Ultimate street rules for Feb - Yellow Bullet Forums
Old 11-11-2012, 09:37 PM   #1
JasonSmith
JasonSmith's Avatar
Default Ultimate street rules for Feb
MEDIA 1 & BILLET ATOMIZERS
ULTIMATE STREET @ LIGHTS OUT 4 SOUTH GEORGIA MOTORSPORTS PARK FEB 22-24TH
BILLET ATOMIZER INJECTORS
MEDIA ONE
ULTIMATE STREET
...32 CAR FIELD (200.00 TECH CARD)
5,000.00 WIN
1000.00 R-UP
300.00 SEMIS
200.00 1/4'S
Ultimate Street street is a heads up class designed for any passenger vehicle from any major manufacturer. Ultimate street cars are limited to a maximum cubic inch limit of 440 cubic inches.
Fiberglass/Carbon body panels are allowed. No one piece front ends. Cowl hoods may not be taller than half way point of the windshield. Forward facing scoops are prohibited.
Racers may have forward scoop if completely sealed/plugged.
INTERIOR
Aftermarket steering columns are allowed.
ELECTRICAL
Optical devices are prohibited. All entries must have operational head lights and tail lights.
ENGINE
SMALL BLOCKS ONLY
Aftermarket blocks and cylinder heads are allowed. Entries may utilize a single carburetor or single throttle body (4150,4500 mounted) Motor plates and solid mounts are allowed. Engine must be in stock location. Mufflers are required on all vehicles except turbo entries. Entries must utilize a single stage nitrous plate with one nitrous, one fuel and one redundant purge solenoid. Foggers must be disconnected and all solenoids must be capped off. Nitrous plates using fogger nozzles are not allowed. All engines are limited to 440 cubic inches. Any engine in question will be measured with a P&G gauge. A correction factor of 1.5% will be used. Competitors may be asked to remove a cylinder head for bore and stroke measurements should any discrepancies arise.
POWER ADDERS
Nitrous - Progressive nitrous controllers are allowed.
SUPERCHARGERS AND TURBO ENTRIES MUST BE STOCK VALVE ANGLE ENGINES ONLY. NO ENTRY MAY HAVE ANY DEVICE TO DIRECT AIR INTO TURBO OR SUPERCHARGER PERIOD. NO CUTTING OF ANY HOLES ON FRONT END. STOCK FRONT ENDS WITH GRILLS/SLOTS ETC. ARE ALLOWED
WITH NO MODIFICATIONS PERIOD. A 50# WEIGHT PENALTY WILL BE ADDED FOR THESE COMBINATIONS IF TURBO/SUPERCHARGER IS FORWARD MOUNTED BEHIND GRILL/SLOTS/ETC
BOOSTED CARS MAY NOT USE ALCOHOL OR ANY OXYGENATED FUELS.( Q-16 ETC...).. ALL SUPER CHARGERS AND TURBOS MUST BE ORIGINAL FROM FACTORY AND TRUE SIZE.. NO REDUCERS OR BILLET WHEELS.
NO E-85 ETC. IN ANY CLASS
SB CHEVY STANDARD 23 DEGREE(NO RAISED RUNNER)
SB FORD 20 DEGREE(NO SR20-FT1 OR T1RI OR EQUIVALENT)
FACTORY HEADED SMALL BLOCK FORD MOD MOTOR
SUPERCHARGER MAX
- 50 # FOR ANY SUPERCHARGED ENTRY THAT IS BELT DRIVEN
- 50 # FOR NON INTERCOOLED
F1A-3200 #
F1C - 3250 #
YSI - 3250 #
TURBO MAX
MID FRAME
T-76 3100 # NO REDUCERS
T-80 3200 # NO REDUCERS
TRANSMISSION
Any OEM style automatic or OEM manual transmission is allowed. Manual transmissions must utilize an SFI approved bell housing.
REAR SUSPENSION
Stock type rear suspension only. Coil over shocks are allowed. Aftermarket replacement control arms are allowed.
WHEELS/TIRES
M/T TIRE PART # 3754R ONLY
WEIGHTS>
N/A SB 2700 lbs
Base weight - 3200 lbs
All heads 14.9 and under - 3250 lbs
Any canted valve head - 3250 lbs
All heads 15 degrees and above carry no additional weight
STANDARD 23 degree combo - 3000 lbs
Any 23 RAISED RUNNER or Equivalent– 3150 lbs
BLUE THUNDER HEADS - 3250 lbs
STANDARD 20 degree ford - 3000 lbs
ANY 20 DEGREE SR20-FT1 OR T1RI OR EQUIVALENT -3150 lbs
C3 OLD STYLE YATES,C302,C302B - 3100
`NO BILLET CYLINDER HEADS
Leaf springs -100#
V-6 -200 #
4150 CARB – 50LBS
5.152 @136.68 2850lbs 23 deg 408 with a plate
JasonSmith is offline   Reply With Quote
Old 11-11-2012, 09:46 PM   #2
88mmRocket
88mmRocket's Avatar
Default Re: Ultimate street rules for Feb
If RR heads are not allowed at why even have the weight hit written in there?
stock block junk
B&K Performance
Ultimate Convertor Concepts
LJMS
A veteran is someone, who at one point in his or her life, wrote a blank check made payable to the United States of America for an amount of "Up to and including my life."
