Using Hydraulic Lifters with Solid Lifter Cam - Yellow Bullet Forums
Old 03-14-2013, 08:39 PM   #1
Topfun99
Topfun99's Avatar
Location: Orlando, then Alamogordo, NM, Manchester, TN and back to Orlando!!!!
Default Using Hydraulic Lifters with Solid Lifter Cam
Just curious what experience anyone has running hydraulic lifters on a solid lifter cam.
Basically I have a solid lifter cam that works very well but I figured out that I don't really need solid lifters since I shift the engine at 6500 rpm and have the rev limiter at 6700. Primarily I'm looking to reduce the rocker noise and maintenance for periodic adjustments. I plan to use very high quality hydraulic lifters.
Cam is a Comp Cam street grind with low lash - 248/242 deg duration @.050" and has .640 lift using 1.7 rockers.
I know it will work at least for sometime but I'm concerned about the long term durabiity. If you are not familiar with my car, it's not unusual for me to drive it many miles to the track so I'm concerned about durability.
Thanks.
Racing Means You Are Probably Just As Poor Making $80K A Year As When You Made $5K But Your Car Is Faster.
NMRA 2010, 2012, 2013, 2016 Bradenton True Street Winner
NMRA 2013, 2014, 2016 Bradenton Shootout Winner - 2016 Average 8.323
Thanks to:
TURBO BY GARRETT
HALTECH (Elite 2500)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - RoadTripRacer@aol.com
Topfun99 is offline   Reply With Quote
Old 03-14-2013, 09:13 PM   #2
barnym17
Default Re: Using Hydraulic Lifters with Solid Lifter Cam
I would think the biggest thing is the hyd.lifters will make the cam seem much larger than with the solids.Instead of the lash ramps just taking up clearance in the valvetrain it will begin lifting the valve at that point.It will make the seat to seat timing act like a larger cam.
barnym17 is offline   Reply With Quote
Old 03-15-2013, 02:34 AM   #3
IT427
Burnout box
IT427's Avatar
Are you talking hydraulic roller lifters? Or just hydraulic lifters? A solid lift cam has more spring pressure than a hydraulic and will wipe the lifter/lobe if too much. Dave
Are you the Hunter, or the Prey?
IT427 is offline   Reply With Quote
Old 03-15-2013, 06:16 AM   #4
Topfun99
Topfun99's Avatar
Quote:
Yes, hydraulic rollers and yes, I know I will need to adjust the spring pressure.
Thanks.
Thanks to:
TURBO BY GARRETT
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 03-16-2013, 07:39 PM   #5
NMRA P/S 5090
NMRA P/S 5090's Avatar
in that particular scenario the lobe design itself would bust shit up. springs would be the least of the worries. the flatty/roller camshaft ramps are not even close to being compatible.
randy, i dont know if the lobes would be similar enough to pull that off or not. i know for a fact it works the other way roller to solid i just never saw enough improvement to justify the 300+ bucks spent.
Jared Bemish
OVALTECH PERFORMANCE
Many Many Thanks to: M.C.R.P., UPR PRODUCTS, BULLET CAMS, PAC SPRINGS, INGRAMS MACHINE SHOP, A&G AUTO PARTS, INTELLIFAB and THE CREW !!!!!
8.2 DECK MAFIA
N/A ALL DAY BABY !!!
NMRA P/S 5090 is offline   Reply With Quote
Old 03-16-2013, 08:17 PM   #6
Topfun99
Topfun99's Avatar
Yeah, even though it was going from solid rollers to hydraulic rollers, I thought about it and decided to just get a hydraulic roller cam. I had a spec'd hydraulic cam design before that ran virtually the same number as the current solid so I decided to go back to hydraulic so I don't have to worry about setting valves anymore plus the tick-tick noise.
Thanks to:
TURBO BY GARRETT
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 03-16-2013, 08:51 PM   #7
NMRA P/S 5090
heard that! congrats as well
Jared Bemish
8.2 DECK MAFIA
Old 03-17-2013, 09:01 AM   #8
LilJohn
LilJohn's Avatar
Randy.... theres no need for your motor to have a reverse split camhaft in it. Not with the twins.
There are some lobe designs from comp that can use either lifter.... but odds are on yours the ramps accelleration rates are too high and itll collapse a hydraulic lifter.
Id love to work something up for ya if youre interested.
