Fast bracket sbc - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 04-24-2013, 08:08 PM   #1
SP4167
Spooled up
SP4167's Avatar
Default Fast bracket sbc
Got a little 460ishCI SBC (4.185/4.250) 13.5-14.1 comp, with a Kevin self sheetmetal intake, T2 terminator, Brodix gb2300 casted/weldtech lightened heads, 2 1/4 headers, low 700ish lift cam, 2350-2400lbs tube chassis camaro 4.56 gears, powerglide and adding a vacuum pump. Hoping it'll at least run 5.40s in the 1/8th. Setup hasn't been down the track yet though. Just looking to make a half ass fast bracket car. Would adding another T2 or putting down nozzles in it make any more power or would it not be worth it? Pros/cons?
Would love for it to run quicker, but satisfied with 5.40s. Any input welcomed, the combination was bought with the car. We just took it apart to build it NA since it'll be a bracket car, it was built for nitrous.
SP4167 is offline   Reply With Quote
Old 04-24-2013, 08:11 PM   #2
Leavinsteven
REBUILDING
Leavinsteven's Avatar
Default Re: Fast bracket sbc
That is one badd "Little" SBC!
http://youtu.be/5L5h8pyAG6Q
Life is Drag Racing....
Everything else is waiting.
Leavinsteven is offline   Reply With Quote
Old 04-24-2013, 08:16 PM   #3
SP4167
Spooled up
SP4167's Avatar
Thanks! Hope it runs as good as it sounded before we took it apart. Previous owner was spraying it pretty good, had 38 pills in each stage. Just took it to the machine shop to order new pistons, cam (4/7 swap), and freshen it up with all new bearings.
1968 Camaro with a SBC
Old 04-24-2013, 08:39 PM   #4
badS10
Spooled up
What did it run when he had it? And what was it in? I'm building a 461...4.155x4.250...afr245 heads pro systems dominator...
badS10 is offline   Reply With Quote
Old 04-24-2013, 08:45 PM   #5
jaxsmith
Member
Pullin gears
jaxsmith's Avatar
2 terminators and a lot of rpm should do the trick
6.12 @ 109 1/8 1.24 60ft
2950 lbs 405" NA
jaxsmith is offline   Reply With Quote
Old 04-24-2013, 08:50 PM   #6
SP4167
Spooled up
SP4167's Avatar
Quote:
Not real sure. Heard it went 4.70s on a small shot. I don't know how small or how good it was tuned at that time.
Old 04-25-2013, 01:47 AM   #7
Jamey1e
Member
Pullin gears
Jamey1e's Avatar
Should go pretty good. Our 468 went 5.10 N/A and 4.71 with a 32 pill at 2200lbs.
Jamey1e is offline   Reply With Quote
Old 04-25-2013, 10:42 AM   #8
78buickregal
www.ULTRA-CARBON.com
78buickregal's Avatar
Wow, nice motor.
What block?
Carbon Fiber Malibu Trunk Lid Video... http://www.youtube.com/watch?v=mC-1T...ature=youtu.be
Carbon Fiber goodies for your race car!
78buickregal is offline   Reply With Quote
Old 04-25-2013, 11:24 AM   #9
358T
Launchin
358T's Avatar
In my opinion 2 throttle bodies would be better so the air has a straighter shot to the valve. Was this engine previously ran with the Single T2 mounted like that?
I think you will get your goal of 5.40's fairly easily. I know a guy who had those heads on a 454 SBC with dual Toilets and ran 4.60-4.65 at 1600lbs
Scott
WWW.KillerRONS.COM
scottoffermann@inbox.com
358T is offline   Reply With Quote
Old 04-25-2013, 03:43 PM   #10
GFBDIESEL
Launchin
hell i went 5.69 in a 2850lb car. looking at buying a 2350lbs car with me in it. it better run better then that.
GFBDIESEL is offline   Reply With Quote
Old 04-25-2013, 04:03 PM   #11
SP4167
Spooled up
SP4167's Avatar
Iron eagle tall deck.
Yes Scott, the T2 was mounted like that already. Will probably give you guys a call before its back from the machine shop to add another T2. Don't remember what size the pump is I'll have to look.
I was realistically thinking it should run 5.20s, but didn't want to set my bar too high! Anything faster than .40s is just that much better to me.