Thank you for those who have served and continue to serve.
88mmRocket is offline   Reply With Quote
Old 11-11-2012, 09:51 PM   #3
UgotBeat
Member
Pullin gears
Weight penalty is just for the nitrous combos
UgotBeat is offline   Reply With Quote
Old 11-12-2012, 08:05 AM   #4
79pacecarmod
DEAMON TWEAKER
79pacecarmod's Avatar
Glad I did run out and get new T1 heads.
And I get to loose 50# works for me.
1979 mustang pace car
Cameron's Torque Convertor Services
5.03 141MPH
June 08 modified mustang feature car
http://www.mustangandfords.com/featu...ang/index.html
WWW.DAMNYANKEESRACING.WEBS.COM
79pacecarmod is offline   Reply With Quote
Old 11-12-2012, 08:07 AM   #5
UgotBeat
Member
Pullin gears
John had stated if the weight penalty needs to be adjusted he will do just that....im not sure if donald will do the same?
Old 11-12-2012, 08:25 AM   #6
79pacecarmod
DEAMON TWEAKER
Quote:
Agreed I do think it a litte over the top but time will tell.
5.03 141MPH
Old 11-12-2012, 09:19 AM   #7
turbotbirds
turbotbirds's Avatar
DAMN, still no E85! Sucks for me again, guess I'll never get to go!
275 True Street (CHRA), Street Race (KOTS), Ultra/Ultimate SBC Methanol Blowthru
Forced Inductions Billet 76mm
LJMS Custom camshafts
5.01@ 140
turbotbirds is offline   Reply With Quote
Old 11-12-2012, 09:24 AM   #8
n8secstangg
n8secstangg's Avatar
No e85 will keep me out in the future
ULTIMATE STREET PROJECT..... GAME ON!!!!....OOPS....game off I guess
363" TFS High Ports,EFI, M1 and an S480
4.842@156 and 7.53@192 on drag radials
NOW A DEALER FOR
Kaenen Composites
Champion Wheels
Big Stuff 3
Lightning Force Performance
NLR Systems
Racecraft Inc
Speedwire Systems
n8secstangg is offline   Reply With Quote
Old 11-12-2012, 10:41 AM   #9
nitrooneshot
Full Force Racing TTFMF
nitrooneshot's Avatar
I would've liked to see Q-16 allowed
Powered By Shine and M1
Bruder Brothers Racing
HALTECH EFI systems
ATFSPEED.COM
Forced Induction, LJMS
Keesey's Airport Auto Team NORTH
R&S Auto Specialties
Accelerated Motorsports
You just can't Boost a Big CID the Same!!
First to the 4's in Ultra!!
nitrooneshot is offline   Reply With Quote
Old 11-12-2012, 10:47 AM   #10
dadsnova69
dadsnova69's Avatar
MEDIA ONE
ULTIMATE STREET
5,000.00 WIN
1000.00 R-UP
300.00 SEMIS
200.00 1/4'S
INTERIOR
ELECTRICAL
ENGINE
SMALL BLOCKS ONLY
POWER ADDERS
SUPERCHARGER MAX
F1A-3200 #
F1C - 3250 #
YSI - 3250 #
TURBO MAX
MID FRAME
TRANSMISSION
REAR SUSPENSION
WHEELS/TIRES
WEIGHTS>
N/A SB 2700 lbs
Leaf springs -100#
V-6 -200 #
4150 CARB – 50LBS
So you can't run ladder bars at Ducks race...Because it is legal with Johns rules...
dadsnova69 is offline   Reply With Quote
Old 11-12-2012, 11:01 AM   #11
cmccarthy
Tellin' it like it is
cmccarthy's Avatar
Q16 and E85 have been disallowed on boosted cars from the beginning in this class. You've had 4 years to figure out how to make it run on C16 like the rest of us.
Charles
BAITTFMF
cmccarthy is offline   Reply With Quote
Old 11-12-2012, 11:12 AM   #12
JasonSmith
JasonSmith's Avatar
Quote:
X2 if E85 is why you arent racing you just dont really want to race
Old 11-12-2012, 01:42 PM   #13
turbotbirds
I have some great local classes I race here! So I'm not gonna put an intercooler on and switch to C for 2 races a year! I'll watch it on the live feed again!
Just maybe, the rule makers will allow it at some point! Hell, John even allows it in Ultra now and I'm sure he has seen it only allows more cars to come.
5.01@ 140
Old 11-12-2012, 01:46 PM   #14
cmccarthy
cmccarthy's Avatar
Bart Tobener went to the semis 2 years ago with a non intercooled blown 4.6 on C16. If he can do it, you can do it.
Charles
BAITTFMF
Old 11-13-2012, 11:47 AM   #15
turbotbirds
Do non-intercooled turbo combos get the same 50 pound break as the supercharger cars? Looks like it applies to all forced induction, but it is directly below the belt drive part!
5.01@ 140
