Best way to repair pin hole leak in new oil pan. - Yellow Bullet Forums
Old 06-27-2013, 06:59 PM   #1
94-6spd
94-6spd's Avatar
Default Best way to repair pin hole leak in new oil pan.
It is coming from the weld. This is a brand new oil pan. What is a good way to seal this up from the outside and still in the car?
94-6spd is offline   Reply With Quote
Old 06-27-2013, 07:01 PM   #2
94-6spd
94-6spd's Avatar
Default Re: Best way to repair pin hole leak in new oil pan.
As you can see it is running out of the side of the pan.
Old 06-27-2013, 07:37 PM   #3
CrAsHmAsTer
Member
Pullin gears
CrAsHmAsTer's Avatar
I had one like that. I drained my oil (mine was on the bottom) the reason for draining.
Scuffed it up with sandpaper cleaned it with carb cleaner and put RTV on it, and let it dry overnght.
I tried JB weld but it still leaked.
ONE MAN,ONE GEAR,ONE SPEED.
CrAsHmAsTer is offline   Reply With Quote
Old 06-27-2013, 07:49 PM   #4
94-6spd
94-6spd's Avatar
Did it ever start leaking again?
Old 06-27-2013, 07:49 PM   #5
lewtot184
Member
Pullin gears
lewtot184's Avatar
unfortunately the only positive way to fix the pan is take it off and tig it up. soft solder will work but the metal needs to be oil free and clean. i doubt any epoxies or silcone type sealers will work unless all oil residue is removed from the inside of the pan.
lewtot184 is offline   Reply With Quote
Old 06-27-2013, 08:22 PM   #6
GKsGS400
YB Managing Editor
GKsGS400's Avatar
Permatex makes an oil leak sealant called spray n seal.
David Shaker
GKsGS400 is offline   Reply With Quote
Old 06-27-2013, 08:27 PM   #7
awake1630
Member
Pullin gears
awake1630's Avatar
marine tex that shit seals everything. What kind of pan is that?
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Brodix track 1 2.08/1.60
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
awake1630 is offline   Reply With Quote
Old 06-27-2013, 08:32 PM   #8
javajoe79
javajoe79's Avatar
Looks pretty easy to pull that pan off by the looks of the pics. Why not do that?
javajoe79 is offline   Reply With Quote
Old 06-27-2013, 08:45 PM   #9
3gdwrench
3gdwrench's Avatar
Drain oil, let sit overnight with drainplug out...clean area well w/brake kleen & some air pressure....Score the area with a grinding disk, say 36 grit, and apply either "Panel Bond" (3M-8116) or 3M catylized seam sealer (2 part). Both products are designed to adhere too bare steel, aluminum, Wood,....whatever. Gaurantee positive results.....
3gdwrench is offline   Reply With Quote
Old 06-27-2013, 09:07 PM   #10
IMSHOT
TEAM RACECAR
IMSHOT's Avatar
Looks like burn-through from a divider welded in there. If it leaks now and the impression is as visible as it looks in that one pic, it will tear in the future.
Baller on a budget..........
IMSHOT is offline   Reply With Quote
Old 06-27-2013, 09:46 PM   #11
boostedbowtie
boostedbowtie's Avatar
If its new and its on a weld call Milodon . That shit is too expensive to just let go . If its a defect I'm sure they will replace it .
boostedbowtie is offline   Reply With Quote
Old 06-27-2013, 11:26 PM   #12
crfbenny
Member
Pullin gears
crfbenny's Avatar
i would call the company you got it from and tell them send a return tag with my new undamaged pan. that cost too much to let go. why would you even consider sealant on a new pan ? or is it new to you but used . if thats the case pull it and weld it that way you wont have to worry later
crfbenny is offline   Reply With Quote
Old 06-27-2013, 11:37 PM   #13
94-6spd
94-6spd's Avatar
Quote:
It is a new Milodon pan that I bought a couple of years ago. I am finally getting the thing ready to drive. I started the engine a couple of times last Saturday to make some adjustments. So last night I noticed oil on my garage floor. I wiped the oil pan down because I couldn't detect exactly where it was coming from. Today after work I saw exactly where it is coming from.
It's a new build with a Procharger that has taken me a while to get going. I really don't want to take this thing out to change the oil pan.
Where can I get those products you guys speak of?
Old 06-27-2013, 11:41 PM   #14
awake1630
Member
Pullin gears
awake1630's Avatar
i have heard of this happening with a few pans from milodon. In the local speed shop the other day some guy was saying the same thing.
I would call and bitch
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
Old 06-27-2013, 11:44 PM   #15
ssminnow
Spooled up
If it is truly a small pinhole. Take a good sharp center punch. Use the punch to distort the metal around the hole. Don't go crazy it only takes a little bit to seal it up. I have done this on hydraulic tanks many times.
ssminnow is offline   Reply With Quote
