nos launcher doesn't work - Yellow Bullet Forums
Old 05-26-2010, 12:01 PM   #1
orangejuiced91
orangejuiced91's Avatar
Default nos launcher doesn't work
I've tried changing the settings on this thing, over and over. Rpm, Map, timed. Changed grounds and can not get it to turn on the solenoids. I can get my purge to work.
orangejuiced91 is offline   Reply With Quote
Old 05-26-2010, 03:31 PM   #2
possessed1
possessed1's Avatar
Default Re: nos launcher doesn't work
I know this will suck for you,but it will help us understand your problem better .
Draw and post a diagram on how you wired the solenoids . It maybe the way you wired it ,unless you know it right ?
possessed1 is offline   Reply With Quote
Old 05-26-2010, 03:51 PM   #3
Monte Smith
The nitrous guy
Your post gives no info to help you with. Two things to check....are you SURE you have the correct ID number programmed in the box....second, you can't have a 0 in the map cutoff number, it won't work.
Monte
Monte Smith
Motorsports Technical Representative
Nitrous Oxide Systems
www.montesmithperformance.com
ph. 256-783-3418
Monte Smith is offline   Reply With Quote
Old 05-26-2010, 04:09 PM   #4
orangejuiced91
Map cut off is at 20psi. Yeah I have the correct ID number. I am using NX solenoids and I have both ground wires from the solenoids ran to the greenish blue wire of the controller. I have both hot wires ran to a continuous switch. I have the blue/white wire ran to a full throttle switch on the carb as a ground and the a good ground ran to the throttle switch. My purge is set up on the second stage side and works great. Any help would be great. Thanks in advance.
Old 05-26-2010, 08:44 PM   #5
big green
how do u change the pulse on the sol mine pulses the same real fast till it stops from 20% to 100
big green is offline   Reply With Quote
Old 05-26-2010, 08:48 PM   #6
Monte Smith
The nitrous guy
The hot wires are ran to a "continuous switch".......what kind of "switch" is this, can it handle 40 amps? NX solenoids draw a lot of amps, so the solenoids need to be powered by a quality relay.
Monte
Monte Smith
ph. 256-783-3418
Old 05-26-2010, 08:51 PM   #7
orangejuiced91
yeah my switch is kind of overkill it's the one that looks like a ford starter solenoid
Old 05-26-2010, 09:55 PM   #8
Leafswinger
If you are test it with the engine off or at idle, you need to set the RPM trigger to "0".
Leafswinger is offline   Reply With Quote
Old 05-26-2010, 09:57 PM   #9
orangejuiced91
yeah I've already tryed that. I'm lost
Old 05-26-2010, 10:04 PM   #10
Procrew
Procrew's Avatar
Does the solid white wire go to a 12v+ switch? Small black wire go to a ground away from the large black wire?
Procrew is offline   Reply With Quote
Old 05-26-2010, 10:09 PM   #11
580stang
580stang's Avatar
i don't want to sound bad but i had this problem. the solinoid was clicking but no power going through it check with a test light
580stang is offline   Reply With Quote
Old 05-26-2010, 10:10 PM   #12
Leafswinger
Are u activating with a WOT switch?
Old 05-26-2010, 10:39 PM   #13
orangejuiced91
I'm getting power to the solenoids. I ran my ground wires to my micro switch this past weekend and bypassed the controller and the nitrous worked.
Old 05-26-2010, 10:48 PM   #14
Doug F
Is the laptop or touchscreen indicate the solenoids should be on?
Doug F is offline   Reply With Quote
Old 05-26-2010, 10:57 PM   #15
orangejuiced91
the little green trigger light comes on the screen
