shafiroff cam specs? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 04-12-2013, 08:35 PM   #1
Tom Pasta
Burnout box
Default shafiroff cam specs?
Looking for cam specs for solid roller I picked up. It is a Shafiroff grind stamped ssre4400 13-35-04. Any help will be appreciated. Thanks
Tom Pasta is offline   Reply With Quote
Old 04-12-2013, 08:37 PM   #2
jr67rs
jr67rs's Avatar
Default Re: shafiroff cam specs?
I would just call shafiroffengines
jr67rs is offline   Reply With Quote
Old 04-15-2013, 08:52 AM   #3
chasek
Spooled up
The SSRE 4400 is a mechanical roller camshaft for a BBC. Recommended valve lash is .026" intake, .030" exhaust at operating temperature. Lobe lift is .490" intake, .4706" exhaust, giving a gross valve lift of .833" intake, .800" exhaust, with the standard 1.7:1 ratio rocker arms. Advertised duration measured at .018" lift is 328 degrees intake, 356 degrees exhaust. Duration at .050" lobe lift is 288 degrees intake, 312 degrees exhaust. Cam timing at .050" is: intake opens 33 degrees BTDC, intake closes 75 degrees ABDC, exhaust opens 97 degrees BBDC, exhaust closes 35 degrees ATDC. Lobe separation is 116 degrees. Regards, Chase
chasek is offline   Reply With Quote
Old 04-15-2013, 11:33 AM   #4
Stockey-Yockey302
SBF TTFMF
Garage
Quote:
Gross valve lift with a 1.7 rocker arm is actually .847/.811. If he has the older cam that was ground by bullet, it will have the specs you posted. If it's the new one ground by comp, then it has the lift I just said. I work in the parts dept. at shafiroff racing.Thanks- Ian
Stockey-Yockey302 is offline   Reply With Quote
Old 04-15-2013, 01:10 PM   #5
chasek
Spooled up
Indicated by the 13-35-04 code, it should be the really older version that was ground by Crane, with the specs I've provided. The 13 stands for BBC, 35 is the week of the year it was ground, and the 04 is 2004 (year). Regards, Chase
Old 06-29-2013, 07:32 PM   #6
496shoebox
Burnout box
I have an older Shafiroff cam too...13-40-99...also has 139556....any help would be appreciated!
496shoebox is offline   Reply With Quote
Old 06-29-2013, 09:15 PM   #7
chasek
Spooled up
What is stamped on the front of the cam? If it's a Shafiroff grind, the grind number will begin with SSRE. The numbers that you've provided indicate the cam core number, and the date code only). Regards, Chase
Old 06-29-2013, 11:56 PM   #8
ordinary builder
gee man
it is so easy to just put adegree wheel on it and see what it is...
THEN THERE WILL BE NO DOUBT....
ordinary builder is offline   Reply With Quote
Old 06-30-2013, 02:32 PM   #9
496shoebox
Burnout box
3263
Old 06-30-2013, 02:33 PM   #10
496shoebox
Burnout box
if it was in the engine that would be a no brainer.....
Old 07-01-2013, 03:14 AM   #11
russ67chevelle
Lol
russ67chevelle is offline   Reply With Quote
Old 07-01-2013, 08:29 AM   #12
chasek
Spooled up
The SSRE3263 is a BBC roller camshaft, with standard journal diameter and firing order. The duration at .050" is 272 degrees intake, 278 degrees exhaust. Lobe separation is 110 degrees. Cam timing at .050" tappet lift is: intake opens 29 degrees BTDC, intake closes 63 degrees ABDC, exhaust opens 72 degrees BBDC, exhaust closes 26 degrees ATDC. This is based on a .750" diameter roller wheel. Recommended valve lash is .022" on both intake and exhaust, at operating temperature. Advertised duration at .0195" tappet lift is 310 degrees intake, 316 degrees exhaust. The basic power range is 4200-7800 RPM. Regards, Chase
Old 07-01-2013, 12:41 PM   #13
496shoebox
Burnout box
Thanks Chase!
Old 07-01-2013, 04:27 PM   #14
Stockey-Yockey302
SBF TTFMF
Garage
Anytime someone needs shafiroff cam specs, you can PM me. I work there and will help you out.
Old 07-01-2013, 07:13 PM   #15
gates79
Burnout box
Hi there have a real street with 402 sbc from ssre it has the comp xr288 hr on a 110
Have added a f1r pro charger to motor have you an idea on what sort of cam would be more appropriate now with the motor boosted? Solid roller 114-116? Change lifters out etc? Thanks for any info
gates79 is offline   Reply With Quote
