Carb problem. Car won't idle in gear. - Yellow Bullet Forums
Old 11-16-2012, 08:51 AM   #1
Dan Neumann
Bring on the Metal!!
Dan Neumann's Avatar
Default Carb problem. Car won't idle in gear.
Looking for some carb insight from the masses. I have a customer who's got a 585 BBC Steve Schmidt motor in his car. It has a Quickfuel dominator on a Sniper intake and 2 foggers plumbed into it. Out of gear the car runs and idles fine once it's got some heat in the motor but as soon as you pull it into gear it refuses to run without peddling the throttle. The motor runs great otherwise. The 4 corner idle screws are about 2 1/4 turns out each which seemed to provide the best idle quality out of gear but it seems no matter where I put those screws it still won't idle in gear. Any ideas on what I should change or look for? Thanks.
It's not how much you spend, but how well you spend it."
www.danneumannracecars.com
You can also follow us on Facebook for more up to date news and pictures.
Dan Neumann Race Cars LLC
Dan Neumann is offline   Reply With Quote
Old 11-16-2012, 08:52 AM   #2
gatsby1219
Void
gatsby1219's Avatar
Default Re: Carb problem. Car won't idle in gear.
locked up converter ?
gatsby1219 is offline   Reply With Quote
Old 11-16-2012, 08:54 AM   #3
timcasbolt
timcasbolt's Avatar
It sounds lean.
timcasbolt is offline   Reply With Quote
Old 11-16-2012, 08:58 AM   #4
GT 350
Grizzly
Does it have a start retard ...nitrous converters are tight if the rpm falls below a certian rpm it drops 20 deg or what you have the ignition set up
GT 350 is offline   Reply With Quote
Old 11-16-2012, 09:00 AM   #5
1QwikBu
1QwikBu's Avatar
sounds like a converter problem to me
Quote:
Originally Posted by YB Dwayn View Post
Right, but you will gladly sit there rape, pillage and free load off the site that has given you the best online platform to talk about racing.... and still complain about it.
we're all just freeloaders
R.I.P COOPS
1QwikBu is offline   Reply With Quote
Old 11-16-2012, 09:07 AM   #6
Dan Neumann
Second converter and does it with both. Both Neal Chance converters.
Old 11-16-2012, 09:13 AM   #7
Dan Neumann
Quote:
I didn't think about that. But will the start retard reactivate once the car's been started and reached it's shut off RPM? Or does it have to be turned off to restart that feature?
Old 11-16-2012, 09:16 AM   #8
JimL
JimL's Avatar
Do you have clearence between the converter and the flex plate before you bolt it up?
JimL is offline   Reply With Quote
Old 11-16-2012, 09:20 AM   #9
Power Mad Racing
Power Mad Racing's Avatar
vacume leak ?????
Power Mad Racing
S & E Performance
2013 OUTLAW 632 CHAMPION
Power Mad Racing is offline   Reply With Quote
Old 11-16-2012, 09:21 AM   #10
big green
Member
Pullin gears
convertor is to tight
superior transmission
big green is offline   Reply With Quote
Old 11-16-2012, 09:22 AM   #11
willisonTfosdik
DamCoonass
willisonTfosdik's Avatar
Man it's hard to fix stuff like this over the internet.
It PROBABLY has a carb that's out of whack from people turning a screw here & a screw there trying to get it to idle.
It sounds way lean to me at idle.
Check the basics 1st.
willisonTfosdik is offline   Reply With Quote
Old 11-16-2012, 09:27 AM   #12
EHA Racing
EHA Racing's Avatar
Do you have any air holes in the butterflies? I've had it happen before where the signal was too low at idle. It was either the slots covered too much front or rear, or we needed to drill some small holes in the butterflies.
Doug Vanstrom / P4046
SBF 114mm Turbo
4.67 @ 162.8 on 275's
7.51 @ 186 1/4 on 29's
www.vanstromperformance.com
www.eha.us.com
www.ultimateconverters.com
www.penngrade1.com
Quote:
Originally Posted by morris View Post
You want to go Bruder fast, Jackson fast it is from the flywheel back.
EHA Racing is offline   Reply With Quote
Old 11-16-2012, 09:28 AM   #13
gene116
gene116's Avatar
Quote:
Originally Posted by Power Mad Racing View Post
vacume leak ?????
^^^ ...would be my first path to go down !
gene116 is offline   Reply With Quote
Old 11-16-2012, 09:30 AM   #14
GT 350
Grizzly
Quote:
look at the tach when it drops in gear and see how far the rpm drops...on mine it runs till it hits 1200 rpm but if the rpm drops below 7 it resets..what system is on it and i will look to see in my files on what his syatems works like
Old 11-16-2012, 09:41 AM   #15
elle
I had the same prob with a new carb. I called the builder and removed some type of screw he had installed and it ran fine after that. It was a few years ago and i can't remember what it was called and i am the furthest thing from a carb expert, sorry.
elle is offline   Reply With Quote
