WTF am I looking at? - Page 4 - Yellow Bullet Forums
Old 02-27-2014, 08:26 PM   #46
IIbad4u
IIbad4u's Avatar
Default Re: WTF am I looking at?
Wouldn't it be quite costly to sleeve all the cylinders compared to another block.. I'm guessing this isn't any special block.
IIbad4u is offline   Reply With Quote
Old 02-27-2014, 09:10 PM   #47
Life's a Drag
Same User Name since 2013
Life's a Drag's Avatar
Quote:
Have you seen the labor rates in Mexico?
Why do you think GM builds their trucks there.
Quote:
Originally Posted by Bigtruckdrivah View Post
I am bitch made, and run my mouth writing checks my ass can't cash.
Quit wasting my time
Quote:
Originally Posted by Monty Mikho View Post
I'd rather drive a Ford!!!!
Quote:
Originally Posted by ratssass View Post
....i know,is LAD is not short.....average height.
Quote:
Originally Posted by Paul-ish View Post
Awesome. I love nutz in my mouth.
Life's a Drag is offline   Reply With Quote
Old 02-27-2014, 09:51 PM   #48
67 bird
67 bird's Avatar
Quote:
Originally Posted by 427Capri View Post
No the part that looks like a sleeve is lower than the deck surface my fingernail catches on the block.
It's where the white line is in this picture the line appears to be a parting line with the inner part being lower than the outer.
It's not sleeved. If on top that's just the gasket transfer...or honing scuff ..Again no sleeve IMO...
67 bird is offline   Reply With Quote
Old 02-27-2014, 09:58 PM   #49
Bigtruckdrivah
TEAM RIGHT CONVERTER
Jeep=GM?
Bigtruckdrivah is offline   Reply With Quote
Old 02-27-2014, 10:05 PM   #50
SMCT1
Launchin
They don't care, they have apes banging on shit all day long on those assembly lines. If he didn't mention jasper, I would venture to question it, but it's a reman so the chance of it being sleeved is 99 percent.
SMCT1 is offline   Reply With Quote
Old 02-27-2014, 10:22 PM   #51
mustangdad
mustangdad's Avatar
those motors are known for lifter bores cracking or even breaking.....look in all the lifter bores maybe water coming from there
Thanks for the help from all my family and friends/AA Performance,Eric Kenward,Kris Nelson Engines.TRZ Motorsports,Wilson Pro Flow
mustangdad is offline   Reply With Quote
Old 02-28-2014, 08:30 AM   #52
427Capri
Capri For Sale
427Capri's Avatar
I'm going to try to hit it with the mag and some powder after lunch. If I get a chance to do it I'll post up some pictures of what I got. I don't know wtf I didn't do that to start with. We were busy as hell and I just didn't think of it.
427Capri is offline   Reply With Quote
Old 02-28-2014, 08:40 AM   #53
jbi66
Member
Pullin gears
jbi66's Avatar
The 3.7 is problematic for everything. I tear them down all the time for coolant consumption issues. Never had any bottom end issues. Clean the block, re-do the heads with a mill job (also very common to have excessive pitting on valves), new Chryslers gaskets and head bolts with a few coats of copper spray on the gaskets, and your good to go. Also, take a very good look at the exhaust valve springs. The scuff against the steel oil deflector cup they sit in and by 150,000 they can be worn thin enough to cause the spring to break, kick out the follower, and your back to where you started. New guides and tensioners never hurts either. Did you hold the camshaft chains to the drive sprocket with two screw drivers or actually get the Chrysler timing tool? Good luck.
Ken Ewer-NMRA DR 10012 *Working On A Comeback Tour *
All wth a true mid frame, BWS500 88mm thanks to Reed at Work Turbochargers and Mike Curcio for the baddest set of Victor Jr's on the planet.
8.08@172 1.30 60 ft on BFG"s
5.003@144 1.22 60 ft on 275's
PSI Motorsports
THE leader in cylinder head and intake reairs and modifications as well as complete engine packages www.mcrp.us/
jbi66 is offline   Reply With Quote
Old 02-28-2014, 08:42 AM   #54
Collinsautomotive
I don't know one a single reman company that uses sleeves, to fucking time intensive.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 02-28-2014, 08:51 AM   #55
BIG(D)
FATTYS RACING
BIG(D)'s Avatar
Quote:
im with yah there!! ive got 1 in my shop now we are having to redo because of a dumbass reman company!!
IF YOU AINT SPRAYIN NUTTIN YOU AINT SAYIN NUTTIN
BIG(D) is offline   Reply With Quote
Old 02-28-2014, 08:54 AM   #56
jimmylauri
jimmylauri's Avatar
Quote:
Originally Posted by Retro 5.0 View Post
How can you install a sleeve from the crankcase?
You cant...but you could tell there is asleeve installed by looking up into the crankcase
71 Nova. 632 conv.head. Smith Race Craft Round tube clip. Split mono's. Asassin bars. Drag radial. #1 THRILL BILLY
jimmylauri is offline   Reply With Quote
Old 02-28-2014, 08:59 AM   #57
CharlieB
CharlieB's Avatar
It's an iron block with NO sleeves.
The 'ring' you are seeing is not consistant around all cyls, it fades out on the left side of the 4th picture. This 'line was caused by the steel fire ring of the head gasket 'working' rubbing against the iron, wearing it away and leaving this ring.
Milling the block will remove it but it looks like the pistons are already at zero deck height. Milling the block and using that head that you mentioned was already over surfaced .050 could be a problem.
What is factory com ratio? And valve clearances?
CharlieB is offline   Reply With Quote
Old 02-28-2014, 04:00 PM   #58
elle
Well?
elle is offline   Reply With Quote
Old 02-28-2014, 04:09 PM   #59
427Capri
Capri For Sale
427Capri's Avatar
Quote:
Originally Posted by elle View Post
Well?
Just sat down to write some tickets and might not get to it today. It's Friday and I know if I wait until quittin' time to push it in that everybody will pissin and moanin' about it being time to go home. I will post up pics of the mag test as soon as I can but it will probably be Monday now.
Old 02-28-2014, 04:57 PM   #60
427Capri
Capri For Sale
427Capri's Avatar
Well the nays have it. I made everybody mad but we pushed the Jeep in and the mag crack detector says that whatever I'm looking at it ain't sleeves. No need for pictures there's nothing to see.
Resources saved on this page: MySQL 1.03%
