9 1/2" thirdmember in 9" housing? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Rearends and Differentials - Mark Williams Enterprises
Old 10-08-2008, 06:53 AM   #1
oklaracer
Launchin
oklaracer's Avatar
Default 9 1/2" thirdmember in 9" housing?
Hello, I have a 9" housing with backbrace and 4-link. I was wondering if the 9 1/2" gears from Strange or MW will fint in the housing. I have done some research and cannot find an answer to this question.
Any information you guys would have on this would be greatly appreciated.
Also, what would be the benefit to useing a 9 1/2" versus a standard 9" gear.
Thanks Ron G.
www.MIDWESTSTREETCARS.com
Henson Racing Engines
Mickeys Chassis Works
Extreme Automatics
4290 lbs--- 6.00@118 in the 1/8th
https://www.facebook.com/WhiteRhino405
oklaracer is offline   Reply With Quote
Old 10-08-2008, 07:48 AM   #2
Jeff Chandler
Jeff Chandler's Avatar
Default
It will fit but you will have to notch the flange where the gasket sits a little so the gear can slide in. The best thing to do is order a gasket from Quartermax and use that as a template since it already has the notch in it.
Here's a link: http://www.quartermax.com/details.ph...D=357&catID=29
Jeff Chandler is offline   Reply With Quote
Old 10-08-2008, 09:35 AM   #3
Scott @ DLS
Member
Pullin gears
Scott @ DLS's Avatar
Default
The only time you would need to go to a 9.5" gear is if you are having 9" pro gear breaking. How much HP are you running?
Scott @ DLS is offline   Reply With Quote
Old 10-08-2008, 02:09 PM   #4
oklaracer
Launchin
oklaracer's Avatar
Default
I am setting up an 555ci BBC w/ an f3r....engine man said it would be around 1800-2000 hp.
Extreme Automatics
Old 10-08-2008, 02:11 PM   #5
oklaracer
Launchin
oklaracer's Avatar
Default
Thanks Jeff....
Extreme Automatics
Old 10-08-2008, 03:12 PM   #6
Scott @ DLS
Member
Pullin gears
Default
You will be fine with a 9" 35 spline pinion pro gear with your application. I know there are cars with well over 2300hp running a 9" gear.
Old 10-08-2008, 04:56 PM   #7
mrdragster1970
T/S 368E
mrdragster1970's Avatar
Default
The life cycle will be longer with the 9 1/2".
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 10-09-2008, 06:49 AM   #8
oklaracer
Launchin
oklaracer's Avatar
Default
Thanks guys....I appreciate it.....I think I have the info I need.
Extreme Automatics
Resources saved on this page: MySQL 1.14%
