valve stems - Yellow Bullet Forums
Old 03-20-2013, 10:29 PM   #1
634 Chevelle
Spooled up
634 Chevelle's Avatar
Default valve stems
Has anyone had any trouble with valve stems flaking. They are manley titanium valves , bronze liners, no valve seals, no oil restricters. Seems to be mainly intake vavles. Motor is a634 bbc that has 2 stages of nos, 7500-8000 rpm, has never had any real problems other than a few lifted ring lands. Any input would be appreciated.
'66 Chevelle, 3000#, 634 bbc
1.11 60ft
3.08 330ft
4.71 660ft at 153 mph
7.32 1320ft at 186 mph
634 Chevelle is offline   Reply With Quote
Old 03-20-2013, 10:31 PM   #2
JakesPorting
Member
Pullin gears
JakesPorting's Avatar
Default Re: valve stems
Exhaust valves ?
JakesPorting is offline   Reply With Quote
Old 03-20-2013, 10:42 PM   #3
634 Chevelle
Spooled up
I think a couple exhaust valves had some minor flaking but mostly was just intake
1.11 60ft
3.08 330ft
Old 03-20-2013, 11:34 PM   #4
JakesPorting
Member
Pullin gears
Ive seen quite a few exhaust but it was from heat .
I have seen some Intakes do it also above the guide near the top
of where the moly is fused to the stem and I think it comes from
the valvetrain not being happy as in floating, bouncing , springs
rubbing heads and retainers rubbing rockers .
Old 03-21-2013, 01:28 PM   #5
634 Chevelle
Spooled up
I believe it is the moly coating that is flaking,nothing in valve train is rubbing (jesel rockers), cam profile is easy on springs (.900 lift) and springs are checked regularly, could detanation cause it, the valves are 12 years old .
1.11 60ft
3.08 330ft
Old 03-21-2013, 02:01 PM   #6
spray power
Have seen this with Manley, Victory and Stealth valves mostly.
Most of the reps have said they have fixed there coating problems and they are good now!
When we have seen this we have always replaced the valves, didn't want to take a chance on the coating getting between the valve and guide and haveing a problem or the stem seeing extra heat/where and failing... Good luck..
Auston Pasquith
ACP Performance & Custom Fabrication
Hot Springs, AR.
Custom manifold porting/EFI conversions
Dealer for:
Induction Solutions/ Woody's Pluming/Jerry Bickel Race Cars/RJ Race Cars/Race Parts Solutions/Hyperformance/BTE-Memphis Performance/Strange Eng./FAST Fuel Injection/Schoneck Composites and more!
spray power is offline   Reply With Quote
Old 03-21-2013, 06:47 PM   #7
634 Chevelle
Spooled up
Thanks for the info
1.11 60ft
3.08 330ft
Old 03-23-2013, 03:16 PM   #8
ranger
Member
Pullin gears
Yeah, bad problem with flaking on the exhaust valve right where the stem is exposed at the valve guide. Intake valves flake after awhile, looks like due to wear.
ranger is offline   Reply With Quote
Old 03-23-2013, 04:36 PM   #9
634 Chevelle
Spooled up
It was flaking intake valve stem where it runs in guide. Figured it started flaking due to 13 years of use
1.11 60ft
3.08 330ft
Old 03-24-2013, 01:38 PM   #10
douglas
It is the coating flaking off. For some reason, I've seen it be worse with Manley valves than several others. Manley actually replaced a few for me. BUT come on man, if you have been running the same set of valves for 13 YEARS, what do you expect?!!
douglas is offline   Reply With Quote
Old 03-24-2013, 02:22 PM   #11
634 Chevelle
Spooled up
Wasn't expecting anything just wondering if was missing something Valves are 13 years old but only 25-35 passes a year
1.11 60ft
3.08 330ft
Old 03-25-2013, 08:39 AM   #12
Rodz
Rodz's Avatar
Quote:
After 13 yrs it time to replace flaking or not.
Rodz is offline   Reply With Quote
Resources saved on this page: MySQL 2.15%
