TH400 or 4L80E - Yellow Bullet Forums
Old 12-19-2013, 12:14 PM   #1
CameronVic
Wayyyyy more left in it!
CameronVic's Avatar
Default TH400 or 4L80E
I have a perfectly functioning TH400, car runs great with it. But the winter has got me thinking. I'm about to buy a 4L80E that lost reverse for $100. I took apart the TH400 and had an engineer buddy help me set all the tolerances and I assembled it so I'm not intimidated by taking it apart, I'm just indecisive.
I believe I could sell my whole TH400 setup (converter, pan, dip stick) for $1100-$1500. I got an 80E for $100. Converter for that would be $600-$900. Mod the crossmember, driveshaft, figure out how to make it a FMVB.
Anyone done the swap? And liked it? Hate it? How much weight did you add?
CameronVic is offline   Reply With Quote
Old 12-19-2013, 12:18 PM   #2
Danger D
Danger D's Avatar
Default Re: TH400 or 4L80E
43lbs more.
http://jakesperformance.com/site/mob...4L80E_FAQ.html
Do the 80. You can run a lower gear, and still cruise the highway with OD.
Only a warrior chooses pacifism; others are condemned to it.
-- Anon
What brings me spiritual peace.... is the fact that I know I can pull you limb from limb, but choose to walk away.
-- Danger D
Danger D is offline   Reply With Quote
Old 12-19-2013, 12:26 PM   #3
CameronVic
CameronVic's Avatar
I'm gonna keep the same rear gear. I won't be buying a wot lockup converter. I mainly just want better than 13mpg cruising and to be able I drive it further than bowling green and back with 22gallons of E85. Lol
Old 12-19-2013, 12:42 PM   #4
Danger D
Danger D's Avatar
I think you answered your own question there sir...
-- Anon
-- Danger D
Old 12-19-2013, 12:43 PM   #5
Bad Notch
Elite Member
Bad Notch's Avatar
If you have the fundage... OD is never a bad thing on a street car.
Bad Notch is offline   Reply With Quote
Old 12-19-2013, 12:46 PM   #6
fleming23
Spooled up
fleming23's Avatar
Don't forget about a shift controller unless you plan to manually shift the 80.
I still say 4L80 and never look back. Was the best thing I did to my car - right up until the point I swapped the 80 out for a 6 speed!
70 Chevelle
496 cu. in. "cruiser"
fleming23 is offline   Reply With Quote
Old 12-19-2013, 12:59 PM   #7
1989k1500
Just get a manual controller for the 80e from Jakes.
A buddy of mine has a 69 chevelle with a 724hp 507 big block and he switched from a 400 to an 80e with a Jakes manual controller and he said its the best thing he could have done, he loves it.
Working crew for a low 6 second LS Impala
1989k1500 is offline   Reply With Quote
Old 12-19-2013, 01:24 PM   #8
6.0Dakota
6.0Dakota's Avatar
Did the swap wired FMVB. Ratcheting it gets old after a while, but the trans was a beast after it was set-up. I used the transgo HD2, a edge 9 1/2" 3800 stall with a toggled lock-up.
6.0Dakota is offline   Reply With Quote
Old 12-19-2013, 01:26 PM   #9
double11
Spooled up
double11's Avatar
hell ya! an 80e for a 100 bux..
great core, even better if you know it only has reverse out
double11 is offline   Reply With Quote
Old 12-19-2013, 01:32 PM   #10
CameronVic
CameronVic's Avatar
I wonder what coulda caused reverse to go out? Could it be just a band? Or a solenoid?
I made a thread in the trans section about how to make it a FMVB. Jake posted and said he would give me a few tips (pretty freaking cool) so we'll see! I'm gonna buy it as soon as I get back in town. Can't wait to pull it apart!
Old 12-19-2013, 01:34 PM   #11
225digger
time to go racing yet ?
225digger's Avatar
im rebuilding a 80 right now , no reverse , the direct clutches where toast ....... everyone says the bands breaks , but the direct clutch in mine there is no fiber anymore all steels .
this is my 1st 80 build also and if you done a 400 there pretty easy , i bought the tools for the overdrive clutch assembly , have yet to put that part together , but everything else is normal stuff for a auto .
if i was you i would buy it .
225digger is offline   Reply With Quote
Old 12-19-2013, 01:41 PM   #12
Matt Hill
On the roller...
Matt Hill's Avatar
I'd get with Chris at Circle D, spend a couple more bucks and get a BADASS lockup converter. Make use of a key feature for $200 more than the proposed $900... In the long run you'll never notice that $200 is missing from your wallet and it's there if you want to lock her up and see how it goes...
www.matthillmotorsports.com | www.bigfuelinjectors.com
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter.
-Ernest Hemingway
Matt Hill is offline   Reply With Quote
Old 12-19-2013, 02:11 PM   #13
CameronVic
CameronVic's Avatar
This is great to hear. Thanks man! I'm gonna get it!
Quote:
i was thinking about their $850 it $900 one. I can assure you I'll never want to lock it WOT, so I would save the $200. I'm also considering a revmax or yank. I know people with all three of those and all have great results.
Old 12-19-2013, 02:24 PM   #14
spidergearsman
spidergearsman's Avatar
Th400 and 4l80 e share the same center support issues...no better automatic
spidergearsman is offline   Reply With Quote
Old 12-19-2013, 02:30 PM   #15
Ruger1022
Go with the 4l80 strong as hell with od you'll be happy.
Ruger1022 is offline   Reply With Quote
Resources saved on this page: MySQL 0.99%
