Carb problem. Car won't idle in gear. - Page 2 - Yellow Bullet Forums
Old 11-16-2012, 08:42 AM   #16
EHA Racing
EHA Racing's Avatar
Default Re: Carb problem. Car won't idle in gear.
Quote:
Originally Posted by elle View Post
I had the same prob with a new carb. I called the builder and removed some type of screw he had installed and it ran fine after that. It was a few years ago and i can't remember what it was called and i am the furthest thing from a carb expert, sorry.
My Pro-Systems had that same secondary idle circuit. When I was having an issue Patrick told me to remove it. Difference was night and day!
Doug Vanstrom / P4046
SBF 114mm Turbo
4.67 @ 162.8 on 275's
7.51 @ 186 1/4 on 29's
www.vanstromperformance.com
www.eha.us.com
www.ultimateconverters.com
www.penngrade1.com
Quote:
Originally Posted by morris View Post
You want to go Bruder fast, Jackson fast it is from the flywheel back.
EHA Racing is offline   Reply With Quote
Old 11-16-2012, 08:47 AM   #17
55sedan
55sedan's Avatar
Whats the timing set at? Sounds like very low timing to me and your trying to compensate with carb settings. JMO
BBC P/Glide 12 Bolt on Leafs
55sedan is offline   Reply With Quote
Old 11-16-2012, 08:48 AM   #18
Dan Neumann
Bring on the Metal!!
Dan Neumann's Avatar
Quote:
Originally Posted by GT 350 View Post
look at the tach when it drops in gear and see how far the rpm drops...on mine it runs till it hits 1200 rpm but if the rpm drops below 7 it resets..what system is on it and i will look to see in my files on what his syatems works like
It's a 7531 box. The carb is a Quickfuel Dominator with billet this and that and 3 adjustable bleeds next to each venturi. Converter spacing is perfect (I put this car all together and I know to make sure it's correct). Converter is not too tight, in fact it's much looser than the first one we had in it but still does the same thing. I agree with those saying it's too lean. We looked for vacuum leaks but not real intensively. The intake was recently off to add a second fogger to it so it's possible.
It's not how much you spend, but how well you spend it."
www.danneumannracecars.com
You can also follow us on Facebook for more up to date news and pictures.
Dan Neumann Race Cars LLC
Dan Neumann is offline   Reply With Quote
Old 11-16-2012, 08:49 AM   #19
elle
Quote:
YUP!!! That was it. I also had a Pro Systems.
elle is offline   Reply With Quote
Old 11-16-2012, 08:50 AM   #20
splitbumper
splitbumper's Avatar
Quote:
agree with that...also the front butterflies might be opened up pass the idle transfer slots...might help to open your rears a bit more
possibly small holes needed in the butterflies?????
splitbumper is offline   Reply With Quote
Old 11-16-2012, 08:53 AM   #21
Dan Neumann
36 degrees total,locked.
Old 11-16-2012, 09:17 AM   #22
indasevens
***INDASIXES***
indasevens's Avatar
I am thinking it somehow needs more fuel down low??? But I know nothing about carbs......Dan, lets make it fuel injected!!!! Then I can help..
indasevens is offline   Reply With Quote
Old 11-16-2012, 09:22 AM   #23
55sedan
55sedan's Avatar
I had problems with a MSD box last year. What I thought was 36* was actually 11*
Im guessing it would retard 25* at startup and never return to full setting.
When cking with light it showed 36* After changing box (didnt touch the dist.) It showed 11*
Changed out the box (after MSD cked it and said nothing was wrong with it) and problem solved.
Hope this helps.
Old 11-16-2012, 09:26 AM   #24
grubb racing
grubb racing's Avatar
2 1/2 turns out on the idle screws sounds as that damn thing should be bloody rich at idle.....what is the idle egt. temp....im going with vacume leak somewhere do the ole wd 40 test see if motor revs when u spray it around intake or carb....
grubb racing is offline   Reply With Quote
Old 11-16-2012, 09:32 AM   #25
Dan Neumann
Hope this helps.
We've ran the car so far on one 200hp stage and it ran 5.09. The box is new and I don't believe it's the problem. It use to idle fine in and out of gear till the intake was pulled and re-installed. (done by someone else) so it's very likely it could be a vacuum leak. That will probably be my first thing to check.
Old 11-16-2012, 09:34 AM   #26
Paulie9fingers
Gettin' tired of the shit
Paulie9fingers's Avatar
Does the idle change much or at all when you turn the idle mixture screws ? Like was mentioned earlier, make sure the throttle blades are adjusted so that at idle they have the same gap between the blade and the body, you may have to close up the primary and open the secondary or vise versa. If adjusting the idle screws don't change the idle much then it may be because you have over exposed the idle slots. Because the blades are open to far, it doesn't allow the carbs idle circuit to properly draw fuel through the idle slots. You can remedy that by drilling a small hole near the air cleaner boss and threading it for an air bleed. This will allow you to close up the throttle blades and still provide additional air as if they were still open. The air bleed allows you to adjust the amount of additional air without having to drill the hole larger and larger until you get it right.
If winning was easy, everyone would be doing it
Paulie9fingers is offline   Reply With Quote
Old 11-16-2012, 09:41 AM   #27
hoffmansgold
Does it have a vacum pump? If so the guy might have forgot to glue the intake gaskets in place. It might have sucked the gasket out the bottom of the intake
Quote:
hoffmansgold is offline   Reply With Quote
Old 11-16-2012, 09:52 AM   #28
55sedan
55sedan's Avatar
I agree, sounds like your headed in the right direction.
Old 11-16-2012, 09:56 AM   #29
buschmec
First round fodder...
buschmec's Avatar
Pull the intake.....you have a vacuum leak
Working to make her faster....4.90@139
Thanks to Troy Balsters, Greg Buschmeyer , Rick Vineyard , John McDonough, Mike and Ty Chaney, Chris and Jolene Bryant, and many others.
buschmec is offline   Reply With Quote
Old 11-16-2012, 09:59 AM   #30
GT 350
Grizzly
On that box the retard is automatic on start retard it stops at800rpm and resets when it drops below 500..just use the kiss method and you will find it even if it is a vacume leak break out the carb cleaner while its running it it will find it easy enough
GT 350 is offline   Reply With Quote
