mickeythompsontires.com;
Old 12-21-2008, 05:29 PM   #1
jim1320
Member
Pullin gears
jim1320's Avatar
Default 440cu Chi heads engine number!!!!
John has informed me that they have just dyno'd a new engine, the engine is a 440ci, 4' stroke/6" rod with a 4.185" bore, on top it has the new Kaase/CHI C400 heads and new C400 4500 intake, its 15:1 compression, cam is high 270* @ .05 intake/880 lift and 290/.800 lift exhaust, fuel was vp Q16.
Im informed it will be put into the dandy engines XW and hopefully raced sometime in January.
Certainly looks like it delivered the goods, and what a high end C build is capable of.
This off cleveland site in Aust. and 54 forum nice number for small block ford engine
Jim
70 Mach 1 10.17 1/4
90 Mustang 5.42@130mph
Crew Ricky Fox, Billy Barnes, Tommy Henrick
Mikes Mustang Shop , Mckeown Motorsport Engineering
X275 Drag Radial Class
jim1320 is offline   Reply With Quote
Old 12-21-2008, 06:22 PM   #2
87mike
Spooled up
87mike's Avatar
Default
That should get it done.
I'd love to build an engine with a set of CHI heads.
Maybe next season.
87mike is offline   Reply With Quote
Old 12-21-2008, 06:30 PM   #3
TomP
Default
A 4 FOOT stroke should make it a lot more than 440 cubes... or did you mean inches?
Impressive engine for sure. Is that a 9.2 deck?
TomP is offline   Reply With Quote
Old 12-21-2008, 07:27 PM   #4
jim1320
Member
Pullin gears
jim1320's Avatar
Default chi engines
Think its a 9.2 block ? 4.0 x 4.185 bore? Its not my , wish it was maybe for xmas. find its on the 54 forum cleveland. and more on the austraila forum for cleveland. Think going in 4 door falcon in aust. new heads from chi cnc porting .
Jim
70 Mach 1 10.17 1/4
Old 12-21-2008, 07:41 PM   #5
WAITNC
Launchin
WAITNC's Avatar
Default
john is a top bloke,i deal with him alot through my job and he has done a killer set of kaase heads for me, so if aspirated they make that kind of power imagine what 2 turbos on methanol can do
WAITNC is offline   Reply With Quote
Old 12-21-2008, 08:06 PM   #6
waterpog
Member
Pullin gears
waterpog's Avatar
Default
I just wish that the CHI heads didn't get lumped in with the Yates stuff as far as weight goes. I would think that on a 9.2" or 8.7" deck it would count as stock valve angle Cleveland.
waterpog is offline   Reply With Quote
Old 12-21-2008, 08:41 PM   #7
taxman
taxman's Avatar
Default
Quote:
Not with a 6" rod.
CHAINS WE CAN BELIEVE IN!
taxman is offline   Reply With Quote
Old 12-21-2008, 10:11 PM   #8
Tims86
Tims86's Avatar
Default
Will see what they do with a 106 in front of the CHI heads. They ran great with the F2 in front of it, and I never really got a good clean it with a solid tune up on it.
Tim Huspen
Carburated Boost
Authorized C&S Specialties Dealer (313) 530-1827
Special Thanks to:
Majerusgarage.com ,Teamzmotorsports.net, C&S Specialties.com, SuperNatural Turbo, UltimateConverter.com, Diamond Pistons (diamondracing.net), Extreme Velocity, Harris Oil
****Light Travels faster than sound. That's why some people appear bright until you hear them speak.****
Tims86 is offline   Reply With Quote
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
