03 Dodge 4.7 Magnum overheating issues? - Yellow Bullet Forums
Old 11-19-2012, 06:33 PM   #1
GRUBBY
Ass, Gas or Grass
GRUBBY's Avatar
Default 03 Dodge 4.7 Magnum overheating issues?
What goes bad on these things? Its in a Ram truck. Not sure of the milage. Its had a new waterpump and thermostat put in it already. I guess it ok if ya drive around town but if ya go out of town a few miles it gets hot. This is my buddys truck, I havent had a chance to look at it yet, just going by what he has told me. Any ideas?
The ladies call me COFFEE, cause I GRIND so FINE...
R.I.P
Rob Ludwig
The BEST bro that ever walked the face of the earth. See ya on the other side.
GODSPEED Coops!
Quote:
jimmylauri sez
FREE JIMMY LAURI
GRUBBY is offline   Reply With Quote
Old 11-19-2012, 06:49 PM   #2
projoe87
Default Re: 03 Dodge 4.7 Magnum overheating issues?
Possible Head, I had that with my wifes old truck, had a blown headgasket. Make sure it has no air in system.
projoe87 is offline   Reply With Quote
Old 11-19-2012, 07:11 PM   #3
Malibuwagon80
Spooled up
Malibuwagon80's Avatar
mine had a cracked radiator!
Malibuwagon80 is offline   Reply With Quote
Old 11-19-2012, 07:46 PM   #4
ITSNOTFASTENOUGH
Launchin
ITSNOTFASTENOUGH's Avatar
Cooling fans are bad to go out. The motor plug is straight up and water gets in and corrodes the pins. Probably popped a 20 amp fuse
83 CUTLASS
3250lbs
5.40s with a backseat.
ITSNOTFASTENOUGH is offline   Reply With Quote
Old 11-19-2012, 07:49 PM   #5
ScreamingSnake
Pre-Staged
ScreamingSnake's Avatar
Head gasket most likely. Those were a common problems with 4.7's especially ones that get ride a little rough or haul loads
Some backwoods 4-banger tuned by a dealership dropout
ScreamingSnake is offline   Reply With Quote
Old 11-20-2012, 12:29 AM   #6
slammed1
slammed1's Avatar
The cooling fan that pops the fuse effects the ac,and usually wont cause overheating.Those engines are known for headgasket issues after about 75k miles if not serviced good. Sometimes even if serviced good headgaskets will have issues,sometimes bad enough that the coolant cuts grooves in the aluminum heads.The radiators also have tank cracking issues as stated above but usually dont create overheating,just blowing out at inconvenient times.....like mine did halfway between FtSmith Ark and Dallas Texas on a Sunday.
Brian M
1980 Camaro,1966 BelAir,2004 Dodge Ram HEMI on 42" tires,72 Chevy Short Wide project
2 door post website,check it out
http://twodoorpost.activeboard.com/
http://i886.photobucket.com/albums/a...mePhoto6-1.jpg
slammed1 is offline   Reply With Quote
Old 11-20-2012, 04:06 AM   #7
Abodyjohn88
Abodyjohn88's Avatar
Lots of probloms with cracked heads inbetween the valves on magnum motors
Abodyjohn88 is offline   Reply With Quote
Old 11-20-2012, 06:39 AM   #8
projoe87
My old 03 ram had same issue, would hold pressure in cooling system for quite a few hours after cooled down, piss out coolant from overflow, did this for few weeks, I did a block test and found it had a exhaust in coolant. Traded it in quickly before anyone knew. Was a good truck with no problems till that.
Old 11-20-2012, 06:46 AM   #9
deucebag
deucebag's Avatar
Does it have a clutch type fan? I had one where the fan wouldnt lock up and caused iverheating, but probably head gasket
deucebag is offline   Reply With Quote
Old 11-20-2012, 07:34 AM   #10
mcfomoco
Burnout box
mcfomoco's Avatar
Radiator is most likely clogged up... If it's overheated much over half way be ready to replace the head gaskets also. It does not take much to warp these heads at all.
mcfomoco is offline   Reply With Quote
Old 11-20-2012, 08:18 AM   #11
GRUBBY
Ass, Gas or Grass
GRUBBY's Avatar
Thanks guys Ill check it out later tonight and see whats up with it.
R.I.P
Rob Ludwig
GODSPEED Coops!
Quote:
jimmylauri sez
FREE JIMMY LAURI
Old 11-20-2012, 08:47 AM   #12
KEVIN S
Member
Pullin gears
Quote:
I would do a block test for sure. I have seen several of these turds with blown head gaskets. Its likely a very small leak so even if it passes the block test don't rule it out. The electric fan on the drivers side is a condenser fan,while it does often pop the fuse it isn't what's causing you concern. I have had sever trucks with clogged radiators as well. It is very easy to back flush the radiator with a water hose and check the flow.
FWIW. We had a customer that didn't want to fix his truck so we tried a high end block sealer(don't remember the name but it was like $75) and it indeed repaired his leak and has been going strong ever since(2 years). If it were my truck I would just repair the truck the right way. Make sure you have the head decked and checked for cracks. KS.
KEVIN S is offline   Reply With Quote
Old 11-20-2012, 09:31 AM   #13
Ranger50
Launchin
Quote:
What he said.
"Never trust an intelligent man with no money to play fair."
<nitrous_mike> Wash those panties out so there aint gonna be no sand in the clam excuse and whining.
Ranger50 is offline   Reply With Quote
Old 11-20-2012, 09:35 AM   #14
dirty chin
Spooled up
What about the air deflector on the bottom of radiator support?
dirty chin is offline   Reply With Quote
Old 11-20-2012, 10:36 AM   #15
bbnova
Head gaskets
bbnova is offline   Reply With Quote
