Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-26-2008, 01:54 PM   #1
TurboTA
Launchin
TurboTA's Avatar
Default
I have a turbo car sbc single turbo. The converter I have is way to tight on the bottom and only revs to 2400rpms on the brake. It will build five pounds of boost in like 10 secs on the brake but then it fights the converter and bogs down the motor untill it get to around 4000rpm. It leaves like a dog on 5 pounds.
I can get it to build 10 pounds of boost but then it is on the brake for 20 secs. It leaves good then though.
I have talked to my converter builder and he is going to restall the converter but I want go racing this weekend before the restall. If I stay on it that long (20secs for two or three passes with time in between to cool the trans and a fluid change) will I for sure burn up the trans. I am going to take fresh fluid out and change it once while I'm out there at the track and also put fresh fluid in before I go.
TurboTA is offline   Reply With Quote
Old 08-26-2008, 03:16 PM   #2
Horndog
Default
Hell of a gamble imo.
If you decide to gamble, be sure to also take with you a couple of those small squirel cage blowers that you can get at Home Depot or Lowes and a good generator. You'll need to blow ambient air on the trans pan and converter after each pass to take heat out.
Good luck.
Jim Horner
If you don't stand for something, you will follow anything...
Quoted by FDR
Government by organized money is just as dangerous as government by organized mob.
Quoted by JoDon
All you need to know is that there are no leaders left ... and that seems to apply to both politics and business. Politics has been dumbed down to high school level popularity contests, and business is looking for the next get rich quick scheme.
Horndog is offline   Reply With Quote
Old 08-26-2008, 03:39 PM   #3
mrdragster1970
A/PM 368E T/S 368E
mrdragster1970's Avatar
Default
As short as possible. As mentioned, you are going to repeatedly put a bunch of heat in the trans.
You are not doing the life of your fluid much of a favor. Good luck.
Used BBC-Dragrace-Trucks-Trailers 4 sale, personally listed items only. Parts For Sale
"Testing-Kind of boring, No N2O, only 1.10's 60 footers" Click here to see Video . Pictures of '70 1/2 Rally Sport Photo's
For my babies, we will always remember. In memory of Chris Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 08-26-2008, 05:43 PM   #4
JustinOlson
Launchin
Default
Throw a little 50 shot at it on the brake. That will get it spooled instantly
JustinOlson is offline   Reply With Quote
Old 08-27-2008, 01:52 AM   #5
Hutch
Moderator
Hutch's Avatar
Default
If you spool that car for 20 seconds then make a pass , you will have cooler output temperature of over 450 degrees and the trans will be ready to catch fire.
I would not recommend you even try this in fear of you catching on fire , wrecking the car and/or someone else.
Its not worth it just to make a pass.
Hutch
Hutch is offline   Reply With Quote
Old 08-27-2008, 04:34 AM   #6
RBPOWER
Spooled up
Default
my transmition man is on my case if I stay on the brake for more than five secs or so
Tallahasse, FL.
RBPOWER is offline   Reply With Quote
Old 08-27-2008, 02:59 PM   #7
WardRacing408
Member
Pullin gears
WardRacing408's Avatar
Default
Have you exhausted all efforts in attempt to build more boost quicker while staging the car...3 step, retarded timing, ?
WardRacing408 is online now   Reply With Quote
Old 08-27-2008, 03:20 PM   #8
Beyond
Member
Pullin gears
Beyond's Avatar
Default
Somebody post that pic of Turbo Todd's fireball at Tulsa to help make the point here...
Beyond is offline   Reply With Quote
Old 08-27-2008, 06:05 PM   #9
Horndog
Default
Was this a tranny oil fire ?
Jim Horner
Quoted by FDR
Quoted by JoDon
Old 08-27-2008, 06:12 PM   #10
Beyond
Member
Pullin gears
Beyond's Avatar
Default
Yup, a huge one - looked like a Jet Dragster when they are show boating..
Old 08-27-2008, 06:21 PM   #11
Horndog
Default
Damn !!!
Jim Horner
Quoted by FDR
Quoted by JoDon
Old 08-27-2008, 08:58 PM   #12
TwinT66
Pre-Staged
TwinT66's Avatar
Default
here is my video.I was way to long on the brake
:http://videos.streetfire.net/video/g...opi_128313.htm
Tony
TwinT66 is offline   Reply With Quote
Old 08-28-2008, 12:52 AM   #13
JUICED96Z
JUICED96Z's Avatar
Default
Tony
Loovvveedd the dune buggy HAHAHA
Yeah don't stay on the brake that long....
My car - I dunno George....
JUICED96Z is offline   Reply With Quote
Old 08-28-2008, 02:46 PM   #14
john@ATI
Pre-Staged
john@ATI's Avatar
Default
the converter is acting like a dyno loading the motor , only 1/3 of the fliud goes to the cooler. I have watched people set on the brake way too long trying to biuld boost and kill the converter. This is one of the reasons for a steel stator, the aluminum stator would melt out of the converter (aluminum melts at 1150). we only like to see 5 seconds on the converter. Back when small blocks ruled and big turbos were the norm. fires we every round once you had a steel stator you could set on the break till it melted the seal out of the front pump, then a big fire. now days with the tuning ability and the use of bigger cube motors biulding boost doesnt seem to be much of a problem.
john@ATI is offline   Reply With Quote
Old 08-28-2008, 02:54 PM   #15
Beyond
Member
Pullin gears
Beyond's Avatar
Default
Another thing to note is that regular ATF has a low flashpoint, between 320 and 375 degrees in most brands.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
