Adding Midplate - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-26-2008, 06:18 PM   #1
.alex.
Launchin
.alex.'s Avatar
Default Adding Midplate
i am getting rid of my motor mounts in a few weeks, my converter was not setup for having a midplate so it has stock pads. is it ok for me to use the same thickness spacer on the pad as the mid plate to even everything out? or should i have the converter rebuilt with a new cover?
.alex. is offline   Reply With Quote
Old 08-26-2008, 07:10 PM   #2
Pwraddr
Launchin
Pwraddr's Avatar
Default
I have seen a company that makes a spacer between the crank and flexplate to eliminate this problem too! Probably cheaper to find this or have one made then to rework the converter.
1989 Notch
1992 Notch
Windsor/C4
Pwraddr is offline   Reply With Quote
Old 08-26-2008, 07:11 PM   #3
Gregaust
Member
Pullin gears
Default
Have just done that here with a T400 on a 383SB. Converter came with spacers to allow for the mid plate but it also needed a longer spigot on the centre to go into the crank. The centre spigot is pressed or screwed on.
Gregaust is offline   Reply With Quote
Old 08-26-2008, 07:15 PM   #4
.alex.
Launchin
.alex.'s Avatar
Default
Quote:
My flex plate has a locator that just slides in. if need be i can have a spacer made for it.
Old 08-26-2008, 10:23 PM   #5
Horndog
Default
Always prefer to weld the spacers to the mounting pads on the conv and pilot snout. Never lost a single one to date.
Yes, what ever thickness midplate you use, have the same amount added to the conv mounting pads and pilot snout.
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
Horndog is offline   Reply With Quote
Old 08-28-2008, 04:06 PM   #6
Rodrigues
Member
Pullin gears
Rodrigues's Avatar
Default
I machined spacers with a 7/16 ID and a 1" OD from 6061 and they worked great. Surprisingly the pilot still entered the crank a safe distance past the chamfer.
I know with neal chance if the pilot is too short they will send you a new one where you chisel it off and press the new one in.
Rodrigues is offline   Reply With Quote
Old 08-28-2008, 10:07 PM   #7
mrdragster1970
T/S 368E
mrdragster1970's Avatar
Default
No expert, but I've used grade 8 washers many many times when I didn't have time to have converter sent out for new pads welded on.
Maybe all of us have just been lucky?? Besides, even with the pads welded on, I've still had to use washers to get my 3/16".
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Resources saved on this page: MySQL 2.27%
