Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 12-03-2006, 04:20 PM   #16
Butch Kemp
Butch Kemp's Avatar
Default
Ed I have a pro flite 3 speed from Pro trans or A1 same deal...I run to the stripe,then lift to let the engine come to idle real quick,then pull it into "clean" neutral almost at the exact same time......then reach for the ignition to keep plugs clean. Any fast N/A class everybody does the same thing..auto or stick..Pro stock,Comp,etc...................I put 100 runs on my aluminum rods this year......BK
Thanks to:
Dart
BES racing engines
Mickey Thompson tires and wheels
CFE heads/manifolds
Ultimate converter concepts
Gilsbach racecraft
Chandler racing components
Utp racecars
QC coatings
Butch Kemp is offline   Reply With Quote
Old 12-03-2006, 05:58 PM   #17
Gary Kubisch
Gary Kubisch's Avatar
Default
Quote:
Originally Posted by F. RIZZO
I will go out on a limb here & still suggest that clicking an engine after neutraling is VERY BAD. Even with the safe neutral(which I also offer in my turbo400s - W/Griner valve bodies) The whole idea w/safe neutral is to take the decceleration load off the engine, but shutting off the engine is still a very bad idea. This sends the transmission into the same circumstances that cause catastrophic failures to 3-speeds. The direct drum is accelerated to an overspeed that can cause explosions w/cast drums & clutch damage w/aluminum drums due to centrifugal apply. The same can be said for glides, only on a smaller scale. I will always tell my guys to ride it out in high gear or neutral w/safe neutral designs & NEVER shut off the engine.
Have a nice day
So,You're saying neutral is OK as long as you leave the Enigne running?
Seems like the Engine builders want you to put it in Neutral,And the Trans. Builders want you to leave it in high gear.
With my T-400 I've always decelarated in 3rd,But I wonder constantly if I should be going to neutral for the sake of my Aluminum Rods?
Gary Kubisch is offline   Reply With Quote
Old 12-03-2006, 06:47 PM   #18
Ed-vancedEngines
Location: Temp location. In a bed in McKinney, Tx. Call anytime on Cell 972-464-7400
Default
When mentioned weak rods, I am almost ashamed to mention what I ran in a 900 plus horsepower 461 cu in years ago, but they were only the factory Chevy 3/8 rod bolts with even pressed in wrist pins. Those were hooked to heavy TRW L2307AF pistons that I had done a lot of work on. At least the rods were polished with stronger bolts from Dorman. At that time I had never heard of ARP. Way back a long time ago. Anyway that is what I meant by weak rods in my post. No way do I consider aluminum rods to be weak. I use the GRP in many things.
Ed
Ed-vancedEngines is offline   Reply With Quote
Old 12-03-2006, 08:30 PM   #19
F. RIZZO
Member
Pullin gears
F. RIZZO's Avatar
Default NO !
Please re-read my post !
There are valve bodies out that have what is called a clean neutral - the shift pattern is P-N/R-1-2-3-N instead of P-R-N-1-2-3. There are shifters out specifically for this type of set up.
This is an entirely different valve body configuration all together. This design was done by Steve Griner quite a long time ago in hopes to help where guys w/3 speeds were being told by thier engine builders to neutral the engine after the stripe or were insisting on neutraling in the shut down.
Dave Klaput (F. RIZZO) aka A.J.
Proformance Racing Transmissions
(630)365-9483
http://proformanceracingtransmissions.com/
http://fastesttransmissions.com/
F. RIZZO is offline   Reply With Quote
Old 12-04-2006, 06:32 PM   #20
Butch Kemp
Butch Kemp's Avatar
Default
10-4 rizzo thanks for the explanation.
Thanks to:
Dart
BES racing engines
CFE heads/manifolds
Gilsbach racecraft
Utp racecars
QC coatings
Old 12-05-2006, 01:56 AM   #21
Hutch
Moderator
Hutch's Avatar
Default
Quote:
Originally Posted by Shelton_Barrs
Hutch,
What causes this to happen? Just curious, don't know much about transmissions and looking to learn a little more than what I have reading books...
Transmissions are supposed to be driven from the input shaft. When they are driven by the output shaft (neutralled) they will start to internally overspeed as the input shaft speed is reduced and reach maximum speed when the input shaft stops. The drum speeds will vary in different applications but there is a critical speed of some parts that I would rather not see tested. The end result is a trans explosion. Critical drum speeds can range from 9,000 rpm to 20,000 rpm depending on drum diameter and constructed material. It doesn't take long to reach those speeds when the multiplier of 2 to 2.5 X driveshaft speed is calculated.
Hope this helps explain things , Hutch
Hutch is offline   Reply With Quote
Old 12-05-2006, 07:59 PM   #22
Shelton_Barrs
Shelton_Barrs's Avatar
Default
Yes it does. Guess I will be changing my shut down procedure in the near future...
thanks,
Shelton
shelton@injectorsplus.com
Shelton_Barrs is offline   Reply With Quote
Old 12-05-2006, 08:42 PM   #23
Mike Thompson
275 DR
Mike Thompson's Avatar
Default
My question is how can you get a good plug reading if you leave the engine running for the entire time it takes to stop the car? I would think all that idle time would dirty the plug reading you are looking for.
Mike Thompson is offline   Reply With Quote
Old 12-06-2006, 01:11 AM   #24
slowfive0
Spooled up
Default
Subscribing.... C-4 rev man vb here.
Quote:
slowfive0 is offline   Reply With Quote
Old 12-06-2006, 01:51 AM   #25
Hutch
Moderator
Hutch's Avatar
Default
I have found that a plug reading is "burned" into the plug. The shutdown will only contribute a smal amount of soot if any. Brake clean will make the "soot" go away and whats left is the run.
Hutch
Old 12-06-2006, 01:45 PM   #26
John Lowe
Launchin
John Lowe's Avatar
Default
X2 I agree with Hutch , I have driven me car back to the pits and it only seems to effect the front part of the porcelain ,in most cases I'm still able to see the fuel ring.
It's a "CAMARO" thing you wouldn't understand
John Lowe is offline   Reply With Quote
Old 12-06-2006, 03:52 PM   #27
Butch Kemp
Butch Kemp's Avatar
Default
If your looking for every thing you have."hp" you can't !!! IMO
Thanks to:
Dart
BES racing engines
CFE heads/manifolds
Gilsbach racecraft
Utp racecars
QC coatings
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
