Old 07-06-2008, 10:38 AM   #1
Mark @ Meridian Tool
Mark @ Meridian Tool's Avatar
Default Aluminum Driveshafts
I have a 3-1/2" aluminum Inland Empire driveshaft on my Camaro.
565 ( 910 h.p. ), 400 turbo w/brake, 9.5 converter.
It has 1350 joints.
A couple buddies have expressed concern over this shaft.
Who thinks this shaft is going to twist up?
Or should I just keep an eye on the welds and go?
Mark @ Meridian Tool is offline   Reply With Quote
Old 07-06-2008, 11:21 AM   #2
footbraker
Default
Mark, got a 3 1/2" MMC aka Metal Matrix Composite aluminum driveshaft with 1350 joints from Denny's in my now 3870 lb. footbraked launched Chevelle that's been in service 10 years, upwards of 3000 passes, survived several broken transmission, rear gears, a broken crank and was worth .04 in ET behind my previous 468 that was making upwards of 750HP replaced this season by my 850HP 522!
http://www.youtube.com/watch?v=rbKYio6OvKM
footbraker is offline   Reply With Quote
Old 07-06-2008, 12:44 PM   #3
mrdragster1970
A/PM 368E T/S 368E
mrdragster1970's Avatar
Default
1050 HP, 3200 lbs ran a PST for several years. Painted a line & check the welds. Run double loops & check after every race.
Very small chance it will explode before it shows twist. Good luck.
Used BBC-Dragrace-Trucks-Trailers 4 sale, personally listed items only. Parts For Sale
"Testing-Kind of boring, No N2O, only 1.10's 60 footers" Click here to see Video . Pictures of '70 1/2 Rally Sport Photo's
For my babies, we will always remember. In memory of Chris Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 07-07-2008, 12:07 PM   #4
68Bird
68Bird's Avatar
Default
I had the same Inland Empire alum. shaft in my car and got rid of it shortly after installing the ProCharger. I felt it was on borrowed time and didn't want to risk tearing up the bottom of the car and possibly the trans when it let go. It had probably 400+ passes on it though at ~750hp, 3150#, 6000 converter, 1.30 60's. Went to a Denny's Nitrous Ready steel shaft that was 8# heavier and didn't notice any loss of performance.
Craig
'68 FIREBIRD True 10.5
4.99 @ 145, no bars
68Bird is offline   Reply With Quote
Old 07-07-2008, 04:10 PM   #5
Yullose
Launchin
Default
Any chance you are the same Meridian I delivered this car to ? In Bellingham, WA ?
Art Wittig / Reading, PA
Yullose is offline   Reply With Quote
Old 07-07-2008, 08:18 PM   #6
Default
Quote:
Sadly, no. That's badass!
Old 07-10-2008, 11:02 AM   #7
Bellman
Bellman's Avatar
Default
I understand that many Renegade racers run the stock Ford motorsport aluminum driveshaft, with the 1330 joints..
These car weigh around 3200 lbs, and run mid 8's at near 160..
86 Mustang GT
383 ci Dart block
Precision PT88 turbo
Turbo 400 Tranny
Bellman is offline   Reply With Quote
Old 07-10-2008, 04:53 PM   #8
Bam54
Burnout box
Bam54's Avatar
Default
We run a aluminum PST 3 1/2 at 3860lbs transbrake and around 700hp. Have alot of passes on it with no problems but we will see when we start using Nitrous. PST said it would be good up to 900hp.
Bam
"Take the Horse out of the barn and let her run baby run!!!!"
71 Mach 1
454ci Clevor
10.16 @ 134
3860lbs
Bam54 is offline   Reply With Quote
Old 07-15-2008, 06:53 PM   #9
8T9GT
Member
Pullin gears
8T9GT's Avatar
Default
Quote:
Bam
Take a look at this link before you get crazy with the HP. I know you're not making 1600hp but this shows what can happen when dealing with aluminum shafts.
http://videos.streetfire.net/video/1...yno_162750.htm
8T9GT is online now   Reply With Quote
Old 07-15-2008, 07:23 PM   #10
sleeper377
Launchin
sleeper377's Avatar
Default
link doesnt work...
Steven Lee
sleeper377 is offline   Reply With Quote
Old 07-15-2008, 08:24 PM   #11
8T9GT
Member
Pullin gears
8T9GT's Avatar
Default
o.k. try this
http://videos.streetfire.net/video/1...-on_162750.htm
Old 07-16-2008, 10:57 AM   #12
TwoFast4Lv
Nitrous Junky
TwoFast4Lv's Avatar
Default
Most of the guys wadding those up are running t56s and launching off the limiter. I ahev many of them broken that way.
I was running a stock GM shaft until recently no problems ;p)
TwoFast4Lv is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
