add four bolt main caps to 351???????? - Yellow Bullet Forums
Old 11-06-2008, 07:29 PM   #1
meus31
Member
Pullin gears
Default add four bolt main caps to 351????????
just wondering if this worth anything as far as strength is concerned a good block is not in the budget for next year. i was just wondering if any of you guys have added these and have any bad or good things to say about it or what girdle do you recommend . the motor makes six hundred on its own and i would like to give it 150 squirt next year. any insight would be great. the block already has a little fill in the water jackets. thanks
meus31 is offline   Reply With Quote
Old 11-06-2008, 08:29 PM   #2
russxr67
Launchin
russxr67's Avatar
Default
W or C block?
russxr67 is offline   Reply With Quote
Old 11-06-2008, 09:50 PM   #3
meus31
Member
Pullin gears
Default
ita a 414 windsor , four inch stroke ,4.060 bore , scat crank 4340, la enterprises 6.300 rod. je pistons 11to1 solid roller pump gas motor with high ports and a super victor on it.
Old 11-06-2008, 09:57 PM   #4
Cale Aronson
Member
Pullin gears
Cale Aronson's Avatar
Default
You are probably ok with what you have at a low compression and a small dose of the spray will be fine, but if you can budget it, it is a good investment to make.
Actually a good affordable block to go with is the World Products Man O War block, because it has splayed billet caps which is very durable. If you are in need of any parts, shoot me a message or give me a call. I can usually give you plenty of options.
Shop 660-646-4553
Cell 816-390-0852
Email cale@gofastquick.com
Cale Aronson is offline   Reply With Quote
Old 11-07-2008, 12:09 AM   #5
Collinsautomotive
Default
By the time you splay the caps on most block plus the fill and girdle you could have bought a good World,dart,FRPP block.
Old 11-07-2008, 01:59 PM   #6
qwiknotch
ProStock Jackstand Winner
qwiknotch's Avatar
Default
whatr year block do you have.?
I have a 1969 351 block with ProGrams Billet Main Caps.
qwiknotch is offline   Reply With Quote
Old 11-07-2008, 03:40 PM   #7
meus31
Member
Pullin gears
Default
its a sixty nine block to my knowledge how hard are you getting after your motor qwik notch and how much did it cost to have them installed and line bored and honed
Old 11-07-2008, 08:46 PM   #8
qwiknotch
qwiknotch's Avatar
Default
It ended up being 13.5:1, with Brodix M1's, SuperVictor, hydraulic roller cam, 3200lbs with no transbrake on a shitty 9" et street.
It went 10.30@133 on nuts and 9.39@148 - 151 (if it spun a little bit) on a 225-250 plate unit.
Old 11-09-2008, 02:47 AM   #9
coupe performance
Spooled up
Default
You will be fine into the mid to low 8 sec. zone. I have built a bunch of these combo's and have NEVER had a block failure. Usually cost about 500-600 to buy the caps and get them installed. VERY cost effective.
Keeping it real....
coupe performance is offline   Reply With Quote
Old 11-09-2008, 10:48 AM   #10
pt race engines
Member
Pullin gears
pt race engines's Avatar
Talking Big Windsors
Quote:
I agree we have done a bunch of these big windsors that make over 700 fwhp N/A and some also use nitrous and are making over 1000hp. We have also never had ablock failure! But I think that if you are making over 700hp I think that the 4 bolt caps are a good idea. Also don`t use those junkie ass Red China caps as you will spend more getting them right then if you just used the Pro Gram caps to begin with. And the good blocks are 69-74 as these also have no problem going to 4.080 bore either. Dan
PT race engines/Cleveland Performance Center 423-479-3232
home of 3x NMRA Champion Brian Mitchell NMRA 8.38 @ 162.44
and the quickest NMRA Renegade nos car ever x2 Dan Rawls 8.315 @164.83
Current NMRA Renegade record holder 8.31@ 164.83
Special thanks to Brian Mitchell for loaning us wizard 1
Steve Johnson and the whole crew at INDUCTION SOLUTIONS.com
Jeremy at UPR products.com
Mark at Bullet Cams
Chris @ Ross Pistons
JP and the crew @ Performance Machine
pt race engines is offline   Reply With Quote
Old 11-09-2008, 12:51 PM   #11
Bellman
Bellman's Avatar
Default
I had considered adding 4 bolt caps to a 69 block I had.. But the main webbing under the out side bolts looked so thin.. That it seemed like drilling and tapping in that area would weaken the block.. Even if you only used 3/8 bolts on the out side..
I think the stock 2 bolt caps work just fine into the 700+ hp range..
86 Mustang GT
383 ci SBF
Garrett GTX5518r turbo
TH400 Tranny
Bellman is offline   Reply With Quote
Old 11-09-2008, 01:35 PM   #12
pt race engines
Member
Pullin gears
That is what we have always found! Also I have a set of Pro Gram caps for one of these blocks and they are half price if anybody needs some. Let me say this that we have never seen a problem with the webbing when installing any 4 bolt cap on a 69-74 windsor block. Dan
Mark at Bullet Cams
Old 11-09-2008, 02:14 PM   #13
qwiknotch
qwiknotch's Avatar
Default
I love the pro grams billet caps I have. really good looking piece.
My 69 block is at 4.125 and I have .165 - .170 between the walls still. Not sure how, this is some mystery Wednesday block that Ford made.
I think I may have to finish this engine now after reading all the fast low compression engines.
Hey grocery, why the 112 lobe? less overlap and some vacuum at idle? not sure why you wouldn't put a 105 -108 lobe in that thing since it is n/a
Old 11-09-2008, 02:54 PM   #14
pt race engines
Member
Pullin gears
I don`t think that is such a mystery,At one time we had access to a sonic checker and I checked about 12-14 early windsor blocks and everyone of them would go 4.080 and still have over .230-250 0n the major thrusts,so I stopped checking them and never worried about them at that bore size.And if it was me and those blocks where in a NA engine @4.125 that wouldn`t worry me either. Dan
Mark at Bullet Cams
Old 11-09-2008, 04:34 PM   #15
qwiknotch
qwiknotch's Avatar
Default
definitely a good thing to know, Dan, thanks.....
