454 bbc towing upgrade power - Yellow Bullet Forums
Old 10-28-2012, 01:32 PM   #1
mickleft
Launchin
Default 454 bbc towing upgrade power
87 chevy truck. 454 tbi. looking to improve torq for towing. what is your suggestion? hopefully keep it under $1000. Thanks
mickleft is offline   Reply With Quote
Old 10-28-2012, 01:33 PM   #2
Coloradoracer
Coloradoracer's Avatar
Default Re: 454 bbc towing upgrade power
Standard stuff here. Intake and cam swap, and a free flowing exhaust.........Not a lot of dollars but nice gains with the right parts.
Mark Goulette
Owner and driver, Livin' the Dream Racing Dragster
Speed kills but it's better than going slow!
www.livinthedreamracing.com
Authorized Amsoil Dealer
Coloradoracer is online now   Reply With Quote
Old 10-28-2012, 04:20 PM   #3
c4mo
Burnout box
http://speedtalk.com/forum/viewtopic.php?t=19135
http://speedtalk.com/forum/viewtopic...28801&start=15
http://speedtalk.com/forum/viewtopic.php?p=211813
All great info threads, the last link should help on the cam. I would say free flowing exhaust, headers. Then compression and cam. If its within your budget possibly a switch to a head like 781 or 049s.
c4mo is offline   Reply With Quote
Old 10-28-2012, 08:39 PM   #4
mickleft
Launchin
Can you remove the cats/alter the exhaust with out screwing up the tbi?no smog tests here.
Old 10-28-2012, 08:49 PM   #5
ordinary builder
removing the catalists
will open up a whole new spectrum....
ordinary builder is offline   Reply With Quote
Old 10-28-2012, 08:50 PM   #6
Tims88
thread killer
Tims88's Avatar
What gears are in the truck.
Tims88 is offline   Reply With Quote
Old 10-28-2012, 09:34 PM   #7
mickleft
Launchin
i believe 3.73, i do not want to change gears. so removing cats will not affect the tbi? thanks
Old 10-28-2012, 10:18 PM   #8
ordinary builder
reprogram the computer when not hooked up to the cats....
4.10 / 4.11 gear works well with a common overdrive ratio and will still be in torque range when you drop down to direct third gear to get over a mountain or hill...
whether it is a ford ( dana type) or a gmc chevy ETC..
I wished that there was a gear ratio in between the 3.73 and the 4.10....!!!!!
Old 10-28-2012, 10:54 PM   #9
Tims88
thread killer
Tims88's Avatar
4.10's are a 10% increase in torque across the board.
4.56 would be 20% or about the equivalent of another 100ft.lbs in the engine....
3.73's are not suitable for what you're doing.
Old 10-28-2012, 11:12 PM   #10
mickleft
Launchin
how do you reprogram a the stock computer?speaking of reprogramming. found aftermarket tuners by jet.any experience with these or are these bs for a non turbo gasser? I have a factory turbo 400 trans.
Old 10-29-2012, 01:24 PM   #11
Firetruck1
draggin' ass
Firetruck1's Avatar
I have to say leave the 3.73 gears for anything unless your in the mountains. I towed with a 84 suburban dually tons of race cars and large boats here in Florida with a 468 peanut port head motor, TH400 and 3.73 geared 14 bolt with 235/85/16 tires. That thing did great and the torque was perfect. Not a tbi but I had cleaned up peanut port heads, about 9 to 1 compression, a edelbrock intake with holley carb (did the same with the q jet) and a comp cams with 550 lift. Food for thought.
Old photo before lowering the front to match the rear.
Michael
Thank you to all who have helped me on my projects:
Dan Neumann Race Cars
Fast Forward Race Engines
FTI Converters and Transmissions
Holeshot Wheels
Jones Racing Products
NRC Motorsports
TRZ Motorsports
“Le Petomane Thruway? Now what'll that a**hole think of next? Does anybody got a dime? Somebody’s gotta go back and get a sh**-load of dimes!”
I have sincere gratitude for gold star families. Thank you
Firetruck1 is offline   Reply With Quote
Old 10-29-2012, 03:08 PM   #12
MelloYello
Launchin
MelloYello's Avatar
The TBI PCM can be reprogramed by a custom burnt chip, replacing the factory prom chip.
I have a '91 K2500 7.4 tbi 4 speed stick that I have done most all the external mods you can do, chip, intake, adj. fuel reg, ignition, and headers with true duals no cats. I had to replaced the single wire o2 sensor to a heated 3 wire to get it to run smoothly especially when cold.
Its way better than it was stock, but still falls on its face after 3500rpm. I think a cam change and head swap will be next.
I had an '89 Suburban that had all the same mods as above plus big valve 781s and a hyd. roller cam. It had some serious grunt to it over a stock 7.4.
A pic of my "poor mans" duramax...
Don't tell me what your gonna do...Tell me what you've done!
MelloYello is offline   Reply With Quote
Old 10-29-2012, 03:30 PM   #13
Firetruck1
draggin' ass
Firetruck1's Avatar
Mello, never heard of a 4 speed stick in that body style truck. Is this possibly a Canada only option?
Michael
Holeshot Wheels
NRC Motorsports
TRZ Motorsports
Old 10-29-2012, 03:33 PM   #14
MelloYello
Launchin
MelloYello's Avatar
1991 was the last year it could have been an option according to the rpo codes. It wasn't a very popular one thats for sure!
Old 10-29-2012, 07:47 PM   #15
mickleft
Launchin
Sounds like the peanut heads are a problem and also low compression. Should I try and have the heads "ported" or go with a better factory head? Will improve the exhaust by getting rid of the cats. Will the tbi need to be reprogrammed or maybe get rid of tbi and run a carb? I have an intake and carb for a bbc.
