2013 dodge ram 1500 traction control removal? - Yellow Bullet Forums
Old 11-11-2013, 12:10 PM   #1
nosnerd
SomeWhat Jaded
nosnerd's Avatar
Default 2013 dodge ram 1500 traction control removal?
anyone buy a programmer that removes the traction control??
buddy got stuck in mud witha trailer and the truck kept on cutting out insread of powering thru..
major PITA
any help?
thanks
"IGNORANCE SHOULD BE FUCKIN' PAINFUL"
522/798hp + NOS/I.S plate
Doin' it on 315's at full weight, ladies
*ULTRA PERFORMANCE and FABRICATION *
www.DandDPerformance.ca
nosnerd is offline   Reply With Quote
Old 11-11-2013, 01:53 PM   #2
CPerry42
Launchin
CPerry42's Avatar
Default Re: 2013 dodge ram 1500 traction control removal?
I know when we use to run explorers on the lift to check for noises we would disconnect an abs sensor. Not sure if it would work or if you would want to go that routr
Chris Perry
84 Thunderbird Turbo Coupe.
83 Mustang GT 302 5 speed. 10 to 1 Compression
Quote:
Originally Posted by Honk if parts fall off View Post
"Posi" is just retard slang for a limited slip differential. The two are one in the same.
CPerry42 is offline   Reply With Quote
Old 11-11-2013, 01:57 PM   #3
BONER
My 2012 has a traction control button. The 13's don't?
Jesus Christ. STFU already.
BONER is offline   Reply With Quote
Old 11-11-2013, 02:01 PM   #4
boosteddakota
wife/gf thread MOD
boosteddakota's Avatar
Garage
Pull the abs fuse out and youll be alset
boosteddakota is offline   Reply With Quote
Old 11-11-2013, 02:05 PM   #5
Luxy72
Launchin
Luxy72's Avatar
My 13 has a VSC button to turn it off right in the middle of the dash under the radio.
Luxy72 is offline   Reply With Quote
Resources saved on this page: MySQL 2.35%
