16v or 12v charging system - Yellow Bullet Forums
Old 10-23-2012, 07:45 PM   #1
GREEN FOX
Spooled up
GREEN FOX's Avatar
Default 16v or 12v charging system
Just checking to see what you all are running with F.I. and a bunch of electronics.
GREEN FOX is offline   Reply With Quote
Old 10-23-2012, 11:34 PM   #2
X-BREDBITCH
To Boost or not to Boost?
X-BREDBITCH's Avatar
Default Re: 16v or 12v charging system
No alternator here but two 16volt batteries on board.
X-BREDBITCH is offline   Reply With Quote
Old 10-23-2012, 11:37 PM   #3
Greg 1320'
Greg 1320''s Avatar
Quote:
Yep.
Twin Coyote In The Works......
Old set up "TwinBullitt" 281ci mod motor 8.0@172 on E85
http://www.youtube.com/watch?v=wyQdmMCHlmw
Greg 1320' is offline   Reply With Quote
Old 10-24-2012, 12:06 AM   #4
BigMinz
Member
Pullin gears
BigMinz's Avatar
We like one Rock 16v battery. No alt
BigMinz is offline   Reply With Quote
Old 10-24-2012, 12:08 AM   #5
luv2xlr8
luv2xlr8's Avatar
i run a yellow top optima and a 140amp alt. i just finally changed out my red top. it was 6+ years old
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 10-24-2012, 12:32 AM   #6
Greg 1320'
Greg 1320''s Avatar
Quote:
I am shocked... Almost every Optima we see ends up in the trash.
Old 10-24-2012, 01:01 AM   #7
Kjewer1
Kjewer1's Avatar
I have a red top that is at least 10 years old. Even after sitting under a pile of wet leaves while I ran a 16v battery that lasted one season it fired the car right up. It's been drained dead hundreds of times. It will crank the motor ~40-50 times for 5-10 seconds before it runs out of steam. I can't kill this thing.
If I get rid of my electric fuel pump I plan to go back to 16v and no alternator. At 9500-10k rpm I've been having trouble lately tossing belts, which kills the boost a pump fuse and porks the run. That gets old quick.
Eagle Talon RWD 122ci - 7.92 at 180 - 5.01 at 143
Mighty Max pickup 140ci - 10.7 at 125
Forced Performance - ECMlink - Kiggly Racing - Dynamic Racing Transmissions - Fuel Injector Clinic - RAD Auto Machine
Kjewer1 is offline   Reply With Quote
Old 10-24-2012, 12:25 PM   #8
MEAN_SBC
TURBOBULLET.COM BITCHES!
MEAN_SBC's Avatar
Quote:
I left a red top in the weeds and ran it over with my lawn mower the other day... lol..
I run a single lithium pros 16v battery.
Brant Campbell
Worlds Fastest MPH Car on 275's
6.92@212.09
2011 PSCA XDR/TT5 Champion
2011 PSCA Sin City Shootout Champion
Thanks To The Following:
MEAN_SBC is offline   Reply With Quote
Old 10-24-2012, 12:43 PM   #9
luv2xlr8
luv2xlr8's Avatar
i wanted to go with a different brand because i heard the newer ones made in mexico are not what the old ones were. but i made a custom setup in the back to hold it ect and it fits nice in my car and the weight of it works in my car
TROY @ RACEWIRES
Old 10-24-2012, 01:02 PM   #10
orangestang
Member
Pullin gears
orangestang's Avatar
The old ones lasted forever.... I think they were bought out a few years ago by Johnson controls and now they are building junk.....
YB! Better News Coverage Than CNN!!!!
If it has TiTs or Tires your gonna have Problems......
Rapid Roy
orangestang is offline   Reply With Quote
Old 10-24-2012, 01:07 PM   #11
taco33150
Johnson control makes die hard batteries still .. Correct??
taco33150 is offline   Reply With Quote
Old 10-24-2012, 01:46 PM   #12
blownholley50
Member
Pullin gears
blownholley50's Avatar
Rock 16v battery and alternator.... works great for me..
West Texas Mean Street-http://www.wtms275.com/
93 LX, F1R, Freezy, XFI
YouTube Page- https://www.youtube.com/user/blownholley50
Harlow Sammons Racing, Southwest Perf. & Machine
www.harlowsammonsracing.com
www.harlowsammons.com
blownholley50 is offline   Reply With Quote
Old 10-24-2012, 02:16 PM   #13
orange88
orange88's Avatar
140amp alt and a normal lead acid 12v battery
8.500
orange88 is offline   Reply With Quote
Old 10-24-2012, 04:25 PM   #14
TurboII
TurboII's Avatar
Garage
16v lithium battery and 16v Powermaster super mini alternator with adjustable output so it can be set high enough to charge battery but not exceed the limits of what a Big Stuff 3 can handle. Everything in the car is on 16v no voltage reducing devices. Had to run a little larger lithium to handle the alternator as recommended by the guys at Lithium Pro Batteries. Took 80LBS out of car getting rid of 2 red tops and extra hookup cables. New battery only weighs as much as the extra cables to run 2 batteries and the 2nd mount so it was 80LBS net savings. It helps to be slightly insane to pay that much for a battery though. Although it is hard to find anything cheaper to save 80 lbs.
TurboII is offline   Reply With Quote
Old 10-25-2012, 12:49 PM   #15
X-BREDBITCH
Where in the hell haved you been? Been doing any races lately Get those 200mph passes yet
