Diesel fuel gelling up... even with addatives.... HELP! - Yellow Bullet Forums
Old 12-22-2008, 12:40 AM   #1
TuffEnuff
TuffEnuff's Avatar
Default Diesel fuel gelling up... even with addatives.... HELP!
I like the idea of Bio-diesel...but, it's crap in the winter. Around Chicago, almost all of the pumps have 10-20% bio in them.
I have noticed a lot of people having problems even when temps are only in the 30's
I've added a ton of the "911" stuff and it helps a little...but, my fuel filter keeps getting gelled and I have to warm it up with a hand torch to get moving again.
Any ideas on what to do? I'm about ready to add a gallon of methanol to try an get this stuff to thin out a bit.
Grudge racers check in! Support the RSD program by making a quick post and saying hello! ->www.rsdforums.net
Concert sound and lighting in the Chicago
area = www.tsaproductions.net
TuffEnuff is offline   Reply With Quote
Old 12-22-2008, 12:57 AM   #2
darrin gorham
Launchin
darrin gorham's Avatar
Default
I have a kenworth with a fuel heater in the fuel filter. you could put a drysump heater pad or wrap the fuel lines with heat tape and keep the block heater plugged in overnight... some thoughts
darrin gorham is offline   Reply With Quote
Old 12-22-2008, 01:17 AM   #3
TWO-TONS-OF-FUN
TWO-TONS-OF-FUN's Avatar
Default
check out arc heat for heaters
2007 Trailblazer SS
1999 Trans Am WS6
1965 Chevelle 300 sedan
1955 Chevy 210
TWO-TONS-OF-FUN is offline   Reply With Quote
Old 12-22-2008, 01:26 AM   #4
michev
Mike Walsh
michev's Avatar
Default
The reason they all have bio is,they get a tax break from the state.We use bio in all our work trucks because of this.In the winter every other fuel delivery is regular diesel to keep from gelling.You have to go to a regular truck stop to find non bio here.There is a roadranger on roosevelt road selling non bio for 2.52
michev is offline   Reply With Quote
Old 12-22-2008, 01:28 AM   #5
BOOST12
Spooled up
BOOST12's Avatar
Default
I haven't had any trouble with mine gelling up yet this winter but I noticed my MPG went to shit as soon as it got cold out! Maybe a Change of Fuel filters is in order....
BOOST12 is offline   Reply With Quote
Old 12-22-2008, 03:50 AM   #6
TuffEnuff
TuffEnuff's Avatar
Default
Quote:
This is happening while I'm driving.... it's really weird.
I'll be driving along for a while, no problem.... then, blaaaaaaaahhhhhh... I run out of power.
Then, it will still idle, sort of, and I heat the fuel filter with a torch for 1-2 mins. then it runs great for a few miles...then... Blaaaahhhhhh... it happens again.
BTW... this is on my 1986 Ford CL9000 semi-tractor. (with 110,000 original miles ) that has a Cummins NT400.
Is there heat wrap or a filter heater that runs on 12 volts?
Old 12-22-2008, 05:25 AM   #7
DRIVER2
Member
Pullin gears
Default
I own a kenworth as well & my semi jelled up a week ago in MN and we put it in the shop to sit 15 hrs before it would fire up. If I was you I would just NOT put that in my trk untill spring comes. Go out of your way to find a trk stop with the good fuel. I know there is two trk stops on I-80-94 at the IN-IL line!
DRIVER2 is offline   Reply With Quote
Old 12-22-2008, 05:53 AM   #8
64 hemi
64 hemi's Avatar
Default
if you are gonna use the crap bio fuel get some in tank artic fox heaters they work off you coolant lines i have em on my peterbilt both tanks btw but you can also cut the bio shit with #1 diesel
64 hemi is offline   Reply With Quote
Old 12-22-2008, 06:41 AM   #9
fatwax
fatwax's Avatar
Default
im in my driveway right now jelled up. started the truck, idled for a minute,stalled, ran out of fuel. changed the 2 filters but it wont stay running, tanks are slushy, put some additive in. any other ideas to get this thing going, never had one this bad before and aint makin no money sittin here at home again. btw its a semi truck im dealing with.
Eric W.
fatwax is offline   Reply With Quote
Old 12-22-2008, 07:07 AM   #10
Andamo
Launchin
Default
Couldn't you just add some kerosene to the tank and thin it out ? That's what we did to a friends diesel Olds a long time ago.
Andamo is offline   Reply With Quote
Old 12-22-2008, 07:09 AM   #11
fatwax
fatwax's Avatar
Default
going to by some more powerservice and a torpedo heater... winter sucks
Eric W.
Old 12-22-2008, 07:22 AM   #12
shooter
Pre-Staged
Default
Heard that!!! I must of lost 2 mpg in town....dont know what the phock they changed but it sucks. I know this much Speedway fuel sucks all year, I am at least 1-2 mpg worse on thier junk all the time. There is a Marathon on the corner of Boughton and 53 in Bolingbrook that always has the good shyt...my Duramax gets the best mileage on it.
shooter is offline   Reply With Quote
Old 12-22-2008, 07:48 AM   #13
mjmotorsports10
Launchin
mjmotorsports10's Avatar
Default
Quote:
Couldn't you just put your bare ass on the fuel tank?
2001 Mustang
NMRA SSO
Special thanks to Motorcity Motorsports
Procharger http://www.procharger.com/
UPR http://www.uprproducts.com/
Tim Bradham Racing Chassis http://www.tbcworks.com/
Total Seal Rings www.totalseal.com
Victory Valves
http://www.titaniumvalve.com/
Edelbrock http://edelbrock.com/
FAST http://www.fuelairspark.com/
Diamond http://www.diamondracing.net/
World http://www.worldcastings.com/
1.16 best 60 ft
4.75 @ 155.88 best
7.28 @ 197.61 mph
mjmotorsports10 is offline   Reply With Quote
Old 12-22-2008, 07:51 AM   #14
smallblocklx
smallblocklx's Avatar
Default
run RED, all I got to say
Just another 600hp diesel suv
Tuned by Eric
Wilson Diesel
Barder turbo service
Warren injectors
smallblocklx is offline   Reply With Quote
Old 12-22-2008, 07:59 AM   #15
Mod
Mod's Avatar
Default
Quote:
It's a couple thousand (around here) if you get caught,,but ya gotta do something to keep it running.
Stay away from the deep fryer fuels,,it'll only cost ya money in the long run.
All our 09 Freighliners with reman zero hrs Cummins ran the Powerservice white jug year round.
Experience is a difficult teacher, because you get the test first and the lesson afterwards.
Mod is offline   Reply With Quote
