S10 with cal trac needs help - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 06-02-2013, 09:49 PM   #16
sharps-10
Spooled up
sharps-10's Avatar
Default Re: S10 with cal trac needs help
I heAr ya on that I'm thinking I might just switch over to a standard coil over so I have more options for spring weights!! So does anyone have any other suggestions.. If my cal trac bar is level when in the top hole will that not be enough bite??
spray it till it blows up then back it off a little
sharps-10 is offline   Reply With Quote
Old 06-02-2013, 09:52 PM   #17
Bigtime
Confused Racer
Bigtime's Avatar
here's mine, top hole, no preload, stock rear springs without oveload, 1.5" lowering block.
Bigtime is offline   Reply With Quote
Old 06-02-2013, 09:57 PM   #18
sharps-10
Spooled up
sharps-10's Avatar
What kind of 60ft you getting with it
Old 06-02-2013, 09:58 PM   #19
Bigtime
Confused Racer
Bigtime's Avatar
Quote:
I have the wind knocked out of it for 10.oh oops 1.43
Old 06-02-2013, 10:00 PM   #20
sharps-10
Spooled up
sharps-10's Avatar
I don't understand
Old 06-02-2013, 10:04 PM   #21
Bigtime
Confused Racer
Bigtime's Avatar
I don't understand
I built it to run the 10.oh index. So to slow it down i put 4.10's in it, have the transbreak release bolt all of the way in and its has a restrictor plate on it.
so now it goes 10.00 @ 135.00 with a 1.43 60' nice and easy so i don't take a chance of hitting the tire to hard.
Old 06-02-2013, 10:07 PM   #22
sharps-10
Spooled up
sharps-10's Avatar
Got ya
Old 06-02-2013, 10:11 PM   #23
Bigtime
Confused Racer
Bigtime's Avatar
you need more front spring. tallest lightest you can get in there. I have moroso's and 90/10's
Old 06-02-2013, 10:14 PM   #24
sharps-10
Spooled up
sharps-10's Avatar
They only have 2 different spring set ups for my coil over and I have the lightest ones
Old 06-02-2013, 10:17 PM   #25
Bigtime
Confused Racer
Bigtime's Avatar
does your caltrac bar look the same angle as mine?
Old 06-02-2013, 10:19 PM   #26
sharps-10
Spooled up
sharps-10's Avatar
In the pic it looks like your bar is either level or a tad down hill.. Mine is level but the is when in the top hole..
Old 06-02-2013, 10:25 PM   #27
Bigtime
Confused Racer
Bigtime's Avatar
Im in the top hole, the bottom hole is cut off
Old 06-02-2013, 10:26 PM   #28
sharps-10
Spooled up
sharps-10's Avatar
And your bar is level or down in the front??
Old 06-02-2013, 10:31 PM   #29
Bigtime
Confused Racer
Bigtime's Avatar
down
Old 06-02-2013, 11:55 PM   #30
Disturbing V6
Launchin
Disturbing V6's Avatar
If you have QA-1 should have more then 3 spring sets. And you can always buy the TRZ conversion to use a standard coil over spring. Gives a lot more spring rates and lengths.
1988 Chevy S-10. Nitrous fed 309 bowtie V6. New motor trans and chassis. Best time so far. 10.02 at 136
http://www.s10forum.com/forum/
http://www.s10racer.com/board/index.php
Disturbing V6 is offline   Reply With Quote
