Damn 2004 F250 Diesel (6.0L) throwing Black Smoke Out the Exhaust! - Page 3 - Yellow Bullet Forums
Old 09-15-2013, 01:34 PM   #31
racerxmd
racerxmd's Avatar
Garage
Talking Re: Damn 2004 F250 Diesel (6.0L) throwing Black Smoke Out the Exhaust!
Alright, I installed the batteries and she fired up. It was throwing out more Black Smoke in the beginning and missing alot. Once she warmed up it got alot better. I Topped Off the Diesel Fuel in the tank and also added some Lucas Diesel treatment. I ran it very hard and seems Great! I will be trading her in once I get the new title from DMV. My old title had a lean from HSBC. Since truck is Paid Off I need a new title stating No Liens on it.
racerxmd is offline   Reply With Quote
Old 09-15-2013, 01:44 PM   #32
garychios
Member
Pullin gears
garychios's Avatar
Default Re: Damn 2004 F250 Diesel (6.0L) throwing Black Smoke Out the Exhaust!
lean? or lien?
4rods @ 300 HP per rod.
http://miperformance.com
garychios is offline   Reply With Quote
Old 09-15-2013, 02:06 PM   #33
racerxmd
racerxmd's Avatar
Garage
My Bad! I meant "lien".
Old 09-15-2013, 03:20 PM   #34
skwerl
AG Jeff sucks cock
skwerl's Avatar
Some auto trans fluid in the fuel will clean up your injectors nicely. I add a half quart for every $100 of fuel in my big truck and it got rid of the injector tap.
-Brian
skwerl is offline   Reply With Quote
Old 09-15-2013, 03:25 PM   #35
chad5.0
Member
Pullin gears
chad5.0's Avatar
Quote:
Not in a 6.0. The injectors are very finnicky about what is run thru them.
chad5.0 is offline   Reply With Quote
Old 09-15-2013, 03:35 PM   #36
christiandseller
christiandseller's Avatar
Quote:
Originally Posted by chad5.0 View Post
Get good batteries in it first. Bad batteries are not good for the FICM.
This.
Forget charging them. Anything below 9 volts should be replaced especially on a diesel.
Quote:
Originally Posted by .gearhead.
Harassment my ass... You and your make-believe attorney obviously have no clue what defines harassment. Because logging into a message board voluntarily and participating in a 2 way debate SURE AS FUCK ISN'T IT.
I gave you the benefit of the doubt early in this thread. But you have implicated yourself over and over. Now you've just become a pathetic liar.
^^^^^Talking about April Bryant
christiandseller is offline   Reply With Quote
Old 09-15-2013, 03:40 PM   #37
christiandseller
This. Don't be a fucking cheapskate and create more problems down the road. Once a battery has been discharged enough to not start the engine, you've lost most of the reserve capacity and it will never be as strong as it was. You may get it back up to 13.6v but it won't hold it under load.
Lol!!! Cheapskate.
Old 09-17-2013, 06:41 PM   #38
racerxmd
racerxmd's Avatar
Garage
Unhappy Re: Damn 2004 F250 Diesel (6.0L) throwing Black Smoke Out the Exhaust!
Well, truck is hard to start still. I have to play with it some to get it to idle. Then when I try to accelerate the throttle it will choke out and throw black smoke! I am thinking I just need to replace the FICM.
Old 09-17-2013, 08:17 PM   #39
Portcity_gt
Member
Pullin gears
Portcity_gt's Avatar
Test it first. Go to advance auto and buy a scan gauge II, it will show ficm volts and many other things you need to monitor. It only cost $150. A new ficm from ford is $1500ish (if your going to buy one get one from bulletproof diesel, its the best you can buy) for about $500.
you can also test the ficm with a volt meter for free.
Come on over to powersroke.org and read the stickys in the 6.0 section before wasting a bunch of money.
Portcity_gt is offline   Reply With Quote
Old 09-17-2013, 08:26 PM   #40
KRAMER 555
Just a Mechanic........
KRAMER 555's Avatar
Some people pay a lot of money to make their diesel throw black smoke
Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. That's relativity.
Albert Einstein
KRAMER 555 is offline   Reply With Quote
Old 09-17-2013, 08:43 PM   #41
Flyin Monkey
Launchin
Flyin Monkey's Avatar
FICM - Just did mine a month ago.
Flyin Monkey is offline   Reply With Quote
Old 09-17-2013, 08:57 PM   #42
watchmysnake
how many ford 6.0 threads before you guys get a clue!
watchmysnake is offline   Reply With Quote
Old 09-18-2013, 07:29 PM   #43
racerxmd
racerxmd's Avatar
Garage
Just did the FICM test as per Bullet Proof Diesel's instructions. I removed the pin cover that shows I have a 4-Pin FICM on my 2004 F250. As per the instructions, I tested the Pin closest to the driver's side with the key in On Postion. It showed 47.9 to 48 volts. Once I had someone turning the motor over to start, the volts dropped alot! They dropped all the way down to 23 volts. Also, the engine did start but was running rough and still throwing black smoke. The guys at Bullet Proof Diesel walked me though the test and recommended I get their 4-Phase FICM. I am having it shipped to me in 2-days so I can install over the week end. So thanks for the help, I will keep you posted once I install it.
Old 09-18-2013, 07:56 PM   #44
Portcity_gt
Member
Pullin gears
Quote:
I tolz ya lol, man those guys are the best. On my truck I have their 6 phase ficm, remote oil cooler, water pump, all aluminum inercooler, filter caps.....
its all top notch stuff.
Old 09-18-2013, 08:01 PM   #45
Portcity_gt
Member
Pullin gears
Unfortunately a bad ficm can kill injectors pretty quickly, you still need to get a monitor to prevent a big mess in the future, mostly the health of the oil cooler. A clogged oil cooler will deprive the egr cooler of coolant causing it to rupture and pump steam and coolant into the cylinders causing blown head gaskets.
Also one of the best things you can do for that truck is to run rotella t6 oil and ONLY oem filters.
