Non intercooled, how much meth is too much? - Yellow Bullet Forums
Old 05-31-2013, 02:18 PM   #1
CameronVic
Wayyyyy more left in it!
CameronVic's Avatar
Default Non intercooled, how much meth is too much?
Here's the specs that are pertinent and some that possibly arent:
1999 crown vic 3700-3800 lbs
chevy 5.3 with 241 heads (8.8ish:1)
LS6 intake and cam
TH400
precision GTSH (7682)
E85
95lb injectors
2 nozzles. 1 pre turbo, one after (50% distilled water/ 50% denatured alcohol)
16psi it stayed just below 200* IATs through the 1/4 traps.
http://www.youtube.com/watch?v=xWDF7rMGXDE
Well I made the brilliant decision to get greedy, and put it on 23psi. I figured 10* would be a nice low starting point. So drove to mexico and did a pull after I turned the boost controller up some.
First pull was about 18psi. I turned it up a little, then repeated, 20 psi. Turned it a little more, did a pull, went to 23psi, and the car started to let loose so I considered it a success, turned around, and went home. Well the car started smoking a little out of the valve covers. I didn't think anything of it, got the car home. I didn't get on it at all the whole way home.
Next day I tried to drive it and it was smoking like a chinese opium den out of the breathers, and the exhaust this time.
Pulled the plugs and there's oil on like 3 or 4 of the plugs. I know the ringlands are toast, that's fine because I have a box of pistons and rods with African Bird oil on them keeping them from corroding.
Long story longer, after I put it back together, I'm going to lower the boost to 18-19 and keep it there, pull a little bit of timing, and try that.
I plan on spraying straight M1 through the nozzles this next time around. My question is at what point is there too much meth if there is a point?
A friend suggested I make this thread to get some possible experience from people on this. I don't know much (or anything) about methanol, but my understanding would be that the more meth I spray to cool the IATs, it would just lower the injector duty cycle and there would be no ill effects.
He also thinks that I could have crushed ringlands not from detonation (like I think), but because of an overly rich condition. AFs were low 11s the entire time, and touched high 10s in a few places on the datalog. I personally don't think that qualifies as overly rich. I would think flatlining 10.0s would be overly rich, which it has never done.
Lemme know what you guys think, and if you have any questions, lemme know. I'm gonna go pull this motor. LOL.
CameronVic is offline   Reply With Quote
Old 05-31-2013, 09:53 PM   #2
baggins
Launchin
Default Re: Non intercooled, how much meth is too much?
Is this non inter cooled?
baggins is offline   Reply With Quote
Old 05-31-2013, 11:18 PM   #3
FULLBLOWN03
Spooled up
FULLBLOWN03's Avatar
Is your meth kit a progressive setup? What size nozzles and are you running pump gas?
Twin Turbo precision 6262's, 4.6L mod motor built by Bridge Racing. F.A.S.T. XFI/lscoils http://bridgeracing.com/
8.90 @ 154 21psi boost on pump/meth on 275's http://www.youtube.com/watch?v=a5SS7D0ThnU
8.49 @ 161.98 25psi boost on 275's http://www.youtube.com/watch?v=gdZPgT11V9E&sns=em
8.18 @ 168.5 precision 6466 turbos 29psi on 275 MT drag radial pro's http://www.youtube.com/watch?v=GnB02...e_gdata_player
Best 1/8 5.10 @ 139.7 3400lbs
FULLBLOWN03 is offline   Reply With Quote
Old 05-31-2013, 11:59 PM   #4
baggins
Launchin
Should have read the title, my bad
Old 06-01-2013, 01:34 AM   #5
ott308
Launchin
What size nozzles? With straight meth (with progressive controller) at that boost level you could run 2 large nozzles no problem. Just tune your setup to suit and take some timing out above a certain IAT incase your meth kit fails.
