800hp 509 bbc - Yellow Bullet Forums
Old 09-17-2013, 01:24 PM   #1
rreistino7
Member
Pullin gears
rreistino7's Avatar
Default 800hp 509 bbc
Looking to build a 509 that will make 800-850hp right now I have a dart big m Callie's 4in stroke crank and a set of Canfield 310 heads that have had some work right now heads and crank are in my 468 that made 697hp what parts would I need to get my goal out of a 509
rreistino7 is offline   Reply With Quote
Old 09-17-2013, 01:29 PM   #2
CamKing
CamKing's Avatar
Default Re: 800hp 509 bbc
Need to see the flow numbers on the heads. "had some work" could mean anything, and that's going to be the biggest factor for making 800hp.
Mike Jones
Jones Cam Designs
Denver, NC 28037 704-489-2449
http://jonescams.com
jonescams@bellsouth.net
CamKing is offline   Reply With Quote
Old 09-17-2013, 01:37 PM   #3
rreistino7
Member
Pullin gears
rreistino7's Avatar
That's the bad thing is I don't know what's been done my builder said he did some work to them and the guy never picked them up so I bought them
Old 09-17-2013, 01:42 PM   #4
DaveyN
DaveyN's Avatar
Quote:
talk to Scott Foxwell...he's done some work with the Canfield heads.....he built my 509....AFR 305 heads...Straub hyd roller...11.4 to 1....made 764 at 6200....800+ would be easy with some compression and or a solid roller...
67 Chevelle 3550 lbs N/A
Straub/Foxwell HYD 509
slooow motion...1.43 back tires...
https://www.youtube.com/watch?v=Fa13syTsA0E
"the" pass....
http://www.youtube.com/watch?v=TM501gwoXsA
crazydaveyracing.com
DaveyN is offline   Reply With Quote
Old 09-17-2013, 01:59 PM   #5
rreistino7
Member
Pullin gears
rreistino7's Avatar
Ya it will be solid roller with 13.5-14:1 comp
Old 09-17-2013, 02:34 PM   #6
CamKing
CamKing's Avatar
It would be well worth the $100 to have one of the heads put on a flow bench. That head could flow anywhere from 350cfm to 420cfm.
Mike Jones
Jones Cam Designs
Old 09-17-2013, 02:44 PM   #7
DaveyN
DaveyN's Avatar
Quote:
^^^this...the heads will be key to what cam it needs...
"the" pass....
Old 09-17-2013, 03:01 PM   #8
bones427
bones427's Avatar
Yes give Scott a call, he's the man on canfields! I run them on 511 4.250x4.375 been 8.77 @2700
70 camaro bbc 511,Canfield 310 heads, 2700 lbs 8.77/152 5.58/124 1/8, 71 scamp 10.99- 100 shot 11.68 n/a V's House of Horsepower. Scott Foxwell. Chris Straub,Total Seal.Callies. BME. C.U.D.R,A.
bones427 is offline   Reply With Quote
Resources saved on this page: MySQL 2.25%
