pic of holley system log - Page 3 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical
Old 05-01-2014, 07:33 AM   #31
Danny Cabral
Danny Cabral's Avatar
Default Re: pic of holley system log
Originally Posted by Dentfix View Post
LS Truck coils...4.5 ms Dwell Time.
Have you tried increasing the Dwell Time to 5.0 msec?
Coils are grounded to valve cover bolt.
This is not good.
ECU power wires run to battery on ground side and cut off switch on positive side.
This is not good.
May God's Grace Bless You
New Holley Dominator ECU for sale every month. (Email me for my usual low price: d c f 1 5 0 @ c o m c a s t . n e t)
Danny Cabral is offline   Reply With Quote
Old 05-01-2014, 08:32 AM   #32
ernie's 5oh
ernie's 5oh's Avatar
the harness for the coils did you make it? And the power wire for the coils, how is that wired up? What gauge, any relays or fuses?
450 sbf for 2014 holley efi
IS 2 stage fogger
best 60' 1.12
Best 1/8 [email protected]
Best 1/4 [email protected]
PSP
Sam Vincent
Monte Smith
Steve Johnsons
ernie's 5oh is offline   Reply With Quote
Old 05-01-2014, 08:47 AM   #33
Dentfix
I ran the ecu power directly to the battery. It made no differance. I guess tonight I'll ground the coils directly to the heads and run an engine ground directly to the battery. At that point I'm out of ideas besides sending the box to holley to be tested?
Dentfix is offline   Reply With Quote
Old 05-02-2014, 12:28 AM   #34
Dentfix
After all this troubleshooting I think I finally found the problem in the tune. My inductive delay was somehow set to 1847 or something like that. No idea how it ever got that high, I don't remember ever adjusting at all when setting my ignition parameters up. I moved it to 120 and everything seems fine.
Old 05-02-2014, 01:29 AM   #35
cam406406
cam406406's Avatar
Always something stupid!!
And u wanted a carb back haha!
Now go destroy some streets!!!!!
cam406406 is offline   Reply With Quote
Old 05-02-2014, 05:15 AM   #36
Danny Cabral
No idea how it ever got that high. I don't remember ever adjusting at all, when setting my Ignition Parameters up.
That's because the Inductive Delay can't be "adjusted" when initially setting up the Ignition Parameters!
The Inductive Delay is checked by momentarily revving the engine (4000 RPM), while using a timing light.
Is this a random guess, or did you actually adjust it?
http://forums.holley.com/showthread....ing-Holley-EFI (Timing Synchronization)
Old 05-02-2014, 08:03 AM   #37
Dentfix
It was a random guess then I verified with a timing light that it was stable when revving
Old 05-02-2014, 09:17 AM   #38
1fast10
1fast10's Avatar
Ground your coils to something other than valve covers.
www.precisionfabandwire.com
https://m.facebook.com/precisionfabwire/
Leashelectronics.com dealer
Holley efi dealer
Injector dynamics dealer
Nickels performance
1fast10 is offline   Reply With Quote
Old 05-02-2014, 10:11 AM   #39
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
I've seen people do it and then hate that decision.
Mike Beck is offline   Reply With Quote
Old 05-02-2014, 10:23 AM   #40
Dentfix
I had a blow thru carb for years and I can make it work. Not as well as efi though, that's for sure. Then when you add the fact that a standalone meth wideband costs as much as an hp efi setup it wouldn't make sense.
