Position of instant center effects on chassis - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 04-30-2013, 11:24 AM   #1
Brad87gt
Default Position of instant center effects on chassis
Say I have an instant center of 50" and it's 9" high. What should happen if I take that same 50" instant center and move it to a height of 15"? What should happen here more anti-squat?
1993 Cobra, 321", Jerico
Brad Knorr
Brad87gt is offline   Reply With Quote
Old 04-30-2013, 12:38 PM   #2
Natas_69
Spooled up
Natas_69's Avatar
Default Re: Position of instant center effects on chassis
This is my understanding----
By raising the height you will raise percentage of anti squat. But this will be difficult to achieve with out changing the length.
By shortening the length you will affect how quickly the rear end can react at the launch.
www.supernaturalturbo.com
Natas_69 is offline   Reply With Quote
Old 04-30-2013, 12:56 PM   #3
Brad87gt
Well my instant center is short I have adjustable upper brackets to get the upper facing down. The lowers are almost perfectly level. So the instant center is short but very low. I was going to raise the rear of the car to raise it up some but I was not sure what the effect would be.
Brad Knorr
Old 04-30-2013, 01:09 PM   #4
JeffMcKC
JeffMcKC's Avatar
http://www.shopeshop.org/tim.47.htm
Knock yourself out
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 04-30-2013, 01:09 PM   #5
JeffMcKC
JeffMcKC's Avatar
Quote:
You will be changing more than just the CG you will be changing the IC at the same time
TRZ Dealer
Old 04-30-2013, 01:24 PM   #6
Brad87gt
Yes I think I want to raise the instant center height in order to raise the anti squat %
Brad Knorr
Old 04-30-2013, 01:26 PM   #7
Brad87gt
Thanks for the link!
Brad Knorr
Old 04-30-2013, 08:08 PM   #8
86lxnotch
i've learned alot lately suspension wise and im still semi confused but i think if you raise your a/s youll be asking for problems hitting the tires hard
the lowers should be 1/8'' uphill to body or as close to it as possible w/o going downhill to body. are your uppers adj on the body side or housing side?
before i forget....what tires? shocks? struts? spring rates?
'86 Mustang
Iron 370 LS/glide/?????
Lil John Motorsport Solutions
Ultimate Converter Concepts
NMRacing
Matt Hill Motorsports
RaceWires
Keesey's Airport Auto
Innovative Performance and Repair
86lxnotch is offline   Reply With Quote
Old 04-30-2013, 09:02 PM   #9
lazaris
Member
Pullin gears
lazaris's Avatar
Raising the IC height will increase the weight transfer.
lazaris is offline   Reply With Quote
Old 04-30-2013, 09:07 PM   #10
Brad87gt
With me in the car my lowers are 1* up towards the chassis. My uppers are adjustable on the rear housing (auto fab kit). I run a 26x10 et drag. I have strange single adjustables front and rear. 12" 130# springs in front, stock coil spring in rear with one coil cut. It is a stick car and has go e a best of 10.16 @134 I want to go 9.99 it only 60' in the low 1.50's last year I have not ran it with the adjustable uppers yet...
Brad Knorr
Old 05-01-2013, 09:46 AM   #11
JeffMcKC
JeffMcKC's Avatar
The trans will make most guys comments from autos 180* from what you need, Clutch issues are a balancing act, how you launch it will make a lot of diff
TRZ Dealer
Old 05-01-2013, 11:03 AM   #12
Brad87gt
I understand. From what I see anti squat well over 100% is needed with a small tire stick car.
Brad Knorr
Old 05-01-2013, 11:18 AM   #13
JeffMcKC
JeffMcKC's Avatar
I VERY GOOD SHOCK IS NEEDED
TRZ Dealer
Old 05-01-2013, 11:19 AM   #14
Brad87gt
I'm assuming my s/a strange shocks won't cut it...
Brad Knorr
Old 05-01-2013, 11:35 AM   #15
JeffMcKC
JeffMcKC's Avatar
I don't think so, the Hit at the start is going to be very hard and the harder you make it hit the more the tire is going to want to basketball back up, your going to want to curb the hit to start then hold it till you shift, then it starts over, this to changes if you have a adjustable "slipper" clutch.
TRZ Dealer
Resources saved on this page: MySQL 1.03%
