A2W Questions - Yellow Bullet Forums
Old 01-03-2013, 03:00 PM   #1
blubu
Spooled up
blubu's Avatar
Default A2W Questions
I'm wanting to mount my a2w IC up front and behind the bumper of my camaro. It's 3.5" I/O and I wanted to mount in the front driver side and that would leave it at a weird angle. The I/O for the water is also on the same side. This is all new to me, would there be anything I need to avoid?
TIA, Josh
78 Malibu SBE 6.0/PG/A2W/S475/E85 Rusty sumbitch
Tuned By Bluecat
blubu is offline   Reply With Quote
Old 01-03-2013, 03:06 PM   #2
LilJohn
LilJohn's Avatar
Default Re: A2W Questions
Just make sure the water outlet is the higher of the two fittings.... or if the are on the same end... that that end is higher than the other.
Can you snap a pic if what yiur talking about?
888-583-4408
www.LilJohnsMotorsports.com
LJMSJohn@gmail.com
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 01-03-2013, 03:11 PM   #3
Static
Launchin
Static's Avatar
I mounted my A2W in a similar position and drilled for a bleeder to remove all the air. Once bleed it seems to work quite well.
1989 Mustang 427W - F2 - Pump Gas
"If it's not custom....someone else has it"
2012 Drag Week Street BB Power Adder - 71 Nova
Static is offline   Reply With Quote
Old 01-03-2013, 04:17 PM   #4
blubu
Spooled up
blubu's Avatar
I'm at work, but it looks like this. Drill the highest point once positioned?
Tuned By Bluecat
Old 01-03-2013, 04:23 PM   #5
Static
Launchin
Static's Avatar
Not the best shot but you get the idea. The bleeder was drilled at the highest point on the backside of the tank. Also not saying its the right way to do it just saying its how I did it.
Old 01-03-2013, 08:13 PM   #6
blubu
Spooled up
blubu's Avatar
I was looking at yours the other day. Looks good! I don't want to run pipes in the car righ now so I figured I'd make an attempt at this.
Tuned By Bluecat
Resources saved on this page: MySQL 2.35%
