2 races 2 coil packs - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical
Old 07-09-2012, 07:09 PM   #1
634 Chevelle
634 Chevelle's Avatar
Default 2 races 2 coil packs
i went to 2nd race in 4 weeks and lost another coil pack, lost one at first race and one in 2nd race, coil packs are to holley dominator system and are just a little over a year old. I have them mounted on my valve covers, does anyone know if this could cause any problems from vibration not grounding properly. I have been replacing them with factory gm coils to get by and seems to run ok. any thoughts, thanks
'66 Chevelle, 3000#, 634 bbc
1.11 60ft
3.08 330ft
4.71 660ft at 153 mph
7.32 1320ft at 186 mph
634 Chevelle is offline   Reply With Quote
Old 07-09-2012, 07:58 PM   #2
cam406406
cam406406's Avatar
Default Re: 2 races 2 coil packs
Does the harness just plug into a gm ls coil What needs to be done to swap from a Holley coil to a replacement
cam406406 is offline   Reply With Quote
Old 07-09-2012, 08:47 PM   #3
634 Chevelle
No I am not using ls coil , using gm waste fire coil, Unbolting module from coil and replacing coil
1.11 60ft
3.08 330ft
Old 07-09-2012, 10:06 PM   #4
gary medders
gary medders's Avatar
I thought the Holleys looked very similar to the coils on a grand national.
Human nature- if your not with us your against us.
Originally Posted by arca54
the way of the world .....if I don't like it you shouldn't either!
gary medders is offline   Reply With Quote
Old 07-09-2012, 10:17 PM   #5
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
The coil itself is going bad but the module is still fine?
I never tried to take one apart myself. I have them in my car, but they are not mounted like yours, I put them inside the cowl.
Are they dying on you and you have no spark? How hot do they get mounted on the valve covers?
I made over 200 passes last year on mine, no issues at all with them.
Mike Beck is offline   Reply With Quote
Old 07-09-2012, 11:05 PM   #6
634 Chevelle
The coil quits sparking, the motor never gets hot, starting line is 100 degrees and finish line is 150 degrees , pull to line and pull back. Module seems fine , put on different coil and keep going
1.11 60ft
3.08 330ft
Old 07-09-2012, 11:25 PM   #7
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
Did you send either of the dead coils back to Holley to get checked?
I had some weak coils a few years ago but Holley swapped them for tested new coils. Car ran but the fumes at idle were god-awful nasty! Burned my eyes. Put new coil packs in and everything was fine after that. Holley started testing their coil packs after this, I wasn't the only one, but Holley took care of everything.
I'm curious if they were open or shorted. Not that it really matters, bad is bad! Are these coils the old GN stuff? I bet these are the same coils that my little S-10 has.
Old 07-09-2012, 11:41 PM   #8
634 Chevelle
Resistance on primary side was high and yes the coils on2.5 in your s-10 would be the same
1.11 60ft
3.08 330ft
Old 07-09-2012, 11:45 PM   #9
RegalRocket
RegalRocket's Avatar
Do you have a ground jumper for the covers?
The base of the coil pack is the ground return. You have an alum cover sitting on an insulating gasket grounded only by the bolts. Not optimal sometimes. Have a bad ground and the current finds other paths, bad paths that torch coils.
RegalRocket is offline   Reply With Quote
Old 07-10-2012, 12:55 PM   #10
634 Chevelle
thats what i was thinking also, was planning on running ground wires even if i found another problem, thanks
1.11 60ft
3.08 330ft
Old 03-28-2013, 05:30 AM   #11
Danny Cabral
Danny Cabral's Avatar
The DIS coil pack harness already has each coil grounded; jumped from each coil to engine ground/cylinder head.
http://www.holley.com/data/Products/.../199R10525.pdf (See wiring diagram - figure 3, page 6.)
The circuitry that drives the Holley waste-fire coils is potted in the base of each coil.
I'm not sure if these base modules can ruin the coils themselves. Just something else to consider.
https://www.yellowbullet.com/forum/sh...87#post4991587 (Additional waste-fire coil info.)
May God's Grace Bless You
New Holley Dominator ECU for sale every month. (Email me for my usual low price: d c f 1 5 0 @ c o m c a s t . n e t)
Danny Cabral is offline   Reply With Quote
Old 03-28-2013, 07:01 AM   #12
64duece
64duece's Avatar
What is your dwell time set to? Too much dwell can overheat the coil and cause failure.
EFI Sales, Installation and Tuning
Professional Wiring
Custom Fabrication & Turbo Systems
Visit us at mooreracecraft.com
609.820.5660 or [email protected]
64duece is offline   Reply With Quote
Old 03-28-2013, 08:58 AM   #13
bigd427w
Boss
bigd427w's Avatar
Call technical service ask for Travis or Tom and tell them the situation. they will test the coils, and replace if they are faulty due to a manufacturing defect. I would do it myself but I'm off 4-6 weeks. Had a shoulder surgery yesterday. - Derek
bigd427w is offline   Reply With Quote
Old 03-28-2013, 09:51 AM   #14
Doug F
The high current power to the coils are go though "spade" type connections between the coils and the base. On some early coils, the "tightness" of this connection may not have been tight enough. When you insert the coil into the base, check to see how much tension is on this connection. This was checked and corrected a while back.
Doug F is offline   Reply With Quote
Old 03-28-2013, 11:42 AM   #15
Matt Cramer
They appear to be either the coils that Electromotive developed for GM in the '80s and also used on their own ignition systems, or somebody's knock off of that design. A lot of coil manufacturers copied that style to have something for the GM guys to run.
Matt Cramer is offline   Reply With Quote
