Hoosier quick time pro Air pressure - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Tires - Mickey Thompson Tires
Old 06-14-2013, 10:35 AM   #1
top452
Spooled up
top452's Avatar
Default Hoosier quick time pro Air pressure
New to these tires. 3200 lb ladder bar car. PG tranny. 31/16.5/15 Approx 50-50 wt transfer.What would a good starting air pressure be.
top452 is offline   Reply With Quote
Old 06-17-2013, 03:26 PM   #2
69TA
Spooled up
69TA's Avatar
Default Re: Hoosier quick time pro Air pressure
I was told 6-8 psi from Hoosiers tech. I run 33x22.5x15, 3200lb, PG. four link and front heavy. My car likes 7psi. I run tubes also.
69TA is offline   Reply With Quote
Old 06-17-2013, 03:32 PM   #3
55sedan
55sedan's Avatar
I run the 29 x 14.5 QTP with Hoosier tubes on a 10'' wheel at 15.5 - 17 psi
BBC P/Glide 12 Bolt on Leafs
55sedan is offline   Reply With Quote
Old 06-17-2013, 03:45 PM   #4
Shifter
Shifter's Avatar
I'm on a small tire (27x11.5-15) and it seems to like 13
1984 GT- 363 on 93 octane, glide, index/bracket, street legal
9.76 @ 138.8
2016 SCSO - 10.00 champion
www.northeastindexracers.com
Shifter is offline   Reply With Quote
Old 06-18-2013, 06:33 PM   #5
onefast68
onefast68's Avatar
Quote:
9 to 10
68 camaro..3300lbs........
big duke 632 with 2 kits ..
4.95 at 145.8 ................
onefast68 is offline   Reply With Quote
Old 06-19-2013, 04:57 PM   #6
h/r racer
h/r racer's Avatar
14x32x15w stiff side walls I run 9.5
h/r racer is offline   Reply With Quote
Old 06-19-2013, 08:54 PM   #7
55sedan
55sedan's Avatar
Wow, everyone runs a lot less than I do.
Any less than 14 in mine and it looks like the wheel is in the pavement at launch.
And thats with tubes.
Old 06-20-2013, 01:33 AM   #8
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
I'll never understand................ Run 22psi on the slow 11.50 car, run 20 psi on the slightly faster 9.50 car......... Take video and watch what the wheel and tire are doing, adjust from there. No tubes, no rim screws, no problems!
Mike Beck is offline   Reply With Quote
Resources saved on this page: MySQL 2.30%
