Rear Wheel Line locks on dragsters? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 05-12-2013, 07:42 PM   #1
Rockerarm242
Spooled up
Garage
Default Rear Wheel Line locks on dragsters?
Wondering if any of you dragster racers out there run line lock on rear wheel brakes...talking through delay box! Our car settles nice and tight on trans brake application but occasionally (out of the blue) will settle slightly forward. Seems to be a good idea. Thanks in advance for any input!
Rockerarm242 is offline   Reply With Quote
Old 05-12-2013, 07:47 PM   #2
sc3515
Member
Pullin gears
sc3515's Avatar
Default Re: Rear Wheel Line locks on dragsters?
My car used to move forward some when getting on the brake, brought it to the trans guys and he changed something with the pressure to solve the problem.. Before it was fixed i would bring the motor up a bit before putting the t brake on
sc3515 is offline   Reply With Quote
Old 05-12-2013, 08:28 PM   #3
Yenko
Member
Pullin gears
To me, there is no reason not to do this. I have my line lock ran with a diode to lock it down when I push my transbrake button. Anything you can do to keep the car in the same spot when you push the transbrake button will be, if nothing else, a piece of mind.
Yenko is offline   Reply With Quote
Old 05-12-2013, 08:47 PM   #4
Rockerarm242
Spooled up
Garage
Your certainly right concerning pump pressure..we use starting line enhancer that elevates idle to approx 1800 RPM which should be adequate for trans brake application plus I check band adjustment about every 25 passes or so..Since line lock releases with TB release...just seems that it would be would added measure to insure that car remains exactly in same position relative to when it brake was applied! My primary reason for asking was if it might affect consistence performance. Went red 006 (number with 1) in box final last and foks on starting line said car moved slightly forward on TB application...Sux because opponent was 50 something on tree...having said that...he was GREEN..and that wins races! Heck..figure it's worth try!
Old 05-12-2013, 08:58 PM   #5
Gary Kubisch
Gary Kubisch's Avatar
Quote:
That is my set up as well.
Like you said.....No reason not to do it.
Photo by Johnboy.Thanks!
Gary Kubisch is offline   Reply With Quote
Old 05-12-2013, 09:55 PM   #6
Yenko
Member
Pullin gears
Quote:
My car would repeat like no others in my opinion. It did not affect my consistency at all. Matter of fact, it probably helped it. If you stage your car the exact same everytime, that will help your consistency. Bracket racing is all about consistency, if you make sure you do the same burnout, stage with the water temp the same, and stage the car in the exact same spot everytime, the only reason it would not be consistant is your tires are shot, or your tune up is wrong. Make everything the same, and have good equipment, and it has to be consistant.
Old 05-12-2013, 10:06 PM   #7
Coloradoracer
Coloradoracer's Avatar
I've got one in mine, and it does help! Car doesn't "rock" when I go on the brake, just sits there!
Mark Goulette
Owner and driver, Livin' the Dream Racing Dragster
Speed kills but it's better than going slow!
www.livinthedreamracing.com
Authorized Amsoil Dealer
Coloradoracer is offline   Reply With Quote
Old 05-12-2013, 10:52 PM   #8
spiralx45
spiralx45's Avatar
I don't have one... not sure if I need it! These cars will still rock line lock or not BTW
Marion Welding Solutions, LLC for all your Welding Supply Needs!
https://www.facebook.com/MarionWeld
spiralx45 is offline   Reply With Quote
Old 05-12-2013, 11:08 PM   #9
topcomp
Member
Pullin gears
topcomp's Avatar
we run one, but it's only because of the lenco.don't need one on my bracket ride
topcomp is offline   Reply With Quote
Old 05-13-2013, 08:41 AM   #10
Hammertime
Hammertime's Avatar
Do some research on it, you'll find a 50/50 mix of guys who said it made their cars more inconsistent rt wise then it was before (brake pressure releases different all the time) ... and honestly its a bandaid fix for a trans issue to begin with.
www.apdracing.com
Hammertime is offline   Reply With Quote
Old 05-13-2013, 09:41 AM   #11
spiralx45
spiralx45's Avatar
Quote:
All depends on how much brake pressure you have I'm sure! Time for a brake pressure gauge!
Old 05-13-2013, 11:18 AM   #12
Wicked Fast
Wicked Fast's Avatar
The better way is to fix the trans
Wicked Fast is online now   Reply With Quote
Old 05-13-2013, 12:07 PM   #13
topcomp
Member
Pullin gears
topcomp's Avatar
Quote:
X2
Old 05-13-2013, 12:21 PM   #14
1Gary
If you timed the both-line lock doesn't release as fast as a trans brake.Mechanically it couldn't.
1Gary is offline   Reply With Quote
Old 05-13-2013, 12:23 PM   #15
spiralx45
spiralx45's Avatar
That car can still rock even after the transbrake is set though... I though a large part of the line lock on a door car is to keep the gear mesh tight...
