Best fuel for Nitrous? Ethanol, Methanol or Race Gas - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 02-01-2013, 07:17 PM   #1
EHA Racing
EHA Racing's Avatar
Default Best fuel for Nitrous? Ethanol, Methanol or Race Gas
I have just been wondering about this for a while. If you had a serious NOS engine and have a tight tuning window, what fuel would you run? E85, E98, M5, NOS Race fuel?
I have built 2 boosted combos for customer's lately and they are both E85 powered. It seems very cost effective over race gas and you are really able to turn up the wick over regular gas. It seems to be very forgiving for what it is.
Doug Vanstrom / P4046
SBF 114mm Turbo
4.67 @ 162.8 on 275's
7.51 @ 186 1/4 on 29's
www.vanstromperformance.com
www.eha.us.com
www.ultimateconverters.com
www.penngrade1.com
Quote:
Originally Posted by morris View Post
You want to go Bruder fast, Jackson fast it is from the flywheel back.
EHA Racing is offline   Reply With Quote
Old 02-01-2013, 07:43 PM   #2
10.5
10.5's Avatar
Default Re: Best fuel for Nitrous? Ethanol, Methanol or Race Gas
I started running E85 in 2008 in a sbf, then in the winter of that year, I switched to E98 and stayed with that until last year. I sold my sbf stuff and got a bbc. Started on E98, and sprayed a 32N in each of two systems (roughly 550-600 hp total worth of nitrous). I felt I had the fuel tune pretty close, but it showed a little heat in the plugs with a fairly low timing number for a conventional headed bbc. My fuel supplier didn't have E98 for awhile, so once I ran out, I switched to C23, then to C16. I feel that I have the fuel tune-up pretty close to where it was before, yet I don't have ANY heat in my plugs now. I'm still adding a slight amount of timing each time I go to the track and it keeps picking up. With the way the plugs looked on ethanol, I don't think I would have added the timing that I have now. I don't know if I had reached the "limit" of the fuel, or if I should have fattened it up more. I kinda wish I had tried adding fuel to the tune and see if it picked up, but now I've bumped up the N pill a little more and feel that I have a handle on my race gas tune better than the ethanol tune at this point.
So, to answer your question, I think I would run race gas if you are spraying a healthy amount and are not trying to "learn" anything with the fuel.
I like being different, so I would love to get back on ethanol with a boat-load of spray, but don't want to risk hurting my engine to do it.
10.5 is offline   Reply With Quote
Old 02-01-2013, 07:49 PM   #3
sixty feet
sixty feet's Avatar
C23
Brent Daniel
sixty feet is offline   Reply With Quote
Old 02-01-2013, 09:09 PM   #4
EHA Racing
EHA Racing's Avatar
Thanks 10.5 and sixty feet. Anybody else have an opinion? I'd like to get as much insight as possible as to what people are using and why.
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
Old 02-02-2013, 08:51 AM   #5
EHA Racing
EHA Racing's Avatar
Dang I thought this would be a decent discussion lol.
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
Old 02-02-2013, 10:37 AM   #6
10.5
10.5's Avatar
Not many with experience with ethanol
Old 02-02-2013, 11:44 AM   #7
EHA Racing
EHA Racing's Avatar
Quote:
Surely there are more than two.
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
Old 02-02-2013, 08:05 PM   #8
nitrousbusa569
Spooled up
nitrousbusa569's Avatar
We found limitations with E85 and E98 when running big nitrous on our bike tunes.....Went to C23 and was able to clean up the tune nicely
nitrousbusa569 is offline   Reply With Quote
Old 02-02-2013, 09:44 PM   #9
EHA Racing
EHA Racing's Avatar
That's good to know. I really thought the cooling effects of alcohol would open up the tuning window more.
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
Old 02-02-2013, 09:54 PM   #10
1970 Mustang
1970 Mustang's Avatar
i have had really good luck with the Renegade pro 120 nitrous fuel, have used c12,c14c16 no2 sunoco max and sunoco max nos, sbf
SBF GV2headed nitrous motor for sale
1970 Mustang is offline   Reply With Quote
Old 02-03-2013, 09:04 AM   #11
10.5
10.5's Avatar
Quote:
Don't get me wrong, I love ethanol and think it's a great fuel to run, and you are basically getting "race gas" quality fuel for cheaper than 87 octane pump gas. In that respect, it's a wonderful thing. However, I do think that you do run into limitations with this fuel before you run into limitations with high octane race fuel. I would love to do more experimenting with the fuel to figure more out about it, but timing number for timing number, a/f ratio to a/f ratio, race gas is more forgiving than ethanol from what I've found so far with my big block.
Old 02-03-2013, 10:19 AM   #12
Monte Smith
The nitrous guy
Anything you can buy out of the pump at your local station is "pump gas" and is such is NOT blended as a performance fuel and that is all you need to know about that type fuel.
As for pure methanol or M5............alky has proven to NOT be a good nitrous fuel for large amounts of spray. The sheer mass of fuel needed, to achieve the needed BTUs to go with the added nitrous, just make it a poor choice.
Look at it this way............the TOP nitrous classes are not fuel limited...........they can run whatever fuel they want and gasoline is the choice..........for a reason.
Monte
Monte Smith
Motorsports Technical Representative
Nitrous Oxide Systems
www.montesmithperformance.com
gtxmonte@msn.com
ph. 256-783-3418
Monte Smith is offline   Reply With Quote
Old 10-27-2014, 03:07 AM   #13
makc11
Burnout box
makc11's Avatar
what about e85 on 200-300 shot?
355
makc11 is offline   Reply With Quote
Old 10-27-2014, 08:34 AM   #14
EHA Racing
EHA Racing's Avatar
Quote:
We sprayed a .030 jet on E85 for a whole season. Never had a single problem.
.030N / .026F with 5.75 psi and 23 timing. 9.00 @ 150 on a stock block SBF 408 daily driven street car on 275's.
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
Old 10-27-2014, 08:41 AM   #15
EHA Racing
EHA Racing's Avatar
With my max effort deal we used Renegade 120N. Many of my friends and customers switched from VP Nitrous fuel to Renegade. All had their personal bests by a long shot this year.
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
