9" Inch Ford Yukon Aluminum Case, GOOD OR BAD - Yellow Bullet Forums
Old 04-07-2013, 10:25 AM   #1
badmouse
Burnout box
Default 9" Inch Ford Yukon Aluminum Case, GOOD OR BAD
Dose any one use this stuff .Is it any good . Here are more spec on it Thru-Bolt Case (3.06" or 3.25")
- T6 Aluminum
- Over-Sized 7075 Forged Caps
- Heavy Duty Thru-Bolt Design
- Good for 1200+ HP
* Aluminum Daytona Pinion Support (28 Spline)
- Oiling Holes for Proper Bearing Lubrication
* 1350 Billet Steel Pinion Yoke (28 Spline)
- Cap Size = 3-5/8" x 1-3/16"
- Spicer U-Bolts Included
* Master Timken Bearing/Installation Kit
- Carrier Bearings/Races, Pinion Bearings/Races, Pilot Bearing, Pilot Bearing Lock Ring, Pinion Nut, Pinion Shims, Pinion Seal, Ring Gear Bolts, Support O-Ring, Marking Compound, Lock-Tite, Brush, & Gasket
* This kit gets you everything needed to build a complete center section, except for the gears and the carrier/spool unit. We offer gears starting at $112 and carrier/spools starting at $100. or should i strange stuff thank for help badmouse
badmouse is offline   Reply With Quote
Old 04-07-2013, 10:29 AM   #2
ChuckDirt
xtremeoutlawseries.com
ChuckDirt's Avatar
Default Re: 9" Inch Ford Yukon Aluminum Case, GOOD OR BAD
I have sold one, never used any but they a nice looking piece for sure.
Xtreme Outlaw Series
S&M Motorsports
XTown Diesel Performance
ALCO Properties
TNT Transmissions
ChuckDirt is offline   Reply With Quote
Old 04-07-2013, 10:40 AM   #3
Torinoboy
Pre-Staged
I havent used an aluminum one. My cast iron one is a beast. Yukon is good stuff. I got mine from Staticz on here, great price. Maybe he'll chime in.
Torinoboy is offline   Reply With Quote
Old 04-07-2013, 10:40 AM   #4
79pacecarmod
DEAMON TWEAKER
79pacecarmod's Avatar
I have it in my yellow car 1.17 60fts at 3150 no issues.
1979 mustang pace car
Cameron's Torque Convertor Services
5.03 141MPH
June 08 modified mustang feature car
http://www.mustangandfords.com/featu...ang/index.html
WWW.DAMNYANKEESRACING.WEBS.COM
79pacecarmod is offline   Reply With Quote
Old 04-07-2013, 10:42 AM   #5
GTA matt
Creepy Ass Cracka
GTA matt's Avatar
I have one. It is a good looking piece. There is a good bit of info on them in the rear end section here.
GTA matt is offline   Reply With Quote
Old 04-07-2013, 10:45 AM   #6
nosnerd
SomeWhat Jaded
nosnerd's Avatar
great piece and a great value
"IGNORANCE SHOULD BE FUCKIN' PAINFUL"
522/798hp + NOS/I.S plate
Doin' it on 315's at full weight, ladies
*ULTRA PERFORMANCE and FABRICATION *
www.DandDPerformance.ca
nosnerd is offline   Reply With Quote
Old 04-07-2013, 10:45 AM   #7
Monty Mikho
Satan
Monty Mikho's Avatar
Garage
Yukon Gear has been a sponsor of the YellowBullet Nationals for 3 years in a row. They continuously give back to the racers and it is awesome you are considering them. They are a great bunch of guys. If you have any question you can ask Aaron in the rear end tech section.
The 7th YellowBullet.com Nationals Event!!
Cecil County Dragway September 2nd - 4th , 2016:
Now accepting 2016 YellowBullet Nationals sponsors!!
Monty Mikho is offline   Reply With Quote
Old 04-07-2013, 10:56 AM   #8
image4you2see
image4you2see's Avatar
Buddies shop has sold hundreds of them and never had one problem with setting up a gear or a customer with any complaints. Give Midwest Chassis a call he can hook you up with a good price on one, he lways has them in stock.
image4you2see is offline   Reply With Quote
Old 04-07-2013, 11:01 AM   #9
Smitty275
Smitty275's Avatar
You won't be disappointed. It's a great piece. Know many who use it with no problems.
Smitty275 is offline   Reply With Quote
Old 04-07-2013, 11:10 AM   #10
1badnova
The X-Bomb
1badnova's Avatar
I just bought the same one you copied and posted from ebay. It looks like nice stuff and quick performance is super quick at getting it shipped. I bought everything from them. The package you listed, spool and gear. all for around 800 bucks. Its going in the car and should be done mid week.
http://www.ebay.com/itm/221186853913...84.m1497.l2649
http://www.ebay.com/itm/390560673877...84.m1497.l2649
http://www.ebay.com/itm/370779329721...84.m1497.l2649
1badnova is offline   Reply With Quote
Old 04-07-2013, 11:11 AM   #11
badmouse
Burnout box
thanks for all the help guys.
Old 04-07-2013, 11:23 AM   #12
Faststreetcar
Spooled up
Faststreetcar's Avatar
Never tried one of those. I do have an actual Mark Williams through bolt style aluminum case with a 3.06 bearing size for sale cheap ($200), PM if interested.
Faststreetcar is offline   Reply With Quote
Resources saved on this page: MySQL 1.09%