888-583-4408
www.LilJohnsMotorsports.com
LJMSJohn@gmail.com
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 03-17-2013, 09:31 PM   #9
Topfun99
Topfun99's Avatar
Thanks LilJohn for the info. Honestly, you may be right about the camshaft (it is a Comp Cam) but I'm trying to make things simple and keep everything as they are. I'm simply going to go back to the hydraulic design I had in the engine previously which had virtually the same performance and mileage - a proven design with my combination. The mechanical roller was an "experiment" which showed my that the previous hydraulic roller cam was actually doing quite well - less spring pressure, less maintenance and quieter operation.
Perhaps I could improve performance slightly by testing different cams but honestly, the car weighs 3550lbs, goes 8.40-8.50s and gets almost 18 mpg with both the mechanical roller and the previous hydraulic roller cam - shifting at 6500. I have competitors with cars weighing 200lbs less, bigger cams shifting at 7500, TFS R-box, same boost, etc. that ET the same as I do but at a few more MPH. I'm pleased with my combo already and I'm limited in the resources necessary to try new things right now.
The original posted question is actually a moot point. After getting back from this last trip I ran a compression check and had something going on in the engine so I pulled it yesterday and disassembled it today. Found a bad lifter and wiped lobe - first time I ever had a problem like this in this engine. Don't know if the lobe or the lifter roller went first but their both history. These were high end roller lifters so I suspect the lobe. Hopefully by going back to a hydraulic with less spring rates I won't have this problem again. Fortunately the engine needed to be refreshed so I'm just going to go through it and and make everything fresh.
Now what I need badly is information on a good machine shop in central Tennessee that can hone a block and turn a crank.
Thanks to:
TURBO BY GARRETT
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 03-17-2013, 09:58 PM   #10
RUN-NE1
How many miles on this setup? Also how many miles were you getting out of the hydraulic roller setup?
'91 Mustang Ultra Street/NitrousX/MW8.5RA
Holley EFI
428" SBF BES GV2
12" -4 dry nitrous
Kansas city's Certified Holley EFI reseller.
https://www.facebook.com/KCprotuningandwiring
http://www.kcprotuningandwiring.com/
RUN-NE1 is offline   Reply With Quote
Old 03-17-2013, 10:14 PM   #11
Topfun99
Topfun99's Avatar
Quote:
Good questions, I'll have to check my records. I'm pretty sure the previous hydraulic setup had many more runs/miles on the lifters (stock ford hydraulic rollers) but the hydraulic cam itself I changed once in 2009 to a more aggressive hydraulic roller cam from the original that I initially installed in 2007.
I do know that the hydraulic cam had seat pressure around 135-145lbs and the solid my head guy bumped that up to 200-210lbs so I'm sure the open pressures were similarly higher though I can't remember the number. Obviously the higher seat pressures and mechanical cam characteristics will eat into the life of the valvetrain components as compared to the hydraulic setup.
Thanks to:
TURBO BY GARRETT
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 03-17-2013, 10:16 PM   #12
lightning_2000
Spooled up
lightning_2000's Avatar
http://precisionraceengines.com/
lightning_2000 is offline   Reply With Quote
Old 03-18-2013, 01:06 AM   #13
BLUEOVALRACER
Randy,
I'm sure like you said the hydraulic roller had more miles then then solid roller.I have heard many times street driving is hard on solid roller lifters.Just curious was the solid roller cam faster then the hydraulic roller cam car in your car?
Later Mark.
BLUEOVALRACER is offline   Reply With Quote
Old 03-18-2013, 06:14 AM   #14
Topfun99
Topfun99's Avatar
Quote:
Originally Posted by BLUEOVALRACER View Post
Randy,
Later Mark.
Yeah, I used pressure fed mechanical rollers to help with the durability but still I wouldn't expect the mechanical setup to last as long as the hydraulic.
No Mark, there was not a "step change" in performance. I didn't really select a mechanical roller cam that was significantly larger than the hydraulic roller. At the time I changed over to the mechanical, I was suspicious that the valves were floating at high rpm/boost so we tried the mechanical roller to allow more spring pressure.
Thanks to:
TURBO BY GARRETT
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 03-19-2013, 12:09 AM   #15
BLUEOVALRACER
Maybe not enough RPM for the solid roller to be a benifit over the hydraulic roller?
Later Mark.
