DOT 4 and DOT 5 brake fluid mixed, what to do? - Yellow Bullet Forums
Old 04-08-2013, 10:02 AM   #1
kamkuda
Spooled up
kamkuda's Avatar
Angry DOT 4 and DOT 5 brake fluid mixed, what to do?
It looks like the brake fluid was mixed and the fluid is cloudy.
SHould I switch to DOT 4 or DOT 5
Can I just bleed it out?
kamkuda is offline   Reply With Quote
Old 04-08-2013, 10:18 AM   #2
Gdogg
Gdogg's Avatar
Garage
Default Re: DOT 4 and DOT 5 brake fluid mixed, what to do?
I think you can mix 3 and 4, dot 5 is silicone, so drain it all out, flush it with new stuff.
Give a man a fish and he'll eat for a day. Deport him, and you'll never feed him or his anchor babies ever again. Donald J Trump
https://onsizzle.com/i/donald-trump-...s-bible-224677
Gdogg is offline   Reply With Quote
Old 04-08-2013, 10:43 AM   #3
kamkuda
Spooled up
kamkuda's Avatar
I understand that they do not mix
The benefit of the dot 5 is the boiling point but I wrecked some paint on a car and the silicone doesnt affect paint.
Its expensive and I have been puking out a bunch trying to bleed it ou
I was think of draining and just switch back to the Dot 4
Also I heard the combo of the 2 may degrade the seals
Old 04-08-2013, 11:26 AM   #4
187z
187z's Avatar
Drain and flush.
187z is offline   Reply With Quote
Old 04-08-2013, 11:37 AM   #5
Paulie9fingers
Gettin' tired of the shit
Paulie9fingers's Avatar
Drain it all out and start over, a mighty vac or something similar will make for a speedy process. I would suck all the existing fluid out from all the calipers, refill it with the new fluid of your choice and flush that out too, then refill it and bleed the brakes.
DOT 3, 4 and 5.1 will mix and the Dot 5 is silicone based and should never be mixed with any of the others.
I personally don't like the DOT 5 silicone stuff because of the pedal feel, I'd use either Dot 4 or 5.1.
http://www.advancepetro.com/differentbrakefluid.htm
http://www.opieoils.co.uk/pdfs/tech-...-Explained.pdf
http://www.afcoracing.com/tech_pages/fluid.shtml
If winning was easy, everyone would be doing it
Paulie9fingers is offline   Reply With Quote
Old 04-08-2013, 11:49 AM   #6
stoneloco808
Member
Pullin gears
stoneloco808's Avatar
Yup, drain and flush with the fluid you want to use.
stoneloco808 is offline   Reply With Quote
Old 04-08-2013, 12:01 PM   #7
Run to Rund
Silicones are insoluble in about everything. It will be hard to remove all the residue, and you must do so for good brake performance.
Run to Rund is offline   Reply With Quote
Old 04-08-2013, 12:08 PM   #8
OB1
YB.com Approved Vendor
OB1's Avatar
You can flush the system with denatured alchohol.....
OB1 is offline   Reply With Quote
Old 04-08-2013, 01:11 PM   #9
widowmaker
Member
Pullin gears
widowmaker's Avatar
Flush it all out. Use dot 5.1. Compatible with dot 4
widowmaker is offline   Reply With Quote
Old 04-08-2013, 07:34 PM   #10
BoostBuggy
Burnout box
OMG No! Don't just flush the system. If you truly had DOT 4 and DOT 5 fluids mixed you have a real mess and a potential safety issue on your hands. You need to rebuild all the calipers, the master cylinder and anything else that has seals in it. DOT 4 and DOT 5 fluids are dramatically different in materials and are not compatible in any way. the 2 types will create a "sludge" in the lines, calipers, MC and everywhere else.
The process should be to remove the calipers, MC, ABS pump/unit (and if a manual transmission using brake fluid as the hydraulic fluid) the clutch slave cylinder and anything else with seals associated. You will need to rebuild all these components with new, fresh seals. For the lines, at the bare minimum blow them out several times with denatured alcohol, then reassemble the system.
Other than the fact DOT 5 will not harm paint there is nothing (IMHO) positive about it. It's highly compressible (can be as much as 19% dissolved air - SAE J1705 Appendix 2.2. doesn't swell or lubricate the EPDM seals very well and is NOT hygroscopic.
Good luck with cleaning the mess out...
BoostBuggy is offline   Reply With Quote
Old 04-08-2013, 08:46 PM   #11
Hired driver
Steering wheel holder
Hired driver's Avatar
^ what he said, you need to clean it out not just flush it.
Quote:
Originally Posted by Cheswick View Post
You guys are weird.
Hired driver is offline   Reply With Quote
Old 04-08-2013, 08:50 PM   #12
Monty Mikho
Satan
Monty Mikho's Avatar
Garage
Just put a chute on and remove the brakes.. no one ever made a record pass with a good set of brakes!! Think about that!!
The 8th YellowBullet.com Nationals Event!!
Cecil County Dragway September 1st - 3rd , 2017:
Now accepting 2017 YellowBullet Nationals sponsors!!
Monty Mikho is offline   Reply With Quote
Old 04-08-2013, 08:55 PM   #13
DIABLO05
DIABLO05's Avatar
Quote:
YOU first......
88' Ford Mustang
http://www.youtube.com/watch?v=T6fOFTTMYec
DIABLO05 is offline   Reply With Quote
Old 04-08-2013, 08:57 PM   #14
Monty Mikho
Satan
Garage
Quote:
Originally Posted by DIABLO05 View Post
YOU first......
DONE!!
Your turn!!
Old 04-08-2013, 08:59 PM   #15
Rob G.
Rob G.'s Avatar
DONE!!
Your turn!!
Rob G. is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
