engine and transmission with a JW ultrabell and ATI flexplate w/crank spacer?
04' Mustang 4.6 4v twin 66mm
cp463 is offline   Reply With Quote
Old 11-08-2019, 01:53 PM   #2
Transmission Specialist
Hutch's Avatar
Default Re: 4.6 Mod to TH400 swap. Block plate?
It does help locate the starter but not necessary.
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