FYI- I have 3 large nozzles, 1 pre 2 post running straight meth at 15psi on a 383.
ott308 is offline   Reply With Quote
Old 06-01-2013, 08:56 AM   #6
71 chevy
hardly such a thing as too much methanol from two nozzles.
think about the fact that some boosted cars run methanol fuel as low as 3.5:1 afr
many cars run around 4:1 afr. in gas terms thats approx 8-9 afr
that also answers your other question - you did not lift ring lands from being too rich - guys spraying methanol are spraying 2x as much as gasoline guys, 1.4x as much as e85 and not lifting ring lands. if you lifted from being too rich, then nobody would be able to run meth or eth as primary fuel.
the Capitalist Creed - From each according to his gullibility, to each according to his greed.
"Marketing has won over truth for many years!" Airflowdev
"the first rule of racing is that everyone spends all the money they have" - kevin Cameron
71 chevy is offline   Reply With Quote
Old 06-01-2013, 09:44 AM   #7
wstidham
Member
Pullin gears
Everyone keep in mind this was 50% water/50% denatured alcohol. NOT straight Meth.
Also how do you know he didn't lift them from being too rich? He is on a stock piston pushing a good bit of fuel/pressure through it, add to that a dual irrigation system that is cooling down the intake charge, but at what point will the motor not be able to ingest anymore of the 50/50 mix?
It is difficult to compare a bone stock motor more than doubling its base hp to a purpose built turbo motor with adequate pistons.
I believe the same condition he had before will be much more difficult to happen with straight meth vs the water mix.
But also I would like to hear more first hand experience with the 50/50 mix AND straight meth comparison as opposed to reading the internet.
wstidham is offline   Reply With Quote
Old 06-01-2013, 11:43 AM   #8
CameronVic
CameronVic's Avatar
Quote:
One is 6.32gph@40psi, 10.0gph@100psi.
The other is 9.49gph@40psi, 15.0gph@100psi.
Pump is close to 100psi
I'm not on pump gas, well, technically I am. It's on E85
I have megasquirt and it can pull timing if IATs get too crazy, and it will also add fuel in to target EFs if the meth pump goes. Thank you for the input.
When I start spraying meth, will that change anything as far was the wideband accuracy? Like, will it be reading overly rich when in fact its incredibly lean?
Old 06-01-2013, 04:42 PM   #9
ott308
Launchin
I used to run a mix of meth/water. Tried several different mixes, 100 percent meth I believes works the best. With the meth kit activated on mine at full boost the afr will bump down to the 9s. And it pulls hard. I figure meth with the lower stoich helps. I would never run it that fat with a water mix. Is mine too rich-probably? I will be doing some more tuning soon and leaning it out some. Water mix has a limit of how much to inject-not really the same situation with 100% meth.
Old 06-01-2013, 05:06 PM   #10
bluchev
bluchev's Avatar
Sounds like you should stop fuaroundcking around and put an intercooler on it.....
9.10@153.3 on 24 psi (2015) Dominator EFI 3850 lbs
New setup for 2016 Twin Billet S374's from CRT turbo, 6.0 on 25 psi 1117WHP 884 WTQ
bluchev is offline   Reply With Quote
Old 06-01-2013, 06:00 PM   #11
CameronVic
CameronVic's Avatar
Quiet with your blow through!
Old 06-01-2013, 06:43 PM   #12
brianj5600
Quote:
Originally Posted by bluchev View Post
Sounds like you should stop fuaroundcking around and put and put good pistons in it.....
Fixed!
67 Mustang Coupe, 351w turbo blow thru,
c4, 8.8
brianj5600 is offline   Reply With Quote
Old 06-01-2013, 09:57 PM   #13
CameronVic
CameronVic's Avatar
Well no crushed ring lands as I had hoped...
All a good piston woulda got me here Brian was a more expensive fix
Old 06-01-2013, 10:54 PM   #14
bluchev
bluchev's Avatar
Lol mustve been drunk when i posted that holy mis spelling! Lol
Old 06-01-2013, 11:23 PM   #15
boost creep
Member
Pullin gears
boost creep's Avatar
Ouch! Whats the cylinder wall look like?
boost creep is offline   Reply With Quote
