Looking for used Dually - Yellow Bullet Forums
Old 02-05-2013, 10:23 AM   #1
RATATAK
"PRES."(Jus Sayin CREW)
RATATAK's Avatar
Default Looking for used Dually
Need to buy a used Dually to tow race-truck,
Any one have one for sale, would like diesel.
Jus sayin...
http://www.youtube.com/watch?v=Gu8dMERhyzw
http://www.youtube.com/watch?v=qPh1gtT_Rd8
http://www.youtube.com/watch?v=XMm11d3-MH4
http://www.youtube.com/watch?v=uSid8...ature=youtu.be
http://www.youtube.com/watch?v=0-7zA...ature=youtu.be
Weight: 4000 lbs
Owner: Mic Sites
Driver: Mic & Jackson Sites
Crew Chief: Jackson Sites
Engine Tuner: Dave Sealey
Va.Rod Shop: Donald Williams
RATATAK is offline   Reply With Quote
Old 02-05-2013, 10:30 AM   #2
SLOPAR
SLOPAR's Avatar
Default Re: Looking for used Dually
2wd or 4wd?
JW
SLOPAR is offline   Reply With Quote
Old 02-05-2013, 10:30 AM   #3
duce447
Launchin
duce447's Avatar
What yr range, brand, 2dr-4dr, mileage, color, and how much do you want to spend?? That may help your post. There was one on RJ that looked like a good deal. It was in truck and trailer combo. Good luck.
duce447 is offline   Reply With Quote
Old 02-05-2013, 10:39 AM   #4
deliveryman
>x15%= 632ci
deliveryman's Avatar
Deffinately a Ford right??
Jus sayin
deliveryman is offline   Reply With Quote
Old 02-05-2013, 10:40 AM   #5
RATATAK
RATATAK's Avatar
Quote:
Originally Posted by SLOPAR View Post
2wd or 4wd?
JW
2wd
Weight: 4000 lbs
Owner: Mic Sites
Old 02-05-2013, 10:42 AM   #6
RATATAK
RATATAK's Avatar
Quote:
Jus sayin
As. Long as it is road worthy jus for towing,
Not a daily driver, but dependable, I
Will not be choosey
Weight: 4000 lbs
Owner: Mic Sites
Old 02-05-2013, 10:50 AM   #7
RATATAK
RATATAK's Avatar
Quote:
2000 and up, must be road worthy, diesel,
And fairly good shape, no fix-uppers
Weight: 4000 lbs
Owner: Mic Sites
Old 02-05-2013, 10:53 AM   #8
61-4SPEED
61-4SPEED's Avatar
ebay, in texas. you can pick your color too
91 VETTE FOR SALE
THANKS TO:
JK CUSTOM FABRICATION
NEW EAGLE PA
61-4SPEED is offline   Reply With Quote
Old 02-05-2013, 10:54 AM   #9
SLOPAR
SLOPAR's Avatar
Quote:
Originally Posted by RATATAK View Post
2wd
Here is my deal. I have an 01 F350 Dually,Crew Cab with 8ft. bed. 140k miles and clean as a pin. I am trying to lock up a deal on another truck and if this happens I will PM you and see if you are interested.
Thanks,
JW
Old 02-05-2013, 10:56 AM   #10
RATATAK
RATATAK's Avatar
Quote:
Thanks, live in Va. Will look closer to home!
But again thanks for post,,,,,,
Jus sayin...
Weight: 4000 lbs
Owner: Mic Sites
Old 02-05-2013, 11:28 AM   #11
bentwings
Launchin
If you are looking for a diesel 2000 and up relatively low price, consider a 99 to 02 Dodge dually 24 valve with a 5 spd or 6 spd and 4.1 gears. 2wd. It will be nearly impossible to find a 12 valve which would be the ideal. The reasom they are low price is 2wd and the body rusts. But get a Southern truck and it will be fine.
I have one and have just under 300k miles on it. Daily driver 20mpg. 14-15 towing a 12k enclosed trailer.
I drive 58-60 mph 2000 rpm. The most efficient for the Cummins.
You will need to look in the south for a 2wd as the hosrse people use these a lot. Good reason. Very low front end maintenance. You really don't want to have to fix a 1 ton 4wd and it happens. I have only replaced 1 hub/rotor ($200) on my 2wd. I also live in Minn and we do get plenty of snow and cold here. The trick is to have chains and don't go where you are likely to get stuck. The Cummins starts reliably down to -25 without a block heater too.
Absolutely get a manual trans as the autos are an expensive maintenance item. Yes you can get very good rebuilds for any diesel but they really cost. I've only destroyed one clutch and it was $1400 out the door to have a shop repair it. I could have done it myself but I lacked a shop at the time.
This vintage Dodge can be repaired at home pretty easily. There are Dodge boards that have repair fixes for everything that happens to this generation.
Good luck
bentwings is offline   Reply With Quote
Old 02-05-2013, 11:43 AM   #12
RATATAK
RATATAK's Avatar
Good luck
Thanks for the Great Info......
Weight: 4000 lbs
Owner: Mic Sites
Old 02-05-2013, 01:12 PM   #13
nemisish20
Burnout box
At my dealership we have a beautiful diesel dually. check out www.nwhcars.com. Only about an 8 hr ride from you.
nemisish20 is offline   Reply With Quote
Resources saved on this page: MySQL 1.08%
