Cma for a nitrous 5.3?? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 11-20-2012, 09:42 AM   #1
Dragpny
Member
Pullin gears
Dragpny's Avatar
Default Cma for a nitrous 5.3??
I'm putting together a JY 5.3 setup and was wondering what size cam to use for a 150 shot. Its going in a 2700# foxbody. Just going to use it till my 6.0l is finished. Its a carb set up with front mount distributor/powerglide. Thanks.
92 Mustang
25.5
LS Powered on the Spray
Powerglide
Dragpny is offline   Reply With Quote
Old 11-20-2012, 11:18 AM   #2
WhiteLTone
Spooled up
WhiteLTone's Avatar
Default Re: Cma for a nitrous 5.3??
Pm 1quickbird. He has some wicked custom grinds for these motors and nitrous. See sig below.
stock cube bottle baby.. 8.75 @ 153.7 - 5.58 @ 124 - 1.23 60' built by LEGEND RACING ENT
Stock junk- LRE prepped SBE 6.0, 799 heads with a WORK cast 80mm turbo.
Typical SBE junk.
WhiteLTone is offline   Reply With Quote
Old 11-20-2012, 11:29 AM   #3
LilJohn
LilJohn's Avatar
231/243 @.050. 114+5
888-583-4408
www.LilJohnsMotorsports.com
LJMSJohn@gmail.com
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 11-20-2012, 05:35 PM   #4
ZONES89RS
ZONES89RS's Avatar
If you want a cheap temporary setup, the edelbrock 2116 cam is not bad at all. Made specific for carbed LS.
ZONES89RS is offline   Reply With Quote
Old 11-20-2012, 06:17 PM   #5
SickSilverado
Member
Pullin gears
Are you sure that edelbrock cam will perform ok? It has such low lift compared to the more popular/common cams.
Just an old truck with an old motor.
LSXCTTFMF
And I don't know O where I'm goin'. I just want to be...left alone.
SickSilverado is offline   Reply With Quote
Old 11-20-2012, 09:16 PM   #6
ZONES89RS
ZONES89RS's Avatar
Yep, it will do fine if you are not trying to squeeze every ounce of power from it.
Old 11-21-2012, 08:06 AM   #7
Ed Curtis
Ed Curtis's Avatar
Quote:
You won't need much of a grind. That Fox is super light. Let me know if you want something that'll work. I've done quite a few just like that.
Ed Curtis is offline   Reply With Quote
Old 11-21-2012, 10:02 AM   #8
Widow_Maker
Chupa Cabra
Widow_Maker's Avatar
231/238 .617"/.615" 111+3
You've got a single plane and a carb, needs a tighter LSA and ICL than most other cams would, and on top of that you're only spraying a 150 shot which does not need a dedicated nitrous grind or anything that resembles a cam that is intended for heavy nitrous use.
RTCTTFMF!!!
5.14@137.49 (1.21 60') True Street 275 (3290# RW) SOLD
Smallwood Race Developement
Mcleansville, NC
864-723-2892
Widow_Maker is offline   Reply With Quote
Old 11-21-2012, 10:28 AM   #9
Dragpny
Member
Pullin gears
Dragpny's Avatar
How much would I be able to spray before I would need a dedicated cam? What is the limit on a stock bottom end 5.3?
92 Mustang
25.5
Powerglide
Old 11-21-2012, 10:32 AM   #10
Widow_Maker
Chupa Cabra
Until you're spraying 300 or more I don't see the need for a dedicated nitrous grind that would resemble your typical nitrous grind.
If your tune-up is spot on I don't see why you couldn't spray 250-300hp through one. I put 260rwhp worth of jet through mine very frequently with no issues so far.
RTCTTFMF!!!
Mcleansville, NC
864-723-2892
Old 11-23-2012, 12:00 PM   #11
Oneslowbird
Pre-Staged
You guys and this plus 3 plus 4 bullshit. How about you grind the cam straight up and degree it in to the exact numbers you want? Oh wait, probably never touched a degree wheel eh?
Oneslowbird is offline   Reply With Quote
Old 11-23-2012, 02:38 PM   #12
LilJohn
LilJohn's Avatar
Quote:
Hardly... did it ever dawn on you some people dont use adjustable timing sets?
888-583-4408
LJMSJohn@gmail.com
Old 11-23-2012, 03:56 PM   #13
blackonblacksls
I'm sure they will come in here and have some bullshit excuse but the cam gurus around here probaby never even touched the insides of a ls motor. They be and experts by talking to people on the web and read about shit. Not really building anything.
blackonblacksls is offline   Reply With Quote
Old 11-23-2012, 04:26 PM   #14
72chevy2
72chevy2's Avatar
We've had better results keeping the duration down and using a moderate lift. FWIW
72chevy2 is offline   Reply With Quote
Old 11-23-2012, 05:42 PM   #15
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Quote:
Such as me.
Haley Racing Products
270-784-1534
www.haleyracingproducts.com
PM me about the RJS safety equipment special I'm offering from April 1st to June 30th!
"I have no idols. I admire work, dedication, and competence." - Ayrton Senna
JHaleyH374 is offline   Reply With Quote
